Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 02-16-2005   #1
vtecds1's Avatar
Angry C1 not moving...
My Buddies C1 is having a big problem.The motor runs but for some reason the the rear wheel doesnt want to turn.I can see through the clutch housing that the clutch is opening up but for some reason it doesnt want to turn the pinion.Checked the housing and changed the pads 3x already.We even took the housing and put it on my other buddies C1 and works great.We adjusted the cluth to engage earlier and late and still the same problem.Any1 have any ideas....thanks!!!
vtecds1 is offline   Reply With Quote
Old 02-16-2005   #2
Cole's Avatar
tighten your springs as much as you can. It happend to me too. don't try and beat the springs it is a loosing match....just tighten them up hard and ride it even harder
Cole is offline   Reply With Quote
Old 02-16-2005   #3
badazztoyz.com's Avatar
no dont do that..crack open the throttle all the way for a couple seconds it will start turning
Old 02-16-2005   #4
Cole's Avatar
well the being said, keep in mind you r clutch does not kick in to like 6-8 1000 rpm. so you need to realy floor it to get it to respond. But i still had simler problem with my springs being to loose.
Old 02-16-2005   #5
vtecds1's Avatar
Weve tried to leave it stock and adjust it to were it will engage late .The wheel will turn sometimes when its on the stand but definitely not when theres load on it.Even at full throttle.Any other suggestions...
Old 02-16-2005   #6
have you torn off the clutch drum and seen if theres a clutch shoe or something broken off in there?
Old 02-18-2005   #7
vtecds1's Avatar
Yup...we kept on replacing the clutch to see if it was the culprit but no.We even swapped the clutch housing onto my other buddies bike to see if it was the problem,but it wasnt either.But i did talk to my buddy last nite and he got one of his coworkers to redo some of the welds on the pipe since we notice it was leaking.He said it runs a little sluggish on the bottom end and flutters at top.But at least its moving now.
Old 02-18-2005   #8
nice! tell him to upgrade his reeds or reed cage. Stock cage has no limiters but with fiberglass reeds you dont need them
C1 (2nd gen) vs polini (all polini) ;) Juan Luis Water Cooled Pocketbikes 35 05-03-2005 02:40 PM
which c1 is better? crashburn314 Water Cooled Pocketbikes 13 04-25-2005 06:57 PM
My experience on C1 and GRC RR 8.5 John P Water Cooled Pocketbikes 6 02-23-2005 10:30 PM
Page generated in 0.23280 seconds with 40 queries
