Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 01-03-2005   #1
badazztoyz.com's Avatar
BadAzzToyz.com Banshee SHO review with pics (hydra vs SHO)
I cannot post the pictures so to see the pics go here
http://badazztoyz.com/forum/viewtopic.php?p=223#223
We just barely got these bikes in and are down to one until mid february. We will be doing the review over the next week of this bike. So far I am very impressed with the quality of the bike, you wont snap any of these bolts and dont have to worry about the pullstarter breaking. It does sit a little lower than the Hydra but the pegs on it are top notch. The bike did not overheat on me once in the ten laps I took. We will continue to update this as we learn more or experience problems (if we do).
If you have any questions please post them in the general section.
Upon first inspection you can tell right away that this bike carries the quality that all of the other china bikes lack and anyone who has came into the shop did not believe it was a china bike. Using stainless steel fasteners, braided coolant lines, seat fairing support, quarter turn throttle, certified radiator, external water pump this bike is sure to drop the prices on the italian bikes.
Specifications:
Engine- 49cc two stroke single cylinder water cooled (40x39) bore and stroke
Power-9.7hp@ 13000 rpms
Compression ratio-9:1
Carburetor-18.5mm
Fuel induction-Reed valve direct to crankcase
Ignition-CDI
Coolant system-15 section aluminum radiator
Clutch-2 shoe adjustable
Drive system-Chain
Brakes- Front Dual 120mm Disc Brakes
Rear 80mm Disc Brake
Tires: FRT/RR 110/50-65
Tank Capacity: 1.5 L
Body Material: 2mm Automotive ABS Full Fairings
Frame: MIG-Welded Cast/Extruded Aluminum
Performance-Keep in mind I am comparing this mainly to the hydra
Power- Out of the box this thing flies but the bottom end is lacking even though it is geared 6/74. Once the power comes on it is gone, feeling similar to a kx60. I think with a smaller diameter header pipe it would have a perfect power band. from a stand still the hydra bike will beat it 0-20ish and afterwards the banshee pulls on it. Please keep in mind the hydra is not stock, having a 17mm carburetor and using 6/68 gearing.
Handling- This bike is shorter than the hydra and taller riders may not like it as much but it all comes down to preference. With the way the pegs are situated you dont have to worry about hitting them on they ground like you do with alot of other bikes. Oh yeah the quarter turn throttle really kicks a$$.
Quality-Hands down this a very high quality bike and you cannot compare it to the other bikes it is just not fair http://badazztoyz.com/forum/images/s...icon_smile.gif
Pros-
-Very fast out of the box
-Unbelievable top end
-Top notch in the quality department
-Radiator is awesome
-External water pump is a plus
-Polished aluminum gives it the bling bling factor
-Comes with slicks
-Huge carburetor and filter
-Nice pegs
Cons-
-Shorter than hydra (preference)
-Clutch material suxor
-Its kind of hard to get to the carburetor without removing alot of stuff
-Bottom end is lacking
-Heavier than hydra
Known issues-
-Clutch sux
Old 01-03-2005   #2
great review Chris looks like a good seller to me!! i cant believe the quality of these bikes they really look nice!!!
Old 01-03-2005   #3
lanislover89's Avatar
GREAT revieling photos. this bike looks high in quality
lanislover89 is offline   Reply With Quote
Old 01-03-2005   #4
so what do you recomend this bike needs just a better clutch and smaller diamiter header pipe for now? and what clutch would you recomend for this bike.
Old 01-03-2005   #5
Got mine today from BadAzz, thanks alot. Good shipping and no breakage whatsoever. The bike is nice although its raining here so I can't ride it. May want to look at clutch before u ride it. One sping was set at 1mm longer than the other, probly not good. Set both at 17mm I think, will see what happens. Only other problem is both sprockets run off center pretty bad, yes the pinion too. I've see back sprockets like that, but the pinion shaft has got to be bent or something. But other than that, it is nice.
Bennyhanna is offline   Reply With Quote
Old 01-03-2005   #6
Obpr's Avatar
nice bike my only question is how are you using stainless steel hardware on an aluminium frame? How do you prevent galvanic corrosion?
Obpr is offline   Reply With Quote
Old 01-03-2005   #7
blah's Avatar
Hey Mr Badazz, my mum has warned me about them radiators, she says they look like oil coolers, she says she don't know if they would work too well over here where its 100 fricken degrees, what do you says?
Old 01-03-2005   #8
I just don't understand how no one realizes that this bike is a 98% copy of the GRC GP! I used to own a GP and it was an odd handling bike, the C1 handles better IMO. The GP, and I am sure this bike as well, was too stiff. But anyways... it might not even show up on the track, as most china bikes don't...
Method Man is offline   Reply With Quote
Old 01-03-2005   #9
galvanic corrosion only occurs when the 2 metals are in contact with water. but it will suck when its time to wash your bike. id recomend getting a differant screw matterial that doesnt conflict with the aluninum frame to prevent a rust like breakout.
Old 01-03-2005   #10
Obpr's Avatar
water does accelerate it but it is possable any time 2 dissimilar metals come in contact, (humidity provides enough water to create a reaction)
i don't think it will be fast but i do think it is a possability.
Old 01-03-2005   #11
hmm. i doubt the bolts are coated with anything. good point, this may be a problem. i guess only time will tell
Old 01-03-2005   #12
http://www.wtpbra.com/
gulliver22's Avatar
Not to bust your chops badazz, but from what I understand, the SHO/Banshee would have to race in the open class at most tracks (cuz it's 50cc?), so how would it stand up to other open class pb's (even with modifications)?
I like the bike and would buy one, but not if the other open class bikes are going to eat it's lunch (even if they do cost 2-5 times as much). Of course if I bought it without no intention of using it competatively (or if it is in fact, competitive), then the above wouldn't matter.
Mike
gulliver22 is offline   Reply With Quote
Old 01-03-2005   #13
the phone isnt busy any longer
YES!!! I got through to the guys at Badazz today...I was happy until they notified me they have no more sho's in stock!!!
I'm looking for 2 of these bad boys if anyone knows where i can purchase 2 at the price BAT's sells them for me let me know..
METHOD MAN
the ones being purchased will absolutely be at our local track, yup with all the Euro riding haters pointing their fingers at us..
whome is offline   Reply With Quote
Old 01-03-2005   #14
blah's Avatar
Hey fellas, to judge if galvanic corrosion will take place between metals you have to know what metals they are, there's so many different Aluminiums and stainless's that it's impossible to tell.
http://www.metal-mart.com/Guides/Galvanic.htm
Old 01-04-2005   #15
as far as racing is concerned yes you will be at a disadvantage but here we run a chinese wc class lol. wont steel wool rememdy the corrosion? Im going to get a jet kit and mess with clutch and see if it really needs diff exhaust etc.
blah-blah
Old 01-04-2005   #16
blah's Avatar
Originally Posted by badazztoyz.com
blah-blah
yes-yes? are you planning on pulling the engine apart and taking some pics with that flashy camera ?
Old 01-04-2005   #17
Ritchey79's Avatar
Galvanic corrosion isn't even an issue in this case stainless fasteners aren't high on the chart. This would be like saying that the aluminum or magnesium rims on a Corvette or any other car for that matter would corrode right off the steel studs as soon as you washed it or drove it in the rain!
Old 01-04-2005   #18
Obpr's Avatar
i didn't mean to make it out that galvanic corrosion is some huge problem, i just found it odd to use stainless with aluminium it was something i was taught to avoid.
steel wool, wire brush or sandpaper will remove it, it causes more problems with discoloration, kinda like the battery terminal on a car after time,
as long as the bike is kept dry it should take months before it is even noticable,
not sure of the longevity of these bike but it could be a problem when the bikes are a few years old
Old 01-04-2005   #19
blah's Avatar
Lol, dude on aus ebay 7124620506 claiming 22,000rpm and 100kph from C1, I can't wait till he starts selling banshees, 150kph 30,000rpm maybe?
Old 01-04-2005   #20
Ritchey79's Avatar
Yeah, it's kinda funny b/c my L7 had this problem when I first got it. Mainly just on the brake calipers. Figured the saltwater in the air during shipping from china caused it. Throw in an electrolyte like salt water and you have a real problem. Ahh... that brings back Chem and Physics Lab memories.
Banshee SHO - Project Pics... MachV Water Cooled Pocketbikes 18 07-01-2005 05:02 AM
Banshee SHO High Performance Pipe Kit scooterteq Water Cooled Pocketbikes 17 06-21-2005 12:44 AM
Banshee Sho..mmmmm 12345 Water Cooled Pocketbikes 4 01-04-2005 06:17 PM
Page generated in 0.38679 seconds with 79 queries
