Trouble with trevor simpson head kit - Pocket Bike Forum - Mini Bikes
Post up pics of your Cag...
Stock pipe mod
A "Racing Engine" Built
Boost Bottle?
NOS on my bike
Old 09-30-2004
G-Divisionboyz G-Divisionboyz is offline
I just brought a trevor simpson head kit and install it. The problem is that the cag will not start now........I re-installed my ported head kit and it starts on the first pull..........Not sure why the cag is not starting. did anyone have this problem?
  #2
Old 09-30-2004
snowboardgeek1's Avatar
snowboardgeek1 snowboardgeek1 is offline
PBP COUNCIL MEMBER
I have the trevor simpson head kit but haven't installed it. How many gaskets are you using? Whats your squish? Just saying it doesnt work without giving more info, won't get much help.
Do you get a spark?
  #3
Old 09-30-2004
only one gasket is being used.............no sparks........the plug still looks brand new......
  #4
Old 09-30-2004
PBP COUNCIL MEMBER
Well there goes your problem then. No spark equals no start. Make sure your coil is getting a charge from the flywheel when it spins. You might have to change out your coil.
Also, have you considered having to rejet? You might not have enough fuel getting to the head.
  #5
Old 09-30-2004
zero4's Avatar
zero4 zero4 is offline
PBP COUNCIL MEMBER
No spark when the plug grounded to the head? So if you ground it to the case it will spark? I'm not familiar with the trevor simpson head kit but if that's the case, you of course have a continuity issue. I believe the heads are anodized, correct? The anodizing may prevent the head to ground through the head bolts since it cannot ground through the gasket. Try grinding the anodizing away where the heads of the head bolts meet the head (that was too many heads in that last sentence, lol).
  #6
Old 09-30-2004
Thanks guys for these tips, I will try these solutions when I get off work today. I am not sure why my friends trevor kit works just fine and I got stuck with this problem. What puzzle me that most is that why the trevor simpson head comes in different spark plugs. My friends all got NGK BM7A and I got stuck with the Autolit one.
  #7
Old 09-30-2004
zero4's Avatar
PBP COUNCIL MEMBER
What Autolite p/n is it? You should have 253. 235, 254-255 will work also but are hotter.
  #8
Old 09-30-2004
okay guys, I change the bad coil and install a working one. I know this one works since I tested on my other cags, and there is sparks now I can see it but still does not start. Hmm.......I also added a new gasket. Still puzzled on why this head is not working. I fired up my other cag with the ported head. the motor, coil, sparks, and fires up. But when I put hte trevor simpson head on.....the motor just turns, will not kick on......can someone help me more on this werid problem???????
  #9
Old 09-30-2004
PBP COUNCIL MEMBER
Did you gap the plug?
Still sounds like you're not getting enough of a spark, plus, it seems you need more fuel as well. With more air, more fuel is needed.
What carb are you running? You need to jet higher for sure.
  #10
Old 10-01-2004
Well, I am using a stock carb with stock jets.........I will try to use a larger jet later and re-gap my plug. What size gap should I be at? wider or closer?
  #11
Old 10-01-2004
MiniRacer187 MiniRacer187 is offline
Junior Member
Is the upper gasket (the copper one) damaged in any way where a leak could occur? If your bike starts on the first pull with the old head then it is not a coil or gap problem, you do not even have to remove the coil to install the TS head kit. You probably have a gasket leak or a stuck piston ring. Are you using the same piston as what you use with the other head? If so then that is not the problem but I would check your gaskets and make sure none is damaged or pinched in any way. If so, get a new one. Also make sure when you tighten the TS head kit down that you tighten the bolts in a cross pattern. Looking at the top of the head like this [x]. Get all the bolts snug, not tight then go from top left to bottom right then bottom left to top right tightening little by little until all of them are nice and tight.
  #12
Old 10-04-2004
Thanks guys.........I will add all new gaskets for the O' ring and the header to see if I can start it........
  #13
Old 10-05-2004
PBP COUNCIL MEMBER
You ever get it fixed? I still haven't installed mine.
  #14
Old 10-05-2004
NA............I did not have any time this weekend since I was kinda busy with my other cags. I will try to put gaskets on and see if I get more compressions. I will also install my dellroto carb with bigger jets and see if I can get this upgrade motor started.....
You may not post replies
Forum Jump
Similar Threads
Review of new Badazztoyz Head Kit BAT-HK Ritchey79 Air Cooled Pocketbikes 58 02-06-2006 06:08 PM
ADA 44mm Head kit preview snowboardgeek1 Air Cooled Pocketbikes 4 04-23-2005 02:58 AM
jb extream head kit review elier Air Cooled Pocketbikes 8 04-07-2005 03:04 PM
ADA Reed Kit Review snowboardgeek1 Pocketbike / Mini bike Reviews 0 12-21-2004 09:15 PM
Powered by vBulletin
