good work, you can increase the reed lift a fair bit like the blata motors aside from that there isnt a huge deal to do.
the browny scale just builds up in there unless its caking up behind the impellor i wouldnt worry.
only the polini reverse parts fit in there. only thing i know thatll go in from bzm is the special reverse 6 port head and gold crank for the reverse.
just better bearings all over and a polini pump + seal kit should see it run okay.
and definitely put the gen polini coil box on! the stock one impedes the revs of the motor even at stock.
other mod you can do is take out the reed stuffers and open the inlet to 19mm instead of the 14mm they come as.
