Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 01-19-2009   #1
Council Member
sr20hardbody's Avatar
Cool dellorto 19mm vs dell rep 19mm comparison
k just checked out all parts between the genuine dellorto 19mm and the dell rep 19mm and all parts are interchangeable!!!
the dell reps thread taps arent the greatest which requires a little force when screwing in jets but no big deal they fit and have the same thread pitch just be careful. the reps choke needs replaced with a genuine choke to keep it sealed. the bowl screw on one side is too long and hits the air/fuel mixture screw use a shorter screw on that side. the needle clip is the wrong c clip you'll need a genuine c clip or find the proper size to allow the needle to drop all the way into the atomiser. the seal inside the air/fuel screw passage (little o ring) is the wrong size. the slide has 2 slots on each side which can be dropped in backwards keeping it from running mine came that way
the dellorto has slightly tapered holes inside the inlet/outlet bore. the springs throughout the carb are of better quality and the bowl is also made of a higher grade plastic along with the top piece. it doesnt use lock washers on the bowl screws which is why the rep might leak from overtightening the bowl using these lock washers.
so theres the difference and important info on getting these dell reps running. if i think of anything else i've forgotten i'll add it along the way or if anyone else finds any issues post them up! reason for this thread is these carbs have been out for quite some time and most have had bad luck with them and no one has the for sure answer to all these questions. buying a genuine dellorto would be the way to go but if you already bought the dell rep heres your answers and some pics. i'll get a couple more pics up once i can fit them and the genuine parts are on the right side rep on the left.
Old 01-19-2009   #2
Council Member
Re: dellorto 19mm vs dell rep 19mm comparison
and heres a couple more pics also the dellorto has threads for a screw on velocity stack the rep doesnt.
Old 01-19-2009   #3
bIkEinPoCkEt999's Avatar
THANK YOU. this should be a sticky
bIkEinPoCkEt999 is offline   Reply With Quote
Old 01-21-2009   #4
287889's Avatar
The big difference is the needel, the original carb has a much more tapered needel then the rep this will give more fuel and at high rpm will kepp the engine revving
287889 is offline   Reply With Quote
Old 01-21-2009   #5
Council Member
every engines different what works for one might not work for the other even though they may be identical. i couldnt get my bike running with the real tapered needle i had to use the sharp pointy reps.
i do believe this also has to do with the entire set up the real tapered needle may work with my bike but i'll need to change atomisers etc..
Old 02-25-2009   #6
Torquehead's Avatar
Well done bro.
My 19 Rep's atomizer had smaller holes in the tube so I just got a genuine replacement. Luckily messed up the order and got a package deal with the o-ring, needle...the whole kit in one.
(What bike are you using this Rep on?)
TH
Torquehead is offline   Reply With Quote
Old 02-25-2009   #7
Originally Posted by Torquehead View Post
Well done bro.
TH
torque ,
you might try taking your rep atomizer and solder the holes shut and try it to see how it works or if it works any differently . there are 13 different atomizers for the phbg and some work a little bettter than others depending on your setup
capt highsider is offline   Reply With Quote
Old 02-25-2009   #8
tomkat's Avatar
nice info..
I am still gonna go for the dell..
tomkat is offline   Reply With Quote
Old 02-25-2009   #9
cagaroni's Avatar
perhaps add a list of all the important dellorto part #'s needed to fix the reps flaws..
Old 02-25-2009   #10
Torquehead's Avatar
Originally Posted by standardracer View Post
torque ,
Thanks Standard, much appreciative of the extra techno!!!!
Well, odd thing as it was, I used an atomizer (genuine) with larger holes on the rep as well as a other adjustments and parts were changed. I also mix my own "odd exotic fuel", so I had to use some nylon components. My final combo corrected a lean issue altogether. I was sent an "interesting" setup, as it seemed as if it were intended to be very detuned...dont know...
So an atomizer with small or no holes work good with station fuel? ....geez, I just need to read up on it again before I put the C2 back together this season...
Or, as suggested by NosMan a time back, I may use my Race Edition PHBG (Seen here: (Genuine) Dellorto PHBG 19mm Black Race Edition) that Ive only tried once. I dont want this fuel I use to mess it up though.
Old 02-25-2009   #11
needle c clip
metal float bowl with drain screw (stock screws with lock washers will work fine with this, since it cant warp the metal bowl)
gaskets
note:for a stock blata replica engine, i found the stock setup to work quite well with the exception of running an 84 main and c clip second from top
Old 02-26-2009   #12
Well I cant speak for the blata rep motor with this setup . but I could not get it to run past 6000 rpms with a 262 AN atomizer on a 40 3T polini , a 50 5T polini , BZM 50 6T or the 40 blata . I think the holes are so big it atomizes the fuel too much for a 2 stroke . The smaller sizes 258 260 &262 need bigger jetting where as the taller sizes 264 266 requires a little smaller jet . The AU 262 is pretty much identical to the AN262 except it doesnt have the extra atomization holes in the atomizer . I think a AN 262 would work fine as the holes are alot smaller and dont add so much air to the fuel mixture coming in . Now I have the same black race carbPHBG19 R and a reg PHBG19DS one came with the AN and the other came with a AU in it the AN was the one that wouldnt rev over 6 G until I soldered the holes shut then it ran perfect what i should have done was solder a few shut and then tried it but I was just too frustrated with it so I said screw it and closed them all . Dellorto gives you way too many tuning options with these carbs as they are used on alot of different stuff 2T and 4T however you can fine tune this carb to anything you put it on .
Old 02-26-2009   #13
StrayDawg63's Avatar
I run the TS setup in 2 of my polini 911's a 40cc 5-port and a 50cc open and they both rev to the moon. Running the AN266 atomiser with the 4T nozzle allows the motor to get more fuel cause the 4T nozzle is bigger than the 2stroke nozzle. So that carb you tried with the AN atomiser must of had the 2stroke nozzle in it. Which when using the AN atomiser with the 2stroke nozzle it puts the main jet pretty much against the fuel bowl cause it makes the main jet sit about a 1/4" deeper into the fuel bowl thus not allowing enough fuel to get into the motor. So it sucks in more air from above the fuel level. By plugging the little holes and using a bigger main it helps it to suck up more fuel instead of atomising the fuel.
Old 02-26-2009   #14
cagaroni's Avatar
Originally Posted by bIkEinPoCkEt999 View Post
needle c clip
gaskets
um i meant like a simplified list of the name & part number for newbies so they could order a rebuild package. kinda like this:
CARB GASKET SET - PHVB - 52621
GASKET SET PHBG - 52526
W23 NEEDLE - W23
1486 MAIN-PILOT JET 102: 1486-102
Old 02-26-2009   #15
cagaroni's Avatar
parts list here:
Dellorto and weber carburettors online
9562 AN type atomiser bush Part No - 9562 £7.95 Details
9655 AU atomiser bush Part No - 9655 £7.95 Details
(1) PHBG Slide Part No - 9475 £15.95 Details
(2) PHBG W type needle Part No - 9595 £9.85 Details
(3) BQ type atomiser size 254 Part No - 10132.254 £7.95 Details
(3) BS type atomiser size 262 Part No - 10427.262 £8.95 Details
(3) PHBG AU type 2 stroke atomiser Part No - 9654 £8.95 Details
(3) PHBG AN type 4 stroke atomiser Part No - 9511 £8.95 Details
(4) PHBG Main jet Part No - 1486 £3.28 Details
(5) PHBG Idle jet Part No - 1488 £3.28 Details
(6) PHBG choke jet Part No - 9501 £4.95 Details
(7) PHBG Float assembly Part No - 9450 £11.95 Details
(9) Rubber cable cap Part No - 1476A £0.95 Details
(9) PHBG Cable adjuster - straight Part No - 1104 £1.95 Details
(10) PHBG Cable adjuster lock nut Part No - 1691 £0.48 Details
(11) PHBG Carburettor top screw Part No - 9588 £0.60 Details
(12) PHBG Carburettor top Part No - 9482 £3.95 Details
(13) PHBG Carburetor top gasket Part No - 9514 £0.95 Details
(14) PHBG Slide return spring Part No - 9597 £2.45 Details
(15) PHBG Needle plate Part No - 14958 £1.25 Details
(16) PHBG Needle circlip Part No - 9596 £0.60 Details
(17) PHBG Pull-up choke assembly Part No - 9538 £9.95 Details
(18) PHBG Choke Assembly O ring Part No - 8297 £0.60 Details
(19) PHBG Mixture screw O ring Part No - 8678 £0.30 Details
(20) PHBG Mixture screw washer Part No - 8260 £0.25 Details
(21) PHBG Mixture screw spring Part No - 9336 £0.55 Details
(22) PHBG Mixture screw Part No - 9517 £3.95 Details
(23) PHBG Slide stop screw spring Part No - 4670 £0.60 Details
(24) PHBG Slide stop screw Part No - 7673 £2.95 Details
(25) PHBG Float bowl gasket Part No - 9497 £1.75 Details
(26) PHBG Float needle valve Part No - 2838 £5.95 Details
(27) PHBG Anti-surge washer Part No - 9779 £2.95 Details
(28) PHBG Float pivot pin Part No - 9506 £1.50 Details
(29) PHBg Float bowl - Black plastic Part No - 9444 £5.95 Details
(30) PHBG Spring washer Part No - 5011 £0.20 Details
(31) PHBG Float bowl screw Part No - 9588 £0.60 Details
(32) PHBG Trumpet - 34mm Part No - 9830 £4.95 Details
(33) PHBG Wide trumpet Part No - 9814 £4.95 Details
(34) PHBG Float bowl - metal Part No - 9811 £12.95 Details
(35) Fibre seal Part No - 4570 £0.50 Details
(36) PHBG Float bowl nut Part No - 9812 £4.95 Details
(37) PHBG Choke support Part No - 3128 £2.75 Details
(38) PHBG Choke return spring Part No - 3133 £0.75 Details
(39) PHBG Choke piston Part No - 9872 £3.95 Details
(40) PHBG Cable adjuster Part No - 1481 £1.95 Details
(41) PHBG Cable adjuster lock nut Part No - 1692 £0.30 Details
(42) Cable elbow - 50 Part No - 10854 £3.28 Details
(42) Cable elbow - 70 Part No - 3600 £3.28 Details
(42) Cable elbow - 40 Part No - 9330 £3.28 Details
(42) Cable elbow - 90 Part No - 3698 £3.28 Details
(43) PHBG Manifold clamp nut Part No - 8128 £1.55 Details
(44) PHBG Manifold clamp Part No - 8129 £4.95 Details
(45) PHBG Manifold clamp bolt Part No - 8127 £1.95 Details
(46) PHBG Gasket set A & B Part No - 52526 £4.95 Details
(47) PHBG Manifold sleeve Id - 23mm Part No - 4477 £2.95 Details
(47) PHBG Manifold sleeve Id - 24mm Part No - 8376 £2.95 Details
(48) Short trumpet - 20mm - Plastic Part No - 4224 £4.95 Details
(49) PHBG Airbox adaptor Part No - 9365 £3.95 Details
(50) PHBG Lever choke assembly Part No - 53012 £13.95 Details
(51) PHBG cable choke assembly Part No - 53002 £11.95 Details
Old 04-15-2009   #16
Council Member
Well done bro.
TH
im using the rep on the banshee torque
parts list here:
nice edition cagaroni!
Old 01-28-2010   #17
A.K.A. Doctor Dellorto
bike mad yank's Avatar
So, let me get this straight. By the time you've paid out for a rep carb and all the bits to make it right (£25 for a side, £10 for a needle, £14 for a choke lever, £9 for an atomiser, blah-de-blah-dee-blah, shipping and handling, etceterahhh, etceterahhh, etceterahhh) you may well have just paid for a genuine Dellorto to begin with. A lot of people don't know, that if you order a carb from a Dellorto dealer, you can specify exactly what you want inside your carb and it shouldn't cost you a penny more (I got my last PHBG racing carb, from Eurocarbs, fully built to Trev's magic formula complete with lever choke for £75). Which makes it even better that people like Trevor Sellars go to such pains to record every detail and hand the information out for free. So generations of people to follow don't have to find out the hard way.
bike mad yank is offline   Reply With Quote
Old 4 Weeks Ago   #18
Question Re: dellorto 19mm vs dell rep 19mm comparison
Sorry for jumping in on this thread, but i didn't want to start a new thread. Hi bike mad yank. I can see from your posts that you know a lot about tuning a dellorto carb! Could you please help me with a base setting on a phbg 21mm on a 50cc 6 port bzm motor. The current settings is as follows: 110 main jet, 50 pilot jet, 60 starter jet, 40 slide, W23 needle, 266AN atomizer. The bike is a new BMS P2. I'm at 5000 ft above sea level and a temperature of 25 degree celcius. Currently the bike can't even idle and starts easy without choke and just small throttle opening. i think i am way to rich for my altitude, already checked no air leaks. Any suggestions on jetting for this altitude? Thanks Andrio
Andrio is offline   Reply With Quote
Old 4 Weeks Ago   #19
I think most of your problems are with setting your idle screw and your mixture screw. Set the idle screw to 1 1/2 turns out ( center of carb). Set the mixture screw to 2 1/2 turns out ( closest to the motor). 2 1/2 turns out is just a base setting and you will need to fine tune it. Get it started and let it warm up. Now what you want to do it romp on the throttle to like 3/4 throttle than let go. What your listening to is you want the motor to settle right down smoothly without it hanging on to the rev's or loading up. Now if the mixture screw get lower than 1 1/4 turns out you need a smaller main jet and if it gets higher than 3 turns out you need a bigger main jet.
Once you get the mixture screw set now is a good time to get your clutch adjusted before you start to do your plug chops. Cause without the clutch being properly adjusted it will make it hard to tune the carb. If the clutch isn't working right you may think it's the carb and you will just be spinning you wheels with the problems cause no adjustment to the carb seems to help or change the problems going on.
Old 4 Weeks Ago   #20
Smile Re: dellorto 19mm vs dell rep 19mm comparison
Thanks! Problem solved! I've turned the mix screw ot 2.5 turns, idle screw 1.5 turns out, replaced 50 pilot jet with 40, replaced 110 main jet with 100. The bike now idles at 2000rpm and responds beautifully to throttle input and sounds alive. Figured i can even change the main jet to 98 or even 96 at my altitude, but maybe i should just leave well enough alone!
Page generated in 0.34270 seconds with 75 queries
