Adding an extra battery to stock razor - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Electric Pocketbikes
6000W Cag conversion
MX650 mods?
A new drag bike
pr200 razor-mod
electric pocketbikes are horrible!!!!!!
Xp-700
Razor MX350 Help - Charged but goes 2mph
help with razor pr200 set-up
Converting Razor pocket rocket from electric to gas
honda Mini moto 18 volt speed control bypass
Old 07-24-2006
pinoymoomoo pinoymoomoo is offline
Junior Member
hi,
i just picked up a razor scooter the other day without a charger and what i think is a dead battery. I was wondering if it would be safe to add a third or 4th battery to the stock setup. my goal for right now is to increase the riding time. If adding a third or fourth battery does increase the ride time, would the ride length increase alot? also would i need to modify the wiring to the controller?
Thanks,
Andrew
  #2
Old 07-24-2006
werker011's Avatar
werker011 werker011 is offline
Re: Adding an extra battery to stock razor
you can't just add an extra battery,you must also upgrade the controller.if you just want too increase your riding time you can just buy another battery with more mah with same volt's.this way you can still keep the stock controller.what kind of battery is on the bike now and how many watt's is your motor?
  #3
Old 07-24-2006
Junior Member
not sure on the specs of the bike because i didnt get a manual or anything. since i already have 4 batteries and i found out how to fit all four of them nicely, could i just wire the batteries in series parallel which would result in 24v? would thise double the mAH? what i am still stumped about is how to connect the four batteries to the controller. would having more batteries increase the charging time? if so, what can i buy to decrease the charging time.
Thanks,
Andrew
  #4
Old 07-24-2006
Kool-aid's Avatar
Kool-aid Kool-aid is offline
Exclamation Re: Adding an extra battery to stock razor
ive added a third battery for mine and it works but you gotta have a 36 V Charger Anymore batteries will blow Something.......... BTW i Hit 25.4 MPH Today With 3 Battieries And A Stock Controller oh yeah and for some reason when you charge the batteries the third on makes a sizling Does That Mean I need A Razor Mx-500 Controller ? Or What ?
  #5
Old 07-24-2006
werker011's Avatar
there are two version's of the bike,one is a razor 24v and a honda minimoto which is 18v.let's say you have 2 12v 7ah batteries now connect the wire's(+)positive to (-)negative,this will increase the volts too 24v 7ah.if you connect the (+)positive too (+)positive and (-) too (-) it will increase the mah too 12v 14ah.
the controller only needs one postive and one negative wire from the batteries.
what kind of batteries do you have?
  #6
Old 07-24-2006
werker011's Avatar
what batteries are you using?are they the same volt's and mah.
  #7
Old 07-24-2006
Kool-aid's Avatar
Yeah Three 12 V 7Ah Batteries
  #8
Old 07-24-2006
werker011's Avatar
so your using the stock 24v controller with a 36v system.i tried upgrading my son's bike from 18v too 24v and it did'nt work.just keep a close eye on your controller if you are.
using a volt meter check all 3 batt's when fullycharged.check one battery at a time too see what volt's they have.would be best if all 3 batts show near the same volt's.
  #9
Old 07-24-2006
Kool-aid's Avatar
Red face Re: Adding an extra battery to stock razor
thats correct but even if i blow that controller i have i Mx-500 Controller come-ing in on Wed. but that controller is going strong (No Problems) but i have another in the gaurage 250 Watt motor 36 V With a stock controller and that thing is fast must go atleast 30 MPH (Dont Know the exact number Dont Have A Speedometer on that one)
  #10
Old 07-24-2006
Junior Member
so is it safe to wire four batteries in series parallel resulting in 24v 14AH? i purchased the batteries from frys. where do you guys mount your batteries? my third battery is mounted under the rear fender and the fourth is mounted where a gas tank would normally go. the 4th battery lifted the cover alittle so i had to put two spacers in the midle. i think i may be able to squeeze another battery where the two stock batteries are.
Andrew
  #11
Old 07-24-2006
aproldan's Avatar
aproldan aproldan is offline
Andrew
pinoy, no that is not correct...if you wire 4 batteries in series you will end up with 48volt...... what you need to do is this... fisrt 2 batteries wire up in series, then put it aside..... the wire up the other 2 batteries in series...... now wire both sets in series..now you wil have a longer riding time with the same speed you had before,,,,,,
  #12
Old 07-24-2006
Junior Member
i was saying wiring the battery in series-parallel (Shown in picture) doing this would end up with 24volts but having 14aH because:
Wiring in Series will incease the voltage.
And
Wiring in Parallel will incease aH but not the voltage.
My batteries are rated 12v 7aH. Wiring in series/parallel will result in 24v 14ah. would 24v 7aH still be safe for the stock motor and controller? one other question i have is; is it safe to wire differt aH batteries together? for example two 12v 12aH batteries and 2 12v 7aH batteries? Where can i find a faster charger?
Here is a pic of a series/parallel wiring diagram
Thanks,
Andrew
  #13
Old 07-24-2006
Junior Member
decided to go ahead and give it a try, so i wired them all up in series/parallel and hooked up the dmm to the plug. read ~24v. now to order a new charger. im assuming since i have two more batteries, it will take much much longer to charge. any suggestions on what kind of charger i should get? should i just get one off of ebay?
Thanks,
Andrew
  #14
Old 07-25-2006
werker011's Avatar
it's not a good idea to mix the batteries mah,12ah-7ah etc.i'll pm about the charger.
  #15
Old 07-25-2006
werker011's Avatar
you should get a speedo to see the difference between your stock controller and the mx500.
  #16
Old 07-26-2006
Kool-aid's Avatar
got the mx-500 controller in today popped that sucker in and re-wired Neons,Stobe Lights And battiery Put 250 Watt Motor And Rode That Sucka(Couldnt believe The diff.)
Hit 32.4 MPH
  #17
Old 07-26-2006
dommaster23 dommaster23 is offline
Junior Member
Dang thats FAST LOL. I think i might just get the razor after all.
  #18
Old 07-26-2006
Kool-aid's Avatar
Yeah and it feels even faster than that but it dint come like that i had to add a battiery change the controler upgrade the sprocket upgrade the motor not to even think about Strobe lights neon lights speedometer Alot of hard work but dang on dont it pay Off ?
  #19
Old 07-26-2006
DaveTheRave's Avatar
DaveTheRave DaveTheRave is offline
Hit 32.4 MPH
Wowza, And Your Motor Didn't Burn Out? We Tried Projects Like This, And Our 350's Keep Frying When We Tried To Push Them To 30 MPH, Heck, It Wouldn't Even Go Past 25! D:
  #20
Old 07-27-2006
Kool-aid's Avatar
it will go 25 MPH straight up A Hill i got the motor off of a electric Scooter on the back it says 250 Watts but who knows but it hasnt blew yet heres a pic of the sticker that was on the motor-
pic-
You may not post replies
Forum Jump
Similar Threads
adding sipes to the c1 stock tires. Indsk8 Water Cooled Pocketbikes 12 04-21-2006 03:38 PM
Where do we go from here???? kneedragger OMRRA 117 08-28-2005 03:13 AM
800 watt razor 800wattrazor Electric Pocketbikes 15 03-22-2005 11:12 PM
ADA Reed Kit Review snowboardgeek1 Pocketbike / Mini bike Reviews 0 12-21-2004 09:15 PM
Anyone have a extra stock petcock? motod0od Air Cooled Pocketbikes 9 12-19-2004 09:53 PM
Powered by vBulletin
