Originally Posted by jsigone you might want to add weights to ur spare clutch. I wish I done it to mines. But now I have a polini clutch ready to go in there. Gonna add weights to it tonight then back to the track tomorrow  |
where did you get the polini clutch?
what kind of weights did you get - and where did you get them?
can you take pics of them once the clutch has the weights added? pleeeeeeeeease?
FYI - i uploaded a bunch of pics of my blue one and a couple of the "stars/stripes" replica a well in my gallery in case anyone cares!
and as far as using antifreeze - are you going to race? no? then go ahead and use it - as far as mixture - get a cup and mix 50/50 it only takes about 1/8 of a gallon of coolant i think (16 ounces roughly) so if you use 8oz water, use 8oz antifreeze - make sure it is still distilled water - if you plan on racing at a track or even in a "track environment" like the local PB hangout parking lot, i suggest not using the antifreeze mixture for obvious reasons - it is slick it if leaks or boils over thus becoming VERY dangerous!
