Re: gp3 rebilt but wont start help
A tip on starting that thing, if it has the foam air filter still. squish the air filter with you hand when you pull it, it will fire right up. The large carb opening makes it a beast to start, but blocking all air flow on the first couple pulls will bring in more gas and then once you remove your hand it will start. If it doesn't have the foam air filter, figure out a way to block the air flow for the first couple of pulls. Mine usually starts on one pull when i do this.
