Leaf Blower - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Midbikes / Superbikes > 2Stroke Midbikes
Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
NEED Pocket bike 49cc engine diagram
a-nuter motor swap
Put down your top speed
Stop the confusion! - MidBike names and PICS -
Who Says You Cant Turbo A 2 Troke?
Video
Need help Tuning 49cc Carb
Old 04-25-2006
kevin_king kevin_king is offline
Leaf Blower
ok, i know this is a pocket bike forum but i have a question about a leaf blower engine and i know you gise know alot about engines so answer please. ok, i had the leaf blower for only like 3 days and all of a sudden it would never start and it started perfectly before. whats the problem?
*please dont delete forum*
  #2
Old 04-25-2006
Backwoodz Backwoodz is offline
Re: Leaf Blower
ya ran out of gas..........................
  #3
Old 04-25-2006
Re: Leaf Blower
i have gas.
  #4
Old 04-25-2006
wtpbmx2003 wtpbmx2003 is offline
Junior Member
Re: Leaf Blower
are you using the choke?
  #5
Old 04-25-2006
Re: Leaf Blower
yep..help me
  #6
Old 04-25-2006
Junior Member
Re: Leaf Blower
maybe theres something wrong with your pull start. does the spark plug have a spark?
  #7
Old 04-26-2006
125ccCRazy's Avatar
125ccCRazy 125ccCRazy is offline
Re: Leaf Blower
Well the therory is that if it has gas and spark it will run or at least start unless there is something mechanically wrong like a hole in the piston, broken key in the flywheel ect....check for spark, could be a fouled plug, if it has good blue spark try pouring an ounce of fuel in the carb, possibly the diaphram in the carb is bad..If those check out do a compression test, the piston may have a hole in it or the rings broke....This problem will be a process of elimintation..
  #8
Old 04-26-2006
puppetmaster's Avatar
puppetmaster puppetmaster is offline
Re: Leaf Blower
well what i do when all else fails is put in on ground say a few profantities at it and start to kick it untill it starts..lol...
no seriously did you break the engine in properly. it usually says in the manual to use a certain mixture ratio for break in period and then change the ratio. most likely the piston is fried. take it back and get a new one. hope this helped.
  #9
Old 04-26-2006
Re: Leaf Blower
yes i did all of that and how do i test the spark plug?
  #10
Old 04-26-2006
photo photo is offline
Re: Leaf Blower
sounds like a craftsman leafblower had the same problem with mine never could figure it out now i have a stihl and it works great
  #11
Old 04-26-2006
Re: Leaf Blower
i use the choke, the spark plug works. im not sure why it doesnt..
  #12
Old 04-27-2006
Re: Leaf Blower
yes i am usin the choke and my spark plug works.
  #13
Old 05-02-2006
ScooterJunkie ScooterJunkie is offline
Senior Member
Re: Leaf Blower
hmmmm.well r u sure dat u got da rite mix? I work on Mowers weedeaters.etc. my blower had da same problem and it needed an idle ajustment.
Hope this helps
  #14
Old 05-04-2006
FatalError's Avatar
FatalError FatalError is offline
Re: Leaf Blower
Why not just take it back in the first place? I couldn't see anyone arguing with you over it at the counter. Or is this a garage sale item? =)
  #15
Old 05-04-2006
Re: Leaf Blower
i threw it and broke the plastic a bit when it wouldent start. lol
  #16
Old 05-04-2006
FatalError's Avatar
Re: Leaf Blower
Oh, well you still might as well take it back. Just tell them it came that way, just like the rest of the lying public does. People used to bring me back dead fish when i worked at petsmart years ago, & try and tell me they came like that. Although im pretty sure i'd never bag up a dead fish for someone, But you'd be surprised what you can get away with as a consumer/customer. Not really any help, but still a messed up story. =)
  #17
Old 05-04-2006
Re: Leaf Blower
hahaha.. you seem smart.. go to my thread in 2-stroke mid-bikes (i think you already are if you looking at this) and look at my thred on weird noises and please help me.
  #18
Old 07-15-2006
derek920 derek920 is offline
Junior Member
Re: Leaf Blower
I think i might know what your problem is you have to plug it in to an outlet because cause you bot an electric one you got to plug it in man that will solve all your problems.
  #19
Old 07-15-2006
Lastshot Lastshot is offline
Re: Leaf Blower
I'm pretty sure there isn't a leafblower that is both gas and electric, and if so I have never heard of it. And he stated earlier that it was gas, so plugging it in won't help. so I would ignore that response.
  #20
Old 07-15-2006
Mblough's Avatar
Mblough Mblough is offline
Re: Leaf Blower
guys look at the dates on the posts before you yourself make a post. posting on this one was on the brink of grave digging (dead thread revival).
this thread is like a month and a half old. im sure by now the poster eiterh figured it out, sold it, or gave up.
You may not post replies
Forum Jump
Similar Threads
cheap and easy turbo ABCDEF G-unit Air Cooled Pocketbikes 21 12-31-2005 09:45 PM
X 12 mods jamesdem1123 4Stroke Midbikes 6 06-05-2005 07:55 PM
Powered by vBulletin
