Originally Posted by Arjan In the 4 valve read can you put 1 side the 0.3 Carbon ones and the other side 0.5 ones? for better performance overall...? like a 2 stage read..?
Or.. will it mess up the bike...?
Just wondering....  |
thats funny you mentioned that. last week i was thinking the same thing. I used both on my Gem. the result was what I expected. i had great acceleration through out the whole rpms.I'll know more when i take it to the track tomorrow.
yesterday i decided to work on my c1. it never ran right from the beginning. but now it runs like a champ. what i did was shave off 1.2mm of the top of the barrel from 57.2mm to 56mm from top to bottom. then used the old head gasket. there was 2 stuck together. one was 1mm thick and the other .5mm thick. i ended up using the .5mm and a light film of copper gasket maker.
while i had the head out i cleaned up the water jackets. one side of the water jacket was totally clogged up so i drilled it out and hit it with a dremel.
also the ports were so mismatched, i ended up match porting all the intake ports. the gaskets were overhanging so i trimmed them back too.
i got the head back on and the squish is set to .65 right now and i can go lower by using a thinner hg gasket now. (.4mm gasket would bring it down to .55mm) I also switched out the plug to a NGK B9EGV racing plug.
next i swapped out my carb with a dellorto 14 with a 72 jet.
i already put a polini clutch in there with a blata drum and 7t polini pinion.
the results are great.it use to have a huge lag in acceleration from low compression but thats all gone. the jetting problems are all fixed with del carb and jets. the clutch problems fixed and so far no cooling isuues. it revs like a mo fo. compare to my real B1 it comes close but i think to get it to its full potential it would need a stuff race crank, new bearings,seals, match port the case to barrel, a 17.5 or 19mm carb,reed spacer and a new race pipe.
next i'll be figuring out how to get this bike to handle better. i have a damper, i just need to weld a tab on the frame. i want to redesign the swing arm to be adjustable.
JSIGONE thats wher i need your help with that program.i'll give you a buzz and you can fix that barrel tonight and grab that jet.
