Tuning a B1 China replica
ZPF Replica on the way...
ZPF Replica here now
d1 rep
Old 05-25-2009   #441
PBP Administrator
nickj's Avatar
Re: Tuning a B1 China replica
Expect to loose a little Rev's, But the extra power will allow for different gearing to even things out.
The difference between the squish you have now and 0.5mm should be really noticeable.
You can loose the base gasket, which will slide the whole cylinder down and get you closer to the correct squish, Make sure to measure a few different times, preferably measured all the way across the piston and inline with the Wrist Pin.
The only downside to correcting squish via the base gasket is, It will adjust port timing, On 9 out of 10 bikes The difference in timing wont cause any noticeable losses in power or revs.
And yes I'm sure the bearings will hold up as long as they aren't the china style, SKF is a GREAT brand.
Nick.
Originally Posted by jon8489 View Post
will the bearings be able to cope with 16,000 rpm ??
it pulls hard enough bottom end anyway because i can run a real low gearing and use all my revs...my dome has had 0.6 taken off it so the compression ratio is higher than stock... if i go down to .5mm squish what would that do to my high revs ??
nickj is offline   Reply With Quote
Old 05-26-2009   #442
im using chinese bearings haha so maybe i should change them :P what will perform better how it is now or with low squish and higher gearin
jon8489 is offline   Reply With Quote
Old 05-26-2009   #443
PBP Administrator
nickj's Avatar
Look at it like this, Lower squish, will give more power, which will allow you to use taller gearing and have close to the same takeoff speed, So I would say with the right gearing and the lower squish you can keep the takeoff speed and yet be able to have a higher top speed too.
Don't expect a miracle but it really does liven things up a bit.
Nick.
Old 05-26-2009   #444
Pegdrag's Avatar
Let's not forget the importance of the setup on the clutch. The right springs, set to the best length, to engage at the best RPM's to launch, but when racing you only need it once.
Old 05-28-2009   #445
my clutch springs are set to 21.8 and im 14 stone running 6 68 gearing
Old 05-28-2009   #446
Pegdrag's Avatar
Sounds like just the ticket then eh.
Old 06-09-2009   #447
i keep having pistons break
Old 06-09-2009   #448
samspeed's Avatar
Jon you're also running a front tyre on the back which is a different profile and therefore makes your gearing different to normal??
samspeed is offline   Reply With Quote
Old 06-12-2009   #449
woooo good work sam we managed to put my engine together and have a waterleak haha oh well still plenty quick enough to beat the other b1's at the track
Old 4 Weeks Ago   #450
the c1 b1 rep can run with the polini and the factory engines if you take time to tune it and if and when it breaks its a lot cheaper to rebuild i pay close attention to clearances to help it not to seize and well lubed and let it go full throttle
JUST PLAIN FAST RACING is offline   Reply With Quote
Old 4 Days Ago   #451
WOW......What a thread, I just read all 23 pages of it... Will be trying out the reed area porting and setting up my squish on my
B1 rep. I've already match ported it.
Has anyone heard of putting the standard clutches in the oven. I read a thread on another forum saying to put the clutch friction parts into an oven at 180* C for 45 min let them cool and do it again for 45 min. It's supposed to make them last far more than twice as long.
ringo.e is offline   Reply With Quote
Old 3 Days Ago   #452
jmac01's Avatar
I think its meant to make sure that the glue has cured properly mate. Supposed to make the shoes less likely to rip off in the first couple of runs. Never tried it myself. I usually replace the circlips with proper ones tho. Proper euro springs are a good idea too. Most of the china springs start to go soft after a few runs.
jmac01 is offline   Reply With Quote
Old 3 Days Ago   #453
StrayDawg63's Avatar
I break-in my clutches in a little toaster oven. I start at 150 degrees for 10 min let it cool down.Than 250 degrees for 10 min let it cool down. Than 350 degrees for 10 min. Just turn the oven up when you pull the clutch out to cool down to pre heat for the next step. Havn't delaminated a clutch since but than again it's usally the first clutch when your first learning how to adjust them that gets messed up.
Old 3 Days Ago   #454
On my B1 rep I found a good starting point due to the springs having a mind of their own, to do the adjustment screws up to touch and then one whole turn in.
Old 1 Day Ago   #455
jmac01's Avatar
A good starting point is to set your springs to 21.5 mm and go from there.
« More Traction | - »
blata 2.5 to origami b1 replica - yes / no ?? jono400 Water Cooled Pocketbikes 10 08-11-2005 03:42 PM
What Is The HorsePower Of A C1 (B1 Replica), Do some C1's have more HorsePower? pbmod Water Cooled Pocketbikes 16 06-21-2005 12:38 AM
B1 Replica Vs Polini 6.2 Hp 817 ryders Chat 31 05-26-2005 09:59 PM
the best b1 replica? crashburn314 Air Cooled Pocketbikes 10 05-03-2005 07:59 PM
B1 China Replica vs. the Italian B1 Video! PocketPride Water Cooled Pocketbikes 11 12-31-2004 12:09 AM
Page generated in 0.28240 seconds with 62 queries
