Re: best pocket bike under 300$- im new help
The Lucky 7 has a stronger frame, a little better quality engine, and everything else is of better quality. The fact is, that Cag even with the pipe and everything isn't worth what you're paying. The pipe MIGHT add 1 mph, the filter, maybe .5 miles, and everything else is pretty pointless.
for $189 NEW you can get the Lucky 7 from a respectable company that will not screw you over. Then go to Pocketracing.net and buy a good pipe. This will help you. When you buy packages like, that, it doesn't help you at all. A Jet Pro pipe will add 4-7mph.
It's your choice, not ours. But when everyone is saying that the Lucky 7 is better, dont you think you should take our advice? I have a cag, and yeah, it works, but i've also put 20 hours worth of time and labor into getting it running as best i can.
-TC
