Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 02-02-2006   #1
AWM
AWM's Avatar
911 Rep Clutch Question
I have heard many times that the stock clutch on the 911 rep is garbage and it would be better to upgrade. I am a bigger guy so I feel a 3 shoe clutch is best for me.
The problem I have is that I'm not a big time racer and don't want to fork out the 200-300 dollars for a performance clutch.
Is there a clutch out there for the 911 rep that is 3 Shoe adjustable under $100?
And if not, what modifications are required to put in a stock 3 shoe C1 clutch in the rep. I know the drum on the rep is 78mm and the drum on the C1 is 80mm
Is there a help on this anywhere?
Thanks
AWM is offline   Reply With Quote
Old 02-02-2006   #2
PBP Administrator
nick's Avatar
Re: 911 Rep Clutch Question
pocketbikesunlimited.com
http://www.pocketbikesunlimited.com/RACINGCLUTCH.html
this looks to me like what you are looking for...
Thanks
nick is offline   Reply With Quote
Old 02-03-2006   #3
bennymax's Avatar
you can put a C1 clutch on your 911Rep only change the original bell or machine it to 79,7mm
but belive me an italian clutch is the best choice for you (any trouble)
you need also a 80mm bell too...
ciao
bennymax is offline   Reply With Quote
Old 02-03-2006   #4
AWM
AWM's Avatar
If I buy that 3 shoe clutch from PBU do I need to buy anything else with it, or can I use my existing bell?
Old 02-07-2006   #5
PhatBikes's Avatar
You won't need anything
PhatBikes is offline   Reply With Quote
Old 02-07-2006   #6
DemonSpit's Avatar
3 shoe clutches are not cheap, but $200-$300 is a little silly for price. 3s Zocchi clutches start at about $140 and will out-perform anything currently on the market. But do remember these are racing clutches, so for bashing around out in the parking lot, they may not do aqll that well. If you are racing, theres nothing better.
http://www.demonmotosports.com/defau...ng&Category=21
DemonSpit is offline   Reply With Quote
Old 02-07-2006   #7
http://www.wtpbra.com/
gulliver22's Avatar
The 911 replica stock clutch is a joke and definitely needs to be replaced (because it engages way too low in the rpm range). I tried the Chinese adjustable 2 shoe and it was toast in less than 30 minutes. I'd recommend a BZM, Zocchi or Polini clutch. I forgot what size the stock bell (think it was 79 or 78mm?) is on the replica, so you should measure it and then discuss with your dealer before you buy one of the racing clutches so they match up.
Also, one other important point, the bellhousing on the replica motor is not the same size as the polini bellhousing where it mates to the crankcase, so don't buy one of them thinking you can bolt it up (you can buy the 80, 79 or 78mm bells and install them in the replica's bellhousing if you need too). Why is this an issue? Most racers will have all 3 bells usually mounted in their own bellhousings, that way when the clutch wears down they just switch to a smaller bell and the clutch shoes last a lot longer.
Hope that helps...
gulliver22 is offline   Reply With Quote
Old 02-07-2006   #8
yep put a polini cluth on itand be done with it.when my rep was stock i ran the 80mm polini cluth wich u can get for 100.00 set at 4500 realse and went out and one the season championships with it
alphy280z is offline   Reply With Quote
Old 03-08-2006   #9
gulliver22's Avatar
4500 rpm????!!!
Old 03-08-2006   #10
MelloCag's Avatar
Originally Posted by gulliver22
4500 rpm????!!!
It's gotta be a type error
Old 03-08-2006   #11
gulliver22's Avatar
I hope so. The p.o.s. stock replica clutch will engage higher than that (but not much).
Old 06-04-2006   #12
the c1 clutch will go right in the 911 rep. it works pretty good, a lot better than stock.
b and b racing is offline   Reply With Quote
Old 06-04-2006   #13
i took the stock motor out & put a 40cc polini motor in it
c1 rep clutch question bri-on-1 Water Cooled Pocketbikes 12 05-18-2006 01:53 AM
Blata Origami B1 Clutch in a 911 6.2 MINIMADNESS European Pocketbikes 3 04-03-2006 07:18 PM
Clutch set up for the 911 Rep notics Water Cooled Pocketbikes 14 11-28-2005 07:28 PM
911 rep what is the best clutch combo ???? Liquid-cooled-qc Water Cooled Pocketbikes 18 10-27-2005 09:27 AM
Best clutch combo for 911 rep check it out ?? Liquid-cooled-qc Water Cooled Pocketbikes 7 08-02-2005 12:11 PM
Page generated in 0.31181 seconds with 54 queries
