WOOOOOOO HOOOOOOOO!!
The jets work!!! I got the bushing/sealing ring made and reinstalled the carb. The biggest jet I had on hand was an 82..........too small. I had good pull through the top end but the plug is barely colored after 4 full throttle runs to top speed. I've gasket matched the jug and case and I'm running BAT fglass reeds. I'm estimating I'll need an 84-86.
By the way............ THIS CARB MAKES THE BIKE FLIPPIN FLYYYYYYYYYYYYYYYYYYYYY, and, it'll only have more power when I get the larger jets!!
Having the numbered jets made tuning VERY easy. I made two jet swaps(78-80-82) until the top end sounded good, put the clip in the fourth slot, set the A/F screw till the throttle response was good(WAY better than stock)and set the idle(nice and smooth)...........all on the bench. Then I took it to my neighbors 550 ft driveway for the full pulls.
(kinda spooky trying to reign it in on slick blacktop
Chris, if your watching, stock up on Dellorto's and include them with this carb.
Your customers will thank you.
Finally, I can give this carb a BIG
Banzai !!!!!!!!!!!
