Old 08-26-2004   #1
SUX2BU's Avatar
Why no "boost box" for our CAG's?
I've read up on these and the theory behind how it works sound ok. but i only see then for the 49 cc midi bikes. what gives?
SUX2BU is offline   Reply With Quote
Old 08-26-2004   #2
davesmotors.com's Avatar
Boost bottles are only useful on piston skirt engines which lack a reed to prevent flow back into the carburetor.
The reed valve inducted engines as featured on the '47cc' bikes don't need boost bottles - the reed valve does the same job
davesmotors.com is offline   Reply With Quote
Old 08-26-2004   #3
SUX2BU's Avatar
oh ok. thanx
Old 08-26-2004   #4
I don't know if it's completely useless, Though, I have heard that before from people that know more than me..
Try running the bike without any air filter on it. If you rev it up you can see exhaust coming back through the intake. I can't prove this happens on all bikes, but mine has done it with both stock and CF reeds. This makes three big performance losses,
1. Less oxygen. The exhaust has already been burnt, leaving little or no oxygen left. Sucking that back in is just a waste of space.
2. Hot Gases. Heated gas has increased volume. This means that you are getting less gas back in per stroke. (39cc of cold air has more oxygen than 39cc of hot air)
3. Rich state. The air coming in, going out, and coming in again has passed by the carbuerator 3 times. Not very efficient or accurate, you can imagine. You can "tune "this out with the adjustable jet, but this is only a band-aid to the real problem.
I might try making one and see if it really does help, I've seen people say yes and no. You can make it cheap enough, and if it does what it could, it should improve all round somewhat.
Btw, I wouldn't spend money on a boost box. Just make one for like $.50
PMantix84 is offline   Reply With Quote
Old 08-26-2004   #5
Couple minor corrections for you re:1 and 2...
The fuel/air mix coming back out past the reed is not exhaust. It is unburnt fuel/air which should be forced up through the transfer ports into the cylinder, but is instead leaking back out the reed.
On 3, you are exactly right - the disruption of airflow across the carb needle results in a mixture different than what is intended.
Old 08-27-2004   #6
Yeah, you're right..
When I saw this coming out I bent over to smell it. I guess it never crossed my mind that the exhaust it right there too.
You'll get that when you work on cars a lot and just tinker on a little bike occasionally.
Thanks for the fix
Banshee cags, water cooled cags?!!!!!!!!!!!! Patrick8 Water Cooled Pocketbikes 1 03-26-2005 05:57 PM
cags vs x7's??? SIN84D 2Stroke Midbikes 24 03-01-2005 04:10 PM
New Boyesen Reeds For Cags!!!!!!! Demtoofast Air Cooled Pocketbikes 38 01-12-2005 07:29 PM
welcome to the world of cags hayabusa Air Cooled Pocketbikes 16 10-30-2004 11:43 AM
What rear sprockets fit Cags? SDR1DER Air Cooled Pocketbikes 2 09-04-2004 03:52 PM
Page generated in 0.22933 seconds with 33 queries
