Originally Posted by dcminimoto.com This isn't the proper way to get the clutch into the engine case, we developed the modification required to Zocchi and BZM clutches for Blata cases. While it may seem this is the proper approach, it isn't. We send out all clutches preset for the C1 Cagami, when the customer specifies the application. Very soon, we will have clutches for the C1 Cagami that will not require any changes. Just install and go. |
Your right with the zocchi clutch there is no modification required but if the stock clutch is used with the zocchi drum the nut will hit if it is not shaved down. My clutch kit from dcminimoto was $205 but I went with the 60gr. ergal and carbonium 3 shoe kit. It works great and I have tons of laps on the zocchi kit but if you do not want to spend the extra $ the drum fix works well.
