Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 11-30-2004   #1
new cylinder head for the c1
Well I finished a new cylinder head for my c1 at work last night. cost about $35.00 to make 15 for the sparkplug tap and 20 for the bar of aluminum (have extra aluminum now). I put the head back on the bike with 1/2 of my base gasket -.030 so now the top of the piston comes up flush with the top of the jug. On the down stroke the side of the piston sits flush with the bottom of the lowest port Pretty much dead nuts where it should have been from the factory! I also gasket matched the jug and the crank case! I have .030 clearance between the piston and the new aluminum head. The dome on the new head is .750 The new head also doesn't have a .060 step on it( I cut a 5 deg angle instead. The depth of the dome is the same .250 though. The old cylinder head insert had .0015 crush on it to keep it sealed( I increased the crush to .003 due to the added compression) All I can say is after putting the engine back together is holy s**t it has a lot of compresstion now. The nice thing is the squish is set perfect and I can't see any way a stock cylinder head could produce this type of compression even if the squish was maxed out and the head was decked! B4 when I cranked the engine over it was like starting my 4 hp lawnmower. Now If feels good and tight. I hope with the new high compression aluminum head, aluminum intake(starts @ 17.5mm and opens to 19mm) and badazz 17mm carb the engine will produce some good HP! 10-12
I have one question though. Any1 try the new badazz fiberglass reeds(they are 3/16 of and inch longer then the stock metal 1's. I think they bind? I need to cut them down? The bike idles good but dies when the throttle is given? If the throttle is worked the bike will get up to 20 mph slow but then take off like a greased monkey! Also the aluminum spacer? I have 1 but do they work? With the larger carb and intake do you still new 1? does blata use them for racing?
I will test out my bike when the weather gets better and let every1 know how my mods do. If I get the gains that I should I will prob start producing aluminum intakes, aluminum heads, and frame sliders.
Sorry for my typing I'm not tarded just a lill slow. I mainly use the computer to look up porn and/or ebay. HaHaHa
Take it easy or any way you can get it
Smuda
smuda is offline   Reply With Quote
Old 11-30-2004   #2
jsigone's Avatar
good stuff, keep us us updated
Old 11-30-2004   #3
Demtoofast's Avatar
Nice stuff! Lead the way my friend. That's some great work there. My guess is that the pull-start will need to be upgraded now! Lol!!!
Demtoofast is offline   Reply With Quote
Old 11-30-2004   #4
a3t
a3t's Avatar
If you start production of the intakes, how much will they cost?
I really like the "blingfactor" on that one
a3t is offline   Reply With Quote
Old 11-30-2004   #5
Juan Luis's Avatar
I want ONEEEEEE
Hello, id like know where can i buy it?, i neeeeeed it more more more compression my hydra is the first, and i need it...Help!!!
and one question, iam spanish and i have a basic level english and i dont understand how to take the measure of the squish, has anybody pictures or can anybody help me using a basic basic basic level? thank you very much
Juan Luis is offline   Reply With Quote
Old 11-30-2004   #6
badazztoyz.com's Avatar
good work aaron.. use your stock reeds to trim the reads a little. we do this cause sometimes they fray on the ends.
Old 12-02-2004   #7
JLsilver02's Avatar
Nice work!
JLsilver02 is offline   Reply With Quote
Review of new Badazztoyz Head Kit BAT-HK Ritchey79 Air Cooled Pocketbikes 58 02-06-2006 05:08 PM
How To set the C1 "Squish" jsigone Water Cooled Pocketbikes 11 09-13-2005 12:17 AM
Four boost port BB head review LONG Dallas L7 Air Cooled Pocketbikes 25 05-24-2005 08:31 PM
New Cylinder head for AC C1 (not cag motor) badazztoyz.com Air Cooled Pocketbikes 2 12-16-2004 06:28 PM
Page generated in 0.22497 seconds with 38 queries
