Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Air Cooled Pocketbikes
Forum Home Register FAQ Members List Calendar Today's Posts Mark Forums Read About Us
Pocketbike Pictures Member Map PBP Arcade Mark Forums Read
Pocketbike Forum
Top 10 Threads
CAG,CAG,CAG and Oh Yeah CAG! :The Projects Cometh UP
Post up pics of your Cag...
Stock pipe mod
Boost Bottle?
39 & 47cc CAG FAQ <-- READ TO AVOID PROBLEMS!
NOS on my bike
Whats the fastest your bike ever went?
A "Racing Engine" Built
The Rat - SpyGuy's Redneck-Style Cagllari/Daytona
Added a boost port tonight *pics*
View Poll Results: Boost Bottles
Good 176 73.03%
Bad 69 28.63%
Multiple Choice Poll. Voters: 241. You may not vote on this poll
Old 12-06-2011
EPR's Avatar
EPR EPR is offline
Outlaw
Re: Boost Bottle?
On all three of my Cags, I can see fuel and air moving in the tube, from the back flow out of the reeds from the cases.
  #322
Old 03-04-2012
jaloos's Avatar
jaloos jaloos is offline
GHETTO FABRICATOR
Re: Boost Bottle?
Someone ran a tube on the back top of the carb.
That was me
  #323
Old 03-04-2012
KingRice~ KingRice~ is offline
Re: Boost Bottle?
I've got a boost bottle that I ordered off eBay, made by Doppler Air Company but its a big one which I guess was for 125-150cc or so bikes. They guy had it on his RG125.
Oh here it is http://www.adrenalin-pedstop.co.uk/p...amber-617.aspx
Fitment lists a bunch of 50cc bikes though, hmm, I might stick it on and see how it is.
  #324
Old 03-04-2012
jaloos's Avatar
GHETTO FABRICATOR
Re: Boost Bottle?
Give it a shot. If it works great if not nothing lost.
  #325
Old 06-14-2012
EPR's Avatar
EPR EPR is offline
Outlaw
Re: Boost Bottle?
It gives you a whole list of 50cc 2 stroke engines that it will work with, so it must be the right size.
  #326
Old 06-14-2012
125ccCRazy's Avatar
125ccCRazy 125ccCRazy is offline
Re: Boost Bottle?
the volume of the bottle should be the same CC as the engine.... if you have a 50cc then your bottle should be 50cc to work properly...if the bottle is too big it wont pressurize properly lowering the discharge pressure ultimately lowering the performance effect.. Think about it like this... You have a small balloon and a large balloon...take one breath and blow into the large one and release the air, then the same for the small one... which one filled up more and had greater pressure when released?
  #327
Old 07-21-2012
tommyrider tommyrider is offline
Re: Boost Bottle?
How would this work in the first place?
  #328
Old 07-22-2012
EPR's Avatar
EPR EPR is offline
Outlaw
Re: Boost Bottle?
The cases keep pressure inside, when the piston goes up it pulls the reeds open and drawns air thru the carb, which drawns gas up the main jet tube and into the carb. That is sucked up the intake ports that could be 2 to 5 on an air cooled cag engine. When the piston starts down the reeds shut, but before they do, alittle air and gas spit out, and some of it stays in the boost tube and bottle. When the reeds open again and draw air, it also bring pre-mixed fuel into the engine.
  #329
Old 12-13-2012
angrychild1997 angrychild1997 is offline
Re: Boost Bottle?
so to get this right the boost bottle should be the same size or a little bigger right? it cant be smaller, for example i have an x2 with the stock 49cc engine if i get a 2oz bottle and connected it would it be to big or would it do something?? if am not wrong i think 2oz is 59cc.
  #330
Old 12-13-2012
EPR's Avatar
EPR EPR is offline
Outlaw
Re: Boost Bottle?
If it is 59cc that's close enough, they count the tubing area also,lol.
  #331
Old 12-14-2012
Jesus7Clark Jesus7Clark is offline
Re: Boost bottle
the Mod works better if the bottle is higher than the intake
  #332
Old 12-14-2012
Re: Boost Bottle?
But should i go with the 2oz bottle , have u guys tried a 2oz bottle before?
  #333
Old 12-14-2012
EPR's Avatar
EPR EPR is offline
Outlaw
Re: Boost Bottle?
Just try it and see, I hold back the bike with my feet & crank my engines up before I take off, warms up the clutches, and fills up your boost bottle.
When your reeds open the air going thru the carb & manifold draw pre-mixed air and fuel the bottle to help with lag of the air having to travel from the from the front of the carb inside the cses and past the crank and up the ports. Thats why a smooth path and more ports allows the engine to breath better and w/ a tuned exhaust, it will give you more RPMs.
  #334
Old 03-16-2013
Mo3rro52w Mo3rro52w is offline
Re: Boost bottle
  #335
Old 03-16-2013
MathieuOuellette's Avatar
MathieuOuellette MathieuOuellette is offline
French Fries N Cheese
Re: Boost Bottle?
I've been looking into doing this with a rifle cartrige. I have some different sizes of nickel plated cartriges. The .308 looks to be a little small. I am going to try between a 7.62mm cratrige and a .300 mag cartrige. probably going to have to ad some extra hose to compensate for a little bit of volume.
I found a cable barb that is eactly the right size to thread into a 30 cal cartridge of any kind.
Going to find the volume of the cartridge that way I can possibly figure out how much and what diameter hose I will need?
I dont suppose anyone has tried this before?
Edit: .300 cartridge is about 12cc, much too small I guess.
  #336
Old 04-08-2013
Aspire2b's Avatar
Aspire2b Aspire2b is online now
O.G. Racing
Re: Boost Bottle?
got a question not sure how or where to post it so Im just going to dive in... I picked up an x7 r5 replica and the break levers are tired and dead so I was thinking of using so high end mtb break levers but here is the snag...the safety sensor in the rear break to start via electric starter. What do I do about that little guy? I was thinking of putting it in some sort of vallet box and strapping it out of the way somwhere behind my fairing. Any thoughts? hook a brother up
  #337
Old 04-09-2013
125ccCRazy's Avatar
Re: Boost Bottle?
you can get a push button micro switch from Radio Shack and hide it under the seat, tank ect...
You may not post replies
Forum Jump
Similar Threads
Thread Thread Starter Pocketbike Forums Replies Last Post
Boost bottle materials Supa Dexta Air Cooled Pocketbikes 6 08-15-2005 09:23 PM
Home made boost bottle review!!! u sucker just got served 2Stroke Midbikes 22 07-16-2005 02:14 PM
boost bottle test smn1 2Stroke Midbikes 10 07-06-2005 01:30 AM
boost pressure gauge for a boost bottle? u sucker just got served 2Stroke Midbikes 22 06-25-2005 12:17 PM
Powered by vBulletin
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2006 - 2012 Pocket Bike Forums | About Pocket Bike Forums | Advertisers | Investors | Legal | A member of the Crowdgather Forum Community
Style design by Leo
