Transpond a chainsaw engine to a Cag? - Pocket Bike Forum - Mini Bikes
Post up pics of your Cag...
Stock pipe mod
A "Racing Engine" Built
Boost Bottle?
NOS on my bike
Old 04-02-2005
tuningmann's Avatar
tuningmann tuningmann is offline
Cag engines is well known for their vibrations and lack of performance. Today, my neighbour use his chainsaw and I must say what a reving it has! It was an Partner 49cc and I had a close look at the saw, and must say those engines performs good. No vibs and plenty of reving potential and seemed to look alike the Cag engine.
Now, I had an idea of put a similar engine in my Cag but before I begin I must ask you guys if anyone allready had tryed this out? Oh, I forgot. They are availble in 71cc as well.
  #2
Old 04-02-2005
gmenge's Avatar
gmenge gmenge is offline
How about a chainsaw motorcycle? Can you imagine having to start this.
  #3
Old 04-02-2005
cabey74's Avatar
cabey74 cabey74 is offline
Could you imagine tuning the carbs on it
  #4
Old 04-02-2005
gurt's Avatar
gurt gurt is offline
ha i thought about that before...just imagine having a husquavarna pocket bike
  #5
Old 04-02-2005
badazztoyz.com's Avatar
badazztoyz.com badazztoyz.com is offline
you can really reduce vibes by supporting your motor and using lots of rubber washers
  #6
Old 04-02-2005
pope_blah_the_1st's Avatar
pope_blah_the_1st pope_blah_the_1st is offline
Junior Member
Ok, I siad this to my motor "you can do it, you're great, you're the best" is that enough support? I wasn't sure how i should use the rubber washers? so i got some big ones and squeezed them them all the way up my fingers, that works great, i can't feel any vibrations, matter of fact i can't feel anything, why are the ends of my fingers purple?
  #7
Old 04-02-2005
borednstroked borednstroked is offline
Oh...I put the washer somewhere else and it got real hard and turned purple.
  #8
Old 04-03-2005
all motor cag racer's Avatar
all motor cag racer all motor cag racer is offline
Senior Member
ive seen someone do this before. this guy stuck a 9 hp chainsaw motor on a little tricycle. that **** was the bomb off the line. iono how he did it.
i dont suggest sticking a chainsaw motor in a cag unless u go over the welds a little better.
just what i think.
  #9
Old 04-03-2005
Norman Bates's Avatar
Norman Bates Norman Bates is offline
Member
A chainsaw engine will also vibrate if it's mounted poorly like the cags are.
A few things you have to consider before you destroy a good chainsaw:
Chainsaws run a different pitch chain and they usually have it on the opposite side to a cag, you will need a custom sprocket and you may have to mount your rear brake and disk on the other side of your frame, that requires welding the frame.
The pull starter, may not be accessable when the engine is mounted, you may have to mcgyver up some pully setup to start it? The chainsaws exhaust may burn your leg, you may have to put an elbow on it or make a new pipe, then there's the chainsaws chain lube and engine autolube system, you may need to take all that off to fit the engine in the frame, but most of them are cast onto the crankcase, that may mean you may have to chop the chainsaw engine up to make it fit. I'm not saying it can't be done, just there would be a lot of work, hate to see it end up in the unfinished projects box. Wouldn't it be easier to fix the cag engine mount so it vibrates less and just do a few performance mods on it?
  #10
Old 04-04-2005
Senior Member
he has a good point. i would never try this because i know almost zip about motors and fabrication. although if i did id go for it.
You may not post replies
Forum Jump
Similar Threads
How-To's - Cag performance tips and tricks snowboardgeek1 Air Cooled Pocketbike How-To's 5 06-18-2013 05:27 PM
Engine Mount Modification snowboardgeek1 Air Cooled Pocketbikes 29 04-11-2011 01:06 AM
Where do we go from here???? kneedragger OMRRA 117 08-28-2005 02:13 AM
Putting a Pollini Engine In a Cag :-) pocket1bike Air Cooled Pocketbikes 26 10-28-2004 12:44 AM
How To: Engine Mount Modification snowboardgeek1 Air Cooled Pocketbike How-To's 0 09-23-2004 08:59 AM
Powered by vBulletin
