PRODUCT REVIEW: Badazztoyz' new 2-stage fiberglass reed >>> - Pocket Bike Forum - Mini Bikes
Post up pics of your Cag...
Stock pipe mod
A "Racing Engine" Built
Boost Bottle?
NOS on my bike
Old 02-10-2005
TYSTYX's Avatar
TYSTYX TYSTYX is offline
Here is a review that I promised Badazz back in November, but a re-broken collarbone had sidelined me for a awhile:
The new Badazztoyz reed:
This reed is a two-stage reed. It consists of a single .7mm piece of fiberglass with a hole cut out in the middle.
On top of this lays a .3mm piece of fiberglass. The way this reed works is that at low throttle openings the incoming
fuel/air mixture blows through the hole in the .7mm reed, thus allowing the .3mm reed to open.
At higher throttle openings the .7mm reed starts to open. The theory behind all this is that you will have an increase in
top end power, with no loss of low end power.
Installation notes:
Because this reed is designed like a single-petal reed, it requires that you cut the center bar out of your reed cage for the
reed to work properly. This can be done several ways, but a Dremel tool with a carbide tip did the job for me and it only took
a few minutes. Also, the new reeds are too big and have to be cut down. I clamped them in a pair of vice grips with my
carbon fiber reeds and sanded the 2-stage reed to the exact shape of the carbon fiber reeds. ( see photo )Make sure you sand the edges of the hole too because the edges are a little frail looking from being cut out.
The new reed goes on like this: Put the .7mm w/ the hole in it onto the reed cage, and then put the .3mm reed on top of that. I used my stock reedstops. At first I had a gap between the reeds and the reed gasket, I tried bending the reeds a bit ( notice the slight crack in one of the pics), and I even tried shimming the new reed with a piece of my old metal stock reeds and I still had the gap. I was about to admit defeat, but then I bolted the reed on again without the shim, and it sealed up perfectly. Make sure you locktite the screws. So far, so good.
My cag specs:
I ride a Lucky 7 with a 4-port ZH-1 jug using only one piston ring (top), no base gasket, stock pipe, 1.4 clutch springs,
carbon fiber reeds, ported reedcage, 3mm reedblock spacer, ported stock carb, ported V-stack,
air filter, adjustable main jet ( w / no adjuster ), triple taper needle, and stock gearing. I mix my gas at 40:1
using 91-92 octane. The 2-stroke oil I currently use is Mobil 1 MX-2T full synthetic. My spark plug is an NGK BM7A, gapped at .26. With gear on I weigh 220lbs.
I ride with my brother who rides a completely stock Lucky 7 bike. He weighs 30 lbs. less than I do.
From a dead start, his stock cag will jump out about 30 feet in front of mine, our midrange power seems to be about even,
then my cag comes alive and I catch him and pass him easily. Out of turns his bike will outpull mine, and the only way I can catch him is if there is a good long straight. I have absolutley NO bottom end, even with the reed block spacer so lets see what this new 2-stage reed will do for my cag.
The Test results :
For the test I decided NOT to use the reedblock spacer. I started with my triple taper needle in the fifth ( bottom ) position. I drag raced my brother a few times and now I am able to stay with him off the line. Once we hit mid-range, my bike took off and left him behind. My top end still seemed the same as when I had my carbonfiber reeds in. I messed with the clip position on the carb needle, but I ended back on the fifth position. My bike didnt seem to need any jetting changes. I also didnt have any flat spots anywhere in my powerband, and no reed flutter was noticable at WOT. Next I tried using the 3mm reedblock spacer, which killed a little bit of top-end, and didnt really improve the bottom at all, so I ditched the spacer.
Conclusion:
For me, the new 2-stage reed works. It let me keep my low end power, and added as much top end over the stock metal reeds as the carbon fiber reeds do. It might work better on a modified cag like mine, rather than a stock cag. All these china bikes are different. What works on one, might not be so hot on another. Its all a matter of trial and error and tuning and a little luck. The best way to find out if it works for you is to buy it and try it for yourself.
Next, Im gonna go back to my 1.3 clutch springs and see what difference they make, then I'll try the 1.5's. Actually, my L7 could desperatly use a performance pipe, but since Im riding my new Sendai Tai Chi now, I might just leave my L7 the way it is.
  #2
Old 02-10-2005
SilentX1's Avatar
SilentX1 SilentX1 is offline
very nice!
  #3
Old 02-10-2005
Dallas L7 Dallas L7 is offline
VERY nice review. I too wanted some of my low back after going to the CF reed. The CF top end is KILLER but it does kill your low end. This review would have made me try the dual stage reed but i already got the four petal setup waiting to be installed.
  #4
Old 02-10-2005
badazztoyz.com's Avatar
badazztoyz.com badazztoyz.com is offline
Thanks for the review dude.. email me some pics of your tai chi reed block and maybe my upgraded hydra reed block and dual stage reeds will work on it
  #5
Old 03-02-2005
bradsdad bradsdad is offline
Junior Member
the reeds for the hydra do work on the tai chi(thanks chris)i put the two stage reeds & the 17mm carb on my tai chi and it pulls the hydra (stock)with out any problems,the reeds did need a little mods to fit but what a diffrence.by the way chris this is Ben in napa(j&b's mini moto)we thank you for the help finding porformance parts for the tai chi.
  #6
Old 05-16-2005
cbtlr's Avatar
cbtlr cbtlr is offline
Council Member
Thumbs up
Installation notes:
My Cag specs:
I ride a lucky 7 with a 4-port ZH-1 jug using only one piston ring (top), no base gasket, stock pipe, 1.4 clutch springs,
I ride with my brother who rides a completely stock lucky 7 bike. He weighs 30 lbs. less than I do.
From a dead start, his stock Cag will jump out about 30 feet in front of mine, our midrange power seems to be about even,
then my Cag comes alive and I catch him and pass him easily. Out of turns his bike will outpull mine, and the only way I can catch him is if there is a good long straight. I have absolutley NO bottom end, even with the reed block spacer so lets see what this new 2-stage reed will do for my cag.
The Test results :
Conclusion:
For me, the new 2-stage reed works. It let me keep my low end power, and added as much top end over the stock metal reeds as the carbon fiber reeds do. It might work better on a modified Cag like mine, rather than a stock cag. All these china bikes are different. What works on one, might not be so hot on another. Its all a matter of trial and error and tuning and a little luck. The best way to find out if it works for you is to buy it and try it for yourself.
That was great info.
You may not post replies
Forum Jump
Similar Threads
REVIEW: Billet 4 Petal Reed Setup and billet intake manifold from DDM... jman47cc Air Cooled Pocketbikes 9 08-31-2005 10:56 PM
BadAzzToyz 4 Petal Read Kit Review Ritchey79 Air Cooled Pocketbikes 20 06-14-2005 11:20 AM
The Dual Stage Reed Review sikksikksikk Air Cooled Pocketbikes 2 01-04-2005 09:30 PM
Dual stage reed review today and tomorow sikksikksikk Air Cooled Pocketbikes 42 12-22-2004 01:15 AM
ADA Reed Kit Review snowboardgeek1 Pocketbike / Mini bike Reviews 0 12-21-2004 09:15 PM
Powered by vBulletin
