Originally Posted by hyzer i think that was me that did that right up :P i ran it without oil (it had grease on the gears just didnt run submerged) and put standard bearings in there to try make it run a bit smoother.
in the end i sold both motors for $200. i just got sick of them. they are seriously not even worth their weight in metal.
a few other guys have converted them to run a standard motor which is HIGHLY what i would recommend.
check the water isnt dribbling out around the base gasket though on the barrel. sometimes it drips down under the pullstart area and you can be mistaken. sometimes an easy fix.
otherwise yeah youll have to rip the motor down and change the seals in there and most likely the bearings if water has been seeping in. get the proper polini shaft and impeller while your at it too.
if you have to do a full rebuild enjoy that. theres at least 8 bearings and 8 seals you have to change :cry: $$$$
or as i said before put a bzm 620 or polini series 2 in there ;p even polini gave up on those things.
they have tons of bottom end and gearing from the factory though. thats how the motor is setup. they just have nothing up top.
cheers |
If I wanted a conventional bike I would have slapped a BZM motor onto my extra GP3 frame. :toung:
If you think about pocket bike racing and the tracks normally used to race on, tight and twisty, youd know bottom end can be more important then top end.
Polini know what they are doing. The one major issue with the reverse motor is parts availability. They wouldnt have put out the motor in the first place if it was crap.
I will do what I can for the last two races of our season, then rebuild the motor during the winter with proper bearings, seals, etc.
