Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Electric Pocketbikes
Pocketbike Forum
Top 10 Threads
MX650 mods?
A new drag bike
pr200 razor-mod
electric pocketbikes are horrible!!!!!!
Xp-700
help with razor pr200 set-up
X7 goes electricproject
Electric X7
honda Mini moto 18 volt speed control bypass
Once And For All Polini Vs Electric
Old 06-29-2007
Haris_P Haris_P is offline
Junior Member
Re: A new drag bike
that's the most baller sh*t ever
  #42
Old 06-29-2007
nofearX18's Avatar
nofearX18 nofearX18 is offline
Re: A new drag bike
any updates on that chopper drag bike?
  #43
Old 06-29-2007
johnws6's Avatar
johnws6 johnws6 is offline
Re: A new drag bike
Took a couple pics of the batts today, this is about 38 out of 40 8 cell packs total, so from the pics there is just 2 missing. Quite a bit of power sittin there. The one black thing you see there is a completed 48 volt pack minus the connecting wires. In total there will be 8 of those black 48 volt packs.
  #44
Old 06-29-2007
nofearX18's Avatar
Re: A new drag bike
thats a crap load of batterys! i could go for a 7up rite now lol.
how do u plan on hanging on to thing thing when it takes off?
  #45
Old 06-30-2007
Matty_C Matty_C is offline
Re: A new drag bike
that looks sweet man love the look of it and man thats one big motor :O its gonna be killer
  #46
Old 07-03-2007
johnws6's Avatar
Re: A new drag bike
lol haven't really figured out the hanging on part yet..
  #47
Old 07-03-2007
nofearX18's Avatar
Re: A new drag bike
well i know one thing. that wheelie bar is definitly gonna take a beatin!
  #48
Old 07-04-2007
wolvesracing wolvesracing is offline
Member
Re: A new drag bike
go out to your local tractor suply co. and they sell 6.5 hp farm purpose motors, i dont know if the fork lift motor would get high enough rpm's. you can check them out on there website.
  #49
Old 07-04-2007
johnws6's Avatar
Re: A new drag bike
high enough rpms for what?
  #50
Old 07-04-2007
nofearX18's Avatar
Re: A new drag bike
this is a electric pocket bike....if ive read correctly...
  #51
Old 07-13-2007
bhp Hunter bhp Hunter is offline
Re: A new drag bike
high rpm's for what?! the beauty of series wound motors is down low... hehe, besides if you look at any dyno graph of this kind of motors you will see that as rpms go high power comes down.
johnws6 i have one of those motors in my father's "scrapyard" the drum is a brake, the one i have is rated at 36V 60A 2,6Hp 2800rpm's what are the ratings on the one you have?
oh and something have just crossed my mind, you will feed your motor with 48V rigth? if your motor was built to work with 36V theres no way that the motor will use 600Amps once you start moving... using my motor as an exemple:
if i feed it with 48V, at 2800rpms (nominal speed) the motor will pull +-80A from the batteries
now ASSUMING that the motor efficiency and a crap load of constants dont change
at 1400rpms (half the nominal speed) the motor would pull 160A from the bateries
at 700rpms, 320A
at 350rpms, 640A
to make this motor pull 600A from the batteries at nominal speed you woul need a 270V batterie pack, this means that you're gona leave the line very hard but after a couple of yards the acceleration would not be so spectacular... i think you would be better with more volts and less amps, better for your ET and much better for the motor :S
  #52
Old 07-13-2007
Re: A new drag bike
oh ****... big mistake in series wound motors the current rises exponencialy...
1400rpms 320A
700rpms 1280A
350rpms 5120A
anyway at nominal speed this motor would only be producing about 4.6hp... top end would be very poor... i doubt you can do 80mph with that power
  #53
Old 07-13-2007
Member
Re: A new drag bike
exactly, you'll barely hit 20 mph, but you would have a good enough amount of torque. your best shot is to get a huge sprocket.
  #54
Old 07-13-2007
Member
Re: A new drag bike
finally someone agrees with me
  #55
Old 07-13-2007
Member
Re: A new drag bike
[quote=nofearX18;291773]this is a electric pocket bike....if ive read correctly...
well yeah, learn the basics, motors are electric, engines are gas. so a farm purpose MOTOR.
  #56
Old 07-13-2007
nofearX18's Avatar
Re: A new drag bike
well i call all engines motors.... doesnt make much of a difference to me.
  #57
Old 07-13-2007
aproldan's Avatar
aproldan aproldan is offline
Re: A new drag bike
talk is just talk.. this guy is trying to build a drag bike so you should give him credit for spending the time money and the effort... it may not reach 80mph but it will be something he can be proud of.. any of us building something would be proud of their creation no matter what the results...
now he got a nice motor that was meant for folklift or something like that(too lazy to go back and read what that motor came out of)... anyway the motor was hauling or was meant to haul heavy loads... let's just say 800 lbs. by the time his bike is done it may weigh 150lbs. and say he's 200 lbs. that motor will move him with not problem... now if he gears it down to a 1.2:1 ratio their's his 80mph... the motor will pull some big amps but it is possible..as long as he stays in that rated 2800rpm range he may have a couple hp pulling him across the finish line. how fast down the 1/8 mile, i guess once he gets his bike together we will see... i hope he does set a record
  #58
Old 07-13-2007
Re: A new drag bike
im not trying to disencourage him... on the countrary, i've thinked of something that could be a problem for him and presentet what i think that could be the solution, to go 80mph he needs a certain amout of power, he can obtain that power by gearing low as you said and pull lots of amps from the batts and beat the hell of the comm and brushes and 600A for 10 secs is a lot for a motor of that size, or he can feed more volts to the engine gear a bit higher still have neck breaking acceleration out of the line and good top end without beating the engine so hard.
you're right about the feeling of building things by ourselfs, even if it doesnt work has we expected its something done by us and no one can take that from us
  #59
Old 07-13-2007
johnws6's Avatar
Re: A new drag bike
I'm way ahead of you guys on this.
  #60
Old 07-13-2007
Re: A new drag bike
you better be, you're the bilder any updates? we want pics please
You may not post replies
Forum Jump
Similar Threads
Newbies, Read If You Want To Know What Is The Good Stuff.... Day-Tone-A MX Air Cooled Pocketbikes 38 04-12-2005 12:48 PM
My Bike Ryno Asia Pacific 18 03-11-2005 08:07 AM
Pocket bike engine won't stay running. amanthebest Air Cooled Pocketbikes 12 01-30-2005 01:58 AM
Sactown pocket bike drag racers G-Divisionboyz Northwest 18 12-22-2004 11:43 PM
Powered by vBulletin
Style design by Leo
