Pocketbike Forum
Top 10 Threads
Post up pics of your Cag...
Stock pipe mod
Boost Bottle?
NOS on my bike
A "Racing Engine" Built
View Poll Results: Boost Bottles
Good 176 73.03%
Bad 69 28.63%
Multiple Choice Poll. Voters: 241. You may not vote on this poll
Old 08-25-2004
trademark's Avatar
trademark trademark is offline
Exclamation Boost bottle
The following boost bottles have been used and are proven not to work because the volume is too large
NOS octane booster bottles. although very nice looking it will not work
AXE body spray cans will also not work
baby food bottles will not work
Starbucks cold coffe bottles yep you guest it won't work
for the boost bottle to work it has to equal the volume of the cylinder in our motors which is around 1.7ml
things we know if you do find a bottle this size or are fortunate enoughf to pour your own plastics and can get the volume right in any of the bottles named above.
the Mod works better if the bottle is higher than the intake
the shorter the hose the better because the gasses do not have to travel as much and loose the speed. or boost that we want.
anything i mist post em up..
  #2
Old 08-25-2004
bmarley5780 bmarley5780 is offline
Junior Member
Lowe's - saw a little bottle of-----> wd-40 -----> 2 oz.
-----> beautane(sp?)-----> 1.5 oz.
1.5oz curently on my bike, have yet to take off/on and see if it does anything.....
  #3
Old 08-25-2004
KillJoy KillJoy is offline
Junior Member
Most bottle's contents are measured by weight, not by volume.
You want one that is about 1.7-ish cc (3cubic inches) by volume.
KillJoy
  #4
Old 08-25-2004
davesmotors.com's Avatar
davesmotors.com davesmotors.com is offline
There are some billet boost bottles available which, although pricey, work very well and are practically indistructable...
http://www.davesmotors.com/store/product1218.html
  #5
Old 09-26-2004
andrwsaid andrwsaid is offline
Junior Member
boost bottle installment
Hey-- SO i finally put together my own boost tube. I made it out of PVC pipe. Now I am wondering, how do i install it, and where? Sorry if this is a stupid question I really just don't know.
  #6
Old 09-26-2004
bigsugar500lbs bigsugar500lbs is offline
PVC + GASOLINE = BAD
have fun with your fuel system after a while with melted pvc in it.
  #7
Old 09-26-2004
alvinllaneza alvinllaneza is offline
Junior Member
just dont use pvc
  #8
Old 10-01-2004
MiniRacer187 MiniRacer187 is offline
Junior Member
Originally Posted by alvinllaneza
just dont use pvc
Notice the size of boost tubes/bottles in motocross. The size of these tubes I see on the market like PBU's tube is larger then a boost tube for a CR80. How do you expect that to work? The size of the boost tube is based on intake volume and I doubt a allegid 49cc motor takes in as much air and fuel as a CR80. The boost tubes i have seen online have almost as much displacement as the **** motor they are suppose to hook up to... Does not make any since to me other then a money scam... If you need a boost get a boost box, they are small, clean and properly engineered.
  #9
Old 10-10-2004
kawiultra99 kawiultra99 is offline
Junior Member
What's the boost bottle do for ya???
Wondering how people like the boost bottle. What does it do?
Is it worth it?
  #10
Old 10-10-2004
Junior Member
Sorry gang
  #11
Old 10-10-2004
vehement's Avatar
vehement vehement is offline
Hugs not Drugs!
Originally Posted by kawiultra99
i like it when people take the time to seach and answer their own questions! good job!
  #12
Old 10-11-2004
kawzone kawzone is offline
Junior Member
Boost Bottle?
Hey can anyone help... What is a boost bottle and how dose it work and why...
thanks
kawzone
  #13
Old 10-12-2004
xxtremez xxtremez is offline
boost bottle?
I was checking out pbu and saw the carb kits with a boost bottle. Are they worth the money? Is any one on here running one on a cag?
  #14
Old 10-12-2004
avangusva's Avatar
avangusva avangusva is offline
Just make ur own. Dude, do a search....http://www.pocketbikeplanet.com/showthread.php?t=416
  #15
Old 10-12-2004
Tfizzle Tfizzle is offline
Junior Member
i thought pvc pipe + gasoline =bad
am i correct?
  #16
Old 10-12-2004
POCKETMASTER's Avatar
POCKETMASTER POCKETMASTER is offline
a boost bottle is a small closed tube with a hose that installs between the carb and cylinder, as fuel goes in at low speeds, some goes into the bottle and trickles out at high speed giving a speed "boost". a "juice box" works tons better.
  #17
Old 10-14-2004
asnboi512's Avatar
asnboi512 asnboi512 is offline
whats the differance beteween juice box and boost bottle?
  #18
Old 10-14-2004
this_budweiser_is_4_me's Avatar
this_budweiser_is_4_me this_budweiser_is_4_me is offline
other than price there isnt alot of diff. between them lol **** i build my own boost bottol for less than $6.00 and it works just as good as the high $$$$$ ones
  #19
Old 10-14-2004
joyce joyce is offline
Junior Member
how to make the booster bottle myself?
what materials you use for the booster bottle. how big the booster bottle will have to be in volume and in size?
can you teach me so that i can make one for my bike?
how fast do it make it go faster, low end speed or high end speed?
  #20
Old 10-14-2004
Thumbs up
What is a boost bottle?
The boost bottle is a small sealed chamber connected to the manifold of a 2 stroke engine by a small tube. It works with a 2 stroke by when it sucks in gas, then the piston goes up the gas wants to keep going forward but hits the piston. It would then usually go back into your carb making your fuel mixture double rich in the time fractions of a second. With a boost bottle this flow back of gas goes up into the bottle and compresses itself to do inertia, it will then shoot back down into your cylinder. This makes gas go into your cylinder quicker, allowing for a better explostion and quicker stroke.
How to make one
You want the boost bottle to be greater then the cylinder volume. IF its a bigbore rc 25.4ccs you should make the bottle to be around 27-30ccs, not to much bigger then the cylinder. The bottle should be positioned above the intake manifold so that it drains down; an incorrect position of the bottle below will cause air/fuel sepersation and form a puddle of fuel over time.
If your going to make one, drill the intake manifold and put a 1/4in barb in it pointing upwards (you got have a drill and tap if you want to do it right, not having it ghetto with jb weld or something. You can really make it out of anything. I wouldn't recommend using pvc pipe because of gas. But you can make it out of pipe fittings, or even possibly butane bottles just something that is sealed all around. You don't want to have any air leaks. And use a 1/4 in fuel line, I would use pipe clamps around the two barbs(like what airfilter use to hold it to the velocity stack.
How a boost bottle improves performance
Written originally by: SRE
Air rushes thru the carb on the intake cycle. Ignition accelerates the piston down closing the intake port. The momentum (Intertia) of the air has to go someplace, it goes back thrue the carb causing a double rich mixture. The result can cause hesitation.
Due to the velocity of the air/fuel mixture through the carb, we need to take advantage of this momentum/inertia energy. The boost bottle provides a storage tank for pre-atomized air/fuel mixture. Now when the piston moves up towards TDC (top dead center) the boost bottle assisits in filling the cylinder with preatomized air/fuel mixture for a fraction of a second until the carburetor venturi gets enough velocity to fully atomize the fuel.
The boost bottle provies a "BOOST" supercharged effect to each cycle. The advantage is that it brings up the torque and horsepower in the lower RPM range.
Supplies:
Bottle of some sort
6in of 1/4 fuel line
2 1/4 in barbs
Drill and Tap
Some brains
What I experieced
I noticed when I was warming up my ped after installing it was quicker throttle response. When I got it running how I like it I had it tuned a bit richer on bot L and H. I noticed a lot accel power. When I would rev it a little in the air and drop the back tire to take off it didn't hesitate like it did prevously.
another words if you have a 49cc motor heres what i did
got a peice of pvc 1"x4" 2 end caps drilled and taped it
drilled and tap the manafoild
ran my vapor line to the boost bottol
DONE
it took me less than an hour to make a do
You may not post replies
Forum Jump
Similar Threads
Boost bottle materials Supa Dexta Air Cooled Pocketbikes 6 08-15-2005 09:23 PM
Home made boost bottle review!!! u sucker just got served 2Stroke Midbikes 22 07-16-2005 02:14 PM
boost bottle test smn1 2Stroke Midbikes 10 07-06-2005 01:30 AM
boost pressure gauge for a boost bottle? u sucker just got served 2Stroke Midbikes 22 06-25-2005 12:17 PM
Powered by vBulletin
Style design by Leo
