Originally Posted by DJ411 hey guys so i've been reading some of these posts. I have the 2 spring one, Red springs Clutch. I didn't understand how the clutched worked, thankz to Google i got the answer.
But i'm worried about mine, like i don't know if it's just how the clutch is or i have a bad rim. It doesn't spin smoothly. When i jack up my bike and get it started. I have to throttle (to me) a lot compared to my other bike. That has 3 springs. |
Something you should check before the clutch. check whether your chain is too tight, your axle bolt is too tight and any damage on the wheel bearings. Then to the clutch, you should set your engagement point to right before the engine hits the powerband. I am thinking your clutch may engage too soon, that's why it feels lack of power.
Tighten your springs: engage later.
Loosen your springs: engage sooner.
Better off having a measuring caliper to help you to make sure both side of the springs are equal in height to avoid uneven worn. A tach is a handy tool to have for clutch adjustment as well
here is an good read about clutch adjustment:
Minimoto Garage - Clutch Setup and Adjustment
