Horsepower blata elite 14 wrs - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > European Pocketbikes
Post pics of your Blata...
Polini vs Blata
Got Me a 2.5 for $305.00 yesssss
VIDEO: GRC RX, 64.4mph run.
Free Blata 2.5
Show Pictures Of Your Bike/s
GRC RX or GRC RR
Polini Gp3 13hp
heres my baby
Old 09-20-2006
minirossi2006 minirossi2006 is offline
Junior Member
I need more horsepower in my blata elite 14 wrs, Somebody knows how to get it? sorry about my english, im spanish.
  #2
Old 09-20-2006
mccrash59's Avatar
mccrash59 mccrash59 is offline
Junior Member
Re: Horsepower blata elite 14 wrs
Hi Javi!
Glad to see you around...
This guy does need really help. He´s a real fast rider but his ride is killing him and his mechanic patience, there´s one trouble after another.
In the dyno test the bike developed barely 9hp and is a pain to find the correct carb setting. Last weekend in a local race the bike seemed fine using a chinese barrel, but not that good is suposed to perform a 12cv tuned engine.
Thanks guys, we know in the Uk these bikes are a bunch and you´ve found the right way.
Cheers
  #3
Old 09-21-2006
Junior Member
hey
what`s up.
What are you doing over here.... i found this web the last week and im trying to find information about blata engine to make it stronger for madrid championship. Fernando it´s talking with blata spain, and they want help us..i see you in la Princesa.
  #4
Old 10-02-2006
rasputin rasputin is offline
i've tested a stock wrs engine with a 19mm carb on the dyno, it had 11hp at the rear wheel.
the biggest flaw in the blata engine is the intake. you can surely increase power by porting the intake.
r
  #5
Old 10-02-2006
crazywelder72's Avatar
crazywelder72 crazywelder72 is offline
Junior Member
where does one find a dyno for these? also what is the top end on these.
  #6
Old 10-02-2006
my posting was a little mistakable. i did not use an engine dyno, i used an "amerschlaeger p4" scooter dyno (simulates a load of 95kg).
any "scooter dyno" is good for minibikes. do NOT use a large motorcycle dyno, they'll just wreck the clutch, as the simulated load is too large (150-200 kg).
i don't know the code of the top end. it's a 2006 wrs engine.
r
  #7
Old 10-02-2006
Syncopix's Avatar
Syncopix Syncopix is offline
rasputin i'm wondering if you fitted the PHVB carb in that WRS.. is that right?
Did you know if are any differences between the WRS engine and the B1 Kit engine? i have one origami engine in my elite 13, it's a b1 kit engine because it has the PHVB intake but i don't know if has the claimed 15hp or if it's different than the WRS engine.
PD:the bike also have the WRS exhaust and crank
  #8
Old 10-02-2006
zx9rstv's Avatar
zx9rstv zx9rstv is offline
the 06 wrs engine has been redesigned from the previous years. thr B1 engine is NOT the same as the WRS engine. the new wrs engine has a flat top piston and a race stuffed crank.the cylinder and head is a complete redesign from the old. My WRS stock came with a 17.5 carb. I had the worst time tuning that carb and getting the bike to run right. I fitted it with a 19mil dellorto carb phbg.. after adjusting the needle and putting in a 83 main jet .. it runs like a champ.
  #9
Old 10-02-2006
the 19mm carb is a dellorto phbg. bytheway, that's not my bike. i was wondering about the power of a blata engine so i asked a guy to bring his wrs to the dyno.
i don't know much about all the various blata engines. i have a wrs "kit" engine in my workshop, and it came with a 14mm phva carb. the code on the cylinder is "11d". as far as i know the difference between the "kit" engines and the normal engines is an additional porting of the intake and piston done at the factory. it's not my engine either, but i can use it for dyno tests...
r
  #10
Old 10-03-2006
mccrash59's Avatar
Junior Member
Anyway I´ve always heard Blata is crearly claiming not so true top end power. The supposed B1 15hp would be 11,5 or 12 at last.
My friends team purchased two 14wrs at the same time and both engines are different, not the same crank nor piston and other small diffs.
  #11
Old 10-03-2006
Syncopix's Avatar
Thanks guys, i had tested both carbs and the phvb was the best to work.. i was very difficult to adjust but once done the bike goes like hell.
My engine is from a 2005 origami and it has the latest type of cylinder, it's marked as 7c05 but in fact is a B Cylinder (marked at the bottom).. had the standar crank but i changed it a few months ago.
Mccrash the power claimed by blata is at the crank, so it you put the bike at the dyno i would do a few hp less.. the other manufacturers had the same problem, all the power output it's supposed at the crank.
Now i'm thinking to purchase a 50cc kit from savacanada because last saturday the piston bearing cracked and some pieces of metal scratched the piston, head and some little scratch in the cylinder.. so anyone could tell me if that kit is a good choice? i'm wondering if the port timing it's adjusted in those kits..
  #12
Old 10-03-2006
blata, like everybody else, are claiming crank hp. this means that their engine has 15 hp at the crankshaft. the clutch, the chain, and the tire, waste 25% of that power, so the power at the rear wheel is 11 hp. a "17 hp" polini bike tested on that same dyno had 12.5 hp at the rear wheel.
i have done simulations regarding the bigboring of blata cylinders. they predict only a little increase in power and torque, but an enormous increase in "midrange" power and rideability. the only port that definitely needs modifying is the boostport, the rest can be left "as is".
of course, one can modify the exhaust port to get the same power as the other 50cc engines. but this will turn the engine into a goatish beast, so it's only advisable for high-speed tracks.
that phvb carb, is that a 20.5mm carb?
r
  #13
Old 10-03-2006
Junior Member
interesting, i rode this 2 years ago when my buddie got it and i definitly underestimated it. needless to say after a half hr or so of playing with it, the powerband finally reared up like a cobra striking its prey. i think everybody knows what happens next. since i have got it i have not pushed it that hard. i actually want to figure out where that sweet spot is and try to master it so i can be sure to have all my weight down on the front end. any sugestions?
  #14
Old 10-03-2006
Syncopix's Avatar
The phvb carb is a 19mm and the intake connection is 5mm bigger so blata fits in the origami with a special stuffers in the reeds cage and bigger intake hose. As i said this carb gives more performance as the phbg, the engine runs smoother and have better acceleration in my bike
This morning i inspected the damage of the engine and miraclously there was no damage in the cilinder.. so i will change the piston and the head and that's it until i have more money.
Regards!
  #15
Old 10-07-2007
redline rotary redline rotary is offline
i got a car dyno it also works on pocketbikes.
  #16
Old 12-25-2007
cagaroni's Avatar
cagaroni cagaroni is offline
Regards!
I see you are also on a spanish forum.. I also have the PHVB19 on my WRS and having a heck of a time trying to dial it in. What idle & main jet are you using and do you run the Blata cf reeds? Also what is temperature over there.. thanks
http://www.portalminimotos.com/foro/...v-vs-12cv.html
  #17
Old 12-25-2007
cagaroni's Avatar
r
The wrs already has the intake ported from blata, at least mine came like that. The only problem that hasnt been fixed from what i can see is the reed lift issue. i added a 10mm spacer to help with this and also to stop the boost port from being blocked by the reed since its covered with the original configuration.
My cylinder has the 11D stamp.
  #18
Old 12-25-2007
cagaroni's Avatar
This is my dilemna now, i also have a PHBG19 ds i can use in place of the PHVB19. I know the PHVB has a larger throat but trying to dial it in has been a nightmare. What were the differences in performance you found between the two?
  #19
Old 01-08-2008
Dazza Dazza is offline
Here is a dyno sheet from a 46.5cc modded Blata with a 19mm PHVB and a 19mm PHBG carby.
There is also the dyno of the 50cc modded motor.
But the kit used is not the USA 50cc wisco kit.
http://i5.photobucket.com/albums/y16...0dyno_0001.jpg
  #20
Old 01-12-2008
i know these "factory ported" engines. but for a 19mm carb, the intake remains an "eye of a needle".r
You may not post replies
[IMG] code is Off
Forum Jump
Similar Threads
Blata 2.5 vs Cagllari hayabusa Air Cooled Pocketbikes 41 04-25-2009 02:47 PM
BZM steering Damper on Blata Elite 14 u_got_smoked European Pocketbikes 0 04-09-2006 05:29 AM
blata elite 14? Dave_O European Pocketbikes 2 06-01-2005 07:56 PM
Powered by vBulletin
