Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 11-21-2004   #1
Question removing clutch on chinese water cooled bike
Hi,
Im having problems removing the whole clutch assembly of my chinese water cooled bike. Does anyone know an easy way to remove the centre nut on the clutch? as mine is very tight and it doesnt seem it wants to come loose
goodbargins4u is offline   Reply With Quote
Old 11-22-2004   #2
Arjan's Avatar
Exclamation
remove the pull starter side too and use the 14 nut to hold the whole assembly, then the clutch nut will come off sooner than the flywheel nut, i believe they are left and right threaded..
Arjan is offline   Reply With Quote
Old 11-22-2004   #3
jsigone's Avatar
too much work there Arjan
looking at teh clutch, behind it you will see "ribs" from teh case. I always use the top vertical one. Hold a flathead screw driver between the clutch plate (black steel part) and the rib, DO not pry on the clutch shoe cuz that cheap crap might break. This will stop the clutch from rotating when ur loosing the nut off. When putting the nut back on, you will have to use the other side of the rib.
The clone clutch should be lose enought to pull off w/ some channel lock plyers. If u can't, find someone w/ a bling 3 shoe clutch puller.
Old 11-24-2004   #4
thanks for the tips guys but how tight are these ********!!! nuts? Im still having trouble, i swear these ********!! nuts are welded on LOL. I have already broken one socket, i think i better take it to the mechanics to loosen off before i do any more damge to it.
Old 11-24-2004   #5
jsigone's Avatar
they might have some type of china locktite on them, so the first time getting them off might suck. Use some better sockets!
Old 11-24-2004   #6
badazztoyz.com's Avatar
they use glue on them if you can believe that
Old 12-01-2004   #7
hi guys , i had to take the bike to the mechanic to loosen this **** nut off. Guess what? even he couldnt do it and he even rounded of the nut so the only way i could get it off was to angle grind the nut off. It was a difficult task to do and i end up damaging the thread. I am going to try to put a die nut on there and try to clean up the thread and hopefully this will work.
If it doesnt work im not sure what to do, would i have to pull apart the whole motor to get this bolt out and replace it with another? anyone have any good ideas? I think ive really ******* this one up LOL
Old 12-02-2004   #8
Demtoofast's Avatar
I am sorry to say this my friend, but that isn't a bolt it's the end of the crank.
Demtoofast is offline   Reply With Quote
Old 12-02-2004   #9
anyone know if its a hard or difficult job to replace the crank and is it expensive buying another one?
Old 12-02-2004   #10
a3t
a3t's Avatar
Replacing the crank isnt to much of a job if you are a bit handy..
The biggest problem is how to find a crank at all, dont know if the B1 Blatacrank fits.
a3t is offline   Reply With Quote
Old 12-02-2004   #11
gabe's Avatar
am sorry to say this my friend, but that isn't a bolt it's the end of the crank.[
I about feel out my chair.lmao sorry
gabe is offline   Reply With Quote
Old 12-02-2004   #12
I have spit on my monitor from bursting out in laughter....
ccs77 is offline   Reply With Quote
Old 12-02-2004   #13
Geeeez guys thanks a lot LOL, stop laughing at me and give me some help GOD **** IT LOL........Maybe if i lay of the weed and booze i wouldnt ***** things up.
Seriously, i need all the help i can get as i am in big trouble here LOL
Old 12-02-2004   #14
JLsilver02's Avatar
Talk to badazztoyz see if he has the stroker crank ready yet
JLsilver02 is offline   Reply With Quote
Old 12-03-2004   #15
a3t
a3t's Avatar
Regarding these stroker cranks, it is said that the cranks have 3mm longer stroke, but the C1.s has very different squish.s, what will happen if a stock C1 with a squish of 1.0mm is equipped with the stroker crank?
Crash boom bang?
Old 12-03-2004   #16
Crash boom bang?
I'm not sure how it works, but I would assume that the 3mm added stroke is downwards, not up?
Tseland is offline   Reply With Quote
Old 12-03-2004   #17
If it's downward it's also upward. Just add some base gaskets, and make sure you have the clearance on the bottom. Assuming it bolts right in....
Old 12-03-2004   #18
Yeah, sorry I wasn't thinking properly. If it was only downwards the mounting points would have to be lower.
Old 12-05-2004   #19
Well finally i have got the bike running again. I didnt have to replace the crank at all i simply took the motor out and put a die nut at the end of the crank and tapped a new thread. I thought it wasnt going to work at first cause i did a bit of damage to it but i finally got a new thread happening. Then i bought a new high tensile nut so im never going to have problems taking this nut off again.
I cant believe i went through all this trouble to replace a **** clutch LOL, i guess i have to be extra carefull next time LOL.
Old 12-05-2004   #20
triks's Avatar
Question
what clutch you using?
triks is offline   Reply With Quote
chinese water cooled engine kmc_gp Pocketbikes Wanted 0 04-25-2005 05:54 AM
2005 Water cooled pocket bike B1 replica for sale hydroman420 Water Cooled Pocketbikes 56 03-03-2005 07:24 AM
water cooled cag ?? amanthebest Water Cooled Pocketbikes 3 01-20-2005 07:52 PM
Removing clutch on cateyes SSJDemon 2Stroke Midbikes 12 01-20-2005 04:23 AM
Clutch springs slowed bike!! django Air Cooled Pocketbikes 0 01-11-2005 07:00 AM
Page generated in 0.33806 seconds with 75 queries
