X7 wiring diagram - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Midbikes / Superbikes > 2Stroke Midbikes
Pics of your midbikes
Top Speed & Mods to get there
x7 top speed!!
NEED Pocket bike 49cc engine diagram
a-nuter motor swap
Put down your top speed
Stop the confusion! - MidBike names and PICS -
Need help Tuning 49cc Carb
Who Says You Cant Turbo A 2 Troke?
Video
Old 07-11-2008
Shiester Shiester is offline
X7 wiring diagram
I looked over alot of posts on here and didn't find anything showing a diagram of the x7 wiring, i recently got one handed down to me but the speedometer,front lights, and blinkers dont work. Anyone know where i can get a diagram for this bike? or have enough knowledge on x7's to maybe help me rewire it alittle.
Thanks
  #2
Old 07-11-2008
dragonkeep2000's Avatar
dragonkeep2000 dragonkeep2000 is offline
Re: X7 wiring diagram
the x7 is the same wiring diagram for the x2,x3,x5,x6,x7,x8,x9 and the cateye ......all of the 2 strokes were the same wiring systems all except the x1 which some of them did not have all the lights that the others did.........i would rather buy a wiring harness for 25.00 new than take a chance of frying the system by accidentally touching the wrong wires together............
  #3
Old 07-11-2008
125ccCRazy's Avatar
125ccCRazy 125ccCRazy is offline
no such thing as a diagram for these bikes since the chinese have NO consistency to the color codes... The harneses change color from one side of the plug to the other and from bike to bike... All you can do is get a test light and start testing wires, my guess would be something came unplugged... Buying a new harness would be useless unless you got every wire for all the lights, controls ect as the chances of another harness plugging into all your connections is slim to none, somewhere there will be a different connector, it's like they wire each bike individually....
I rewire all our bikes so I know what is what and where.....
If you touch a hot wire to a ground all it will do is blow the fuse since everything electrical is run through that one fuse, you wont fry a harness unless you take the fuse out and shove foil or a screw in place of the fuse...These harnesses are not that suficticated, just confusing...
  #4
Old 07-11-2008
it will be easier to change a plug end than to rewire the whole thing ...besides you will already have the messed up harness to pull all of your plug ends from anyways............and all 50cc cdi's ,rectifiers and relays all plug into the wires the same all you need to check are the lights and signal plugs..
  #5
Old 07-11-2008
125ccCRazy's Avatar
true but trying to figure out what goes where is the pain, nothing is color coded, when you rewire it yourself you know what goes where... It's an easy job plus you can wire in more than one fuse relays for higher watt bulbs, alarms, NOS, whatever you want to hook up...Thats just my thing when it comes to the nightmare wiring on these bikes..
  #6
Old 08-17-2010
zaporozhets zaporozhets is offline
how do i know if i need to change the cdi or the wire harness?
  #7
Old 01-13-2012
choebikestudio choebikestudio is offline
where does my ignition coil plug plug into?
  #8
Old 01-14-2012
EPR's Avatar
EPR EPR is offline
Outlaw
Here is a couple off wiring dia. they may be modded wiring but they will give you a general idea. Starter System and a modded stripped wiring I believe. Hope this will help you, wiring is not my Gig,lol.
  #9
Old 02-21-2012
jchaussee jchaussee is offline
In the top diagram what is the thing that is not labled that everything goes in?
  #10
Old 02-21-2012
Also I have a mini pocket bike that looks similar to a cateye. Does anybody know what it is and have a pic of what it is supposed to look like?
  #11
Old 02-21-2012
EPR's Avatar
EPR EPR is offline
Outlaw
I believe that black box and the 4 wire connector above it is the voltage Regulator, ( rectifier ) . See how all the power goes thru there.
  #12
Old 02-21-2012
mijo72 mijo72 is offline
Hey, I was wondering when i got a cat eye pocket bike .The fuse wires was rigged up i was wondering if you can tell me what are the orignal color for the fuse wires are supposed to be on the bike please and thank you ????
  #13
Old 03-13-2012
fs-509 fs-509 is offline
so i could use a wiring harness off the x7 (2stroke) to plug right into my cateye fs 509? just some colors may be differant?
  #14
Old 03-13-2012
bullwinkle0689's Avatar
bullwinkle0689 bullwinkle0689 is offline
i have a diagram. email me on flamin_hotdog@hotmail.com and i will send you it
  #15
Old 03-13-2012
scratch the email, here ya go
  #16
Old 03-14-2012
ok so i spent another day trying to wire this im about to give up i did mamage to find a wiring harness on ebay but its for the x1 x2 would this work for my bike i have the fs 509 / z600 / cateye ?
  #17
Old 03-14-2012
EPR's Avatar
EPR EPR is offline
Outlaw
X1 has no light wires etc.
  #18
Old 03-15-2012
ok thank you what would the best harness to get? im just over thinking this wiring to much and confusing my self
  #19
Old 03-15-2012
EPR's Avatar
EPR EPR is offline
Outlaw
I think X2-X7, 2 stroke wiring would work. Everything that gets power goes to ground after, like your lights, key, coil. All my bikes the green wires all go to ground, and most bikes have a bunch of green wires tied together, an is grounded to the frame w/ a bolt. Alot of hot wire stuff could come off the key switch, or voltage regulator. If the stuff on the bike has plugs and your new wiring has plugs, most are different, 2,3,4,5 and 6 wire plugs are common, for the stator and other things. Go to pocketbikeparts, or maybe scooterparts4less. Look at wiring diagram, find where the hot wire comes from on each part and do them 1 part, 1 wire at a time.
  #20
Old 03-15-2012
on my x2, the only green wires where providing a live feed but they where green and white
You may not post replies
Forum Jump
Powered by vBulletin
