Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 04-19-2005   #1
j4m1eb's Avatar
Question Banshee SHO - Runing in
Just ordered a black Banshee, now the questions start.
Any advice on running in, I assume its 25:1 for 5 tanks? litres?, but is it gentle riding? bursts of full throttle? or what?
With my AC Cag I just thrashed it from the get go - but I'd like to be a bit more carefull with this.
Also I've read the clutch spring thread, does it matter if I run the standard springs whilst running in? If its ok should I make sure they're adjusted the same length and if so what should that be and is it simple?
Can't wait
j4m1eb is offline   Reply With Quote
Old 04-19-2005   #2
NITROMUNCHER's Avatar
here is the deal, i have a banshee h2o and have played with alot of them! break in is 25:1 mix (DO NOT use semi syn. or syn oil) for 1 tank, make sure you ride it for break in because water pump does not work untill clutch is engaged! you can rev it up a bit while riding for break in just dont beat on it for the first 20 min or so! change the clutch springs to red zocchi ones and adj. engagement to 8500 rpms! after that lean forward when the power band hits or you will have some serios road rash! i am r&d the zocchi high flow water pump and 21mm carb and will let everyone know the results when i get back from vacation!
NITROMUNCHER is offline   Reply With Quote
Old 04-20-2005   #3
this has thrown me a bit,what is wrong with using a 25:1 mix with synthetic for the first tank.
i didnt even consider using non synthetic so i take it that there is a good reason for doing so.
jas328sport is offline   Reply With Quote
Old 04-20-2005   #4
yup there is wear
johnboyjoe is offline   Reply With Quote
Banshee SHO High Performance Pipe Kit scooterteq Water Cooled Pocketbikes 17 06-20-2005 11:44 PM
X7 with Banshee sho motor confirmed. cliveyx 2Stroke Midbikes 10 02-16-2005 08:34 PM
Banshee Sho..mmmmm 12345 Water Cooled Pocketbikes 4 01-04-2005 05:17 PM
Page generated in 0.23226 seconds with 27 queries
