Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 01-02-2006   #261
dfelix's Avatar
Re: Tuning a B1 China replica
About the "bore up" talk...
I attached some more images with usefull mesures!
Cylinder could be opened (and coated) to 40mm with no problems.
There is about 10mm of metal to hold the piston...
Like Trevor said, domme as about 1mm for the o-ring...
I think i'll have to buy a Blata orange silicon O-ring soon!
dfelix is offline   Reply With Quote
Old 01-02-2006   #262
You can cut back the lower section of the cases i.e. the part under the bottom reed by at least 10mm and reshape the end profile. This will allow more air/fuel mix to hit the big end and aid cooling the bearing. The top section above the top reed needs to be shaped to allow the air/fuel mix to be directed into the transfer ports without going around a corner.
trevor sellars is offline   Reply With Quote
Old 01-02-2006   #263
Remember dont use a polini 50cc piston the ring keep is in the wrong place, use a bizeta flat top 50cc
Old 01-09-2006   #264
dfelix's Avatar
10mm???
This means that the uper side of the case will loose lots of metal, and the shape!
I will take a picture, some more measures and the post again how it would look after such modification!
I notice that there are different 50cc bizeta flatop piston sizes.
O,OO,A,AA,B,BB
Wich one is best for using with a modified 40mm (nicasil) chinese cylinder?
Old 01-09-2006   #265
cagaroni's Avatar
badazz had some pics here:
http://badazztoyz.com/images/tech/c1/
Old 01-09-2006   #266
Arjan's Avatar
Good stuff guy's!!! time to get my hand's dirty aggain..
Greetz A
Arjan is offline   Reply With Quote
Old 01-09-2006   #267
PBP Administrator
nick's Avatar
hi arjen, good to see you..
Greetz A
nick is offline   Reply With Quote
Old 01-10-2006   #268
look at cagaroni's pictures particularly photo ref: CL-3 WORK .JPEG He's nearly got it right except the length of the lower casing (under the bottom reed) needs cutting back and narrowing in cross section not just thinning out.
The size of piston to use is up to you. Get a piston, give it to the guy who is boring out your barrel and he will match it.
I have no idea of how to upload the photos I have so dfelix give me your E mail address and I'll send some over. perhaps you could upload my pictures of the exhaust ports and case mods. Easier than explaining in text format.
Old 01-10-2006   #269
trevor sellars...can you send that images for me to...i´m a little confuse about the chamber mesarures...i want to put a 40mm piston..but i not certain i can do it...yet!!thanks..
kingstone is offline   Reply With Quote
Old 01-10-2006   #270
Arjan's Avatar
great to be back, my computer crashed and i had a realy hard time getting it fixed aggain.... pffff...... ***ck Bill gates
Old 01-10-2006   #271
Arjan's Avatar
This is how i would do it...the lower green line and the upper blue line...
Old 01-12-2006   #272
badazztoyz.com's Avatar
hey thats my pic
lots more pics there guys to show you the flaws of b1 motor.. Look at the pics i took through inake with head on as well. Im making a head now that will fix it all
Old 01-12-2006   #273
cagaroni's Avatar
are you selling those crankstuffers yet????
Old 01-12-2006   #274
no its expensive work..im getting quotes on new fc stroker cranks that will work on b1 rep and b1
Old 01-12-2006   #275
cagaroni's Avatar
i see you have done many mods & experimentation with the c1/hydra.. would you say you've noticed a nite & day difference in performance between the stock c1 and a modded, matched & de-bugged c1....
Old 01-12-2006   #276
John P's Avatar
word is out Chris is also building a real B1 to see what kind of power he can get out of it.....will be interesting to see if the gains are comparable with the B1 as the C1 ~ So whats the word chris???
John P is offline   Reply With Quote
Old 01-13-2006   #277
weve got 17hp out of a B52 Bored out to 52cc!
Old 01-13-2006   #278
John P's Avatar
LOL...........Trevor that is insane!!!
Old 01-14-2006   #279
dang trevor thats awesome..i wouldnt mind knowing what you did if you wouldnt mind pming me? also john your motor is apart. im trying to find a machine shop to make me some delrin stuffers for the crank cause i dont think my cranks will be done in time for your race season. man your bike was diiirty
Old 01-14-2006   #280
cagaroni's Avatar
badazz, let me know how much one of those stuffers will cost to make if you find somebody....
blata 2.5 to origami b1 replica - yes / no ?? jono400 Water Cooled Pocketbikes 10 08-11-2005 03:42 PM
What Is The HorsePower Of A C1 (B1 Replica), Do some C1's have more HorsePower? pbmod Water Cooled Pocketbikes 16 06-21-2005 12:38 AM
B1 Replica Vs Polini 6.2 Hp 817 ryders Chat 31 05-26-2005 09:59 PM
the best b1 replica? crashburn314 Air Cooled Pocketbikes 10 05-03-2005 07:59 PM
B1 China Replica vs. the Italian B1 Video! PocketPride Water Cooled Pocketbikes 11 12-31-2004 12:09 AM
Page generated in 0.37394 seconds with 77 queries
