how does gearing/ sprockets work? - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > General Pocketbike Discussion
Dandy MR-40 Rebuild
remember my mx500? now it has 6.5hp!
something different here look! Custom Quad.
X18-R Nitro
Post And Vids Of your Homemade Project.
for all Atlanta and surrounding area riders/racers
Cagllari Pocket Bike?
Cleaning stock carb tutorial
My Giovanni 49CC won't start
New Project-Cag Engine on X-games Dirt Bike Bicycle
Old 08-08-2007
X1racer_va X1racer_va is offline
Junior Member
How do sprockets work?
Does a bigger sprocket in the back give u top speed or acceleration?
Does a smaller sprocket in the front give u top speed or accerleration?
  #2
Old 08-08-2007
exposed87 exposed87 is offline
Re: how does gearing/ sprockets work?
a large sprocket in back with incress top speed a smaller reaer sprocket with give u better acel and less top speed but id perfer top speed
  #3
Old 08-08-2007
giverrr giverrr is offline
Exactly. Big rear sprocket-top speed. Small rear sprocket-hole shot
  #4
Old 08-08-2007
minimotoracer311 minimotoracer311 is offline
Excommunicated PBP Staff
No, actually its the complete opposite. Bigger rear sprocket better acceleration, smaller rear sprocket better top speed. Small front pinion better acceleration, larger front pinion better top speed.
Please do the research before you answer someones question, it just makes you look like an idiot and it feeds noobs with the wrong info.
  #5
Old 08-08-2007
Junior Member
>.< u ppl are all sayin diff stuff. What is the correct answer to my question?
  #6
Old 08-08-2007
swanni06 swanni06 is offline
minimotoracer just told you.
  #7
Old 08-08-2007
Junior Member
ok i will go with what minimotoracer is sayin.
  #8
Old 08-08-2007
Junior Member
so if i get a bigger rear sprocket and a smaller front sprocket my bike should accelerate much much faster?
  #9
Old 08-08-2007
what size is your front pinion? count the teeth on it and see.Its easier to change the front pinion gear because you won`t have to worry about messing with the chain size.plus just buying a new pinion/clutch bell combo will be cheaper than a rear sprocket and chain.
  #10
Old 08-08-2007
I wrote that the big rear sprocket gives better acceleration and a small rear sprocket gives top speed and edited my post when I realized someoen else had posted. Sorry I was doing something and should have left it alone rather then assume the post sbove me was correct and agree. Yes X1racer va it will accelerate quicker. Darn caffine
  #11
Old 08-08-2007
Junior Member
my front sprocket is the stock one. I think it has 14 teeth. I have only found bigger front sprockets for better top speed. I found a 20 tooth front sprock that said it would make my bikes top speed 40% faster but much less acceleration. Where can i buy a smaller front sprocket for faster acceleration?
You may not post replies
Forum Jump
Powered by vBulletin
