Old 07-08-2008   #1
Won't start
Hi.
I have mounted a new carburator on my cag, and now i just can't get it to start It worked fine before... What can the problem be?
Old 07-08-2008   #2
matty boi's Avatar
Re: Won't start
which carb is it?
matty boi is offline   Reply With Quote
Old 07-08-2008   #3
Re: Won't start
I don't really know... But i think it's this one: Carb + Filter Upgrade 47cc Pocketbike Pocket Bike CAG - eBay (item 330121618378 end time Jul-11-08 12:36:57 PDT)
And then i have a 49cc cag. One of the rare ones that really is a 49cc.
Old 07-08-2008   #4
matty boi's Avatar
Re: Won't start
ok so you have a dell rep. is the slide closed? like when youre not touching the throttle. the reason i ask is because a lot of people have trouble installing the throttle cable on those carbs.
Old 07-08-2008   #5
Re: Won't start
Yes, the slide is closed... And yes, it was pretty hard to instal it! But i have one exactly like it on another engine, and it works great.
Old 07-08-2008   #6
StrayDawg63's Avatar
Re: Won't start
Make sure your not missing the black rubber seal or the plastic sleeve that's in the motor side of the carb that slips onto the intake adapter.
Old 07-08-2008   #7
Re: Won't start
I'm pretty sure they are where they should be :-)
Old 07-09-2008   #8
Re: Won't start
I hope you take a peek in there anyways. Pretty sure is just like saying you don't know forsure.
Old 07-09-2008   #9
Re: Won't start
then what exactly is it you meen...?
Old 07-09-2008   #10
Re: Won't start
I mean pull the carb off the intake manifold and look inside of the carb from the backside of the carb that slips onto the manifold. There should be a black rubber seal inside the carb and a plastic sleeve that slips onto the intake manifold.
Old 07-09-2008   #11
Re: Won't start
ooh. Okay man :-) And what if there isn't? I haven't looked yet...
Old 07-09-2008   #12
Re: Won't start
Well if there isn't than that's your problem. Also while your there make sure your getting gas into the float bowl and that there's no crap in the bottom of the float bowl. Take the main jet out and make sure it's not plugged up. If you can blow some air through the carb where the main jet goes. Or atleast spray some carb cleaner through it.
Old 07-09-2008   #13
Re: Won't start
I changed the carb with one just like it, and now it works :-) So the problem is the carburator. I will try to clean it.
Page generated in 0.27327 seconds with 54 queries
