turbo is not an option. here is why.
In a 2 cycle motor, the intake and exhaust ports are open simultaneously, meaning no boost can really me made in the cylinder by a 'turbo'. If it was a flathead 4stroke, then no problem. A tuned pipe has a supercharging effect on a 2stroke as the sonic pulse pushes premix back in the cylinder right before it closes and is combusted. hence, getting on the pipe is where the power is at. A turbo would just blow premix out of the motor, unless of course you had poppet-style exhaust valves etc... Hope that helps.
then explain all the turbo 2 stroke Banshees and snowmobiles, it can be done, no one currently makes a turbo small enough for this motor that I know of. there are rumors of turbos for 50-70cc mopeds coming out, maybe that will become a possibility
they don't use reeds, they use powervalves, that is how they put a turbo on it.
you need a way to keep the boost in the cylinder, reeds are not strong enough to do this
rdt you can stick that Greddy T88H-34 up ya *** and crank the boost up to 100 lbs an I must also add tblumer that horse in the background is ya mama screaming from the horse d*** she's taking.
