pocket bike wont start - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > General Pocketbike Forums > General Pocketbike Discussion
Dandy MR-40 Rebuild
remember my mx500? now it has 6.5hp!
something different here look! Custom Quad.
X18-R Nitro
Post And Vids Of your Homemade Project.
for all Atlanta and surrounding area riders/racers
Cagllari Pocket Bike?
Cleaning stock carb tutorial
My Giovanni 49CC won't start
New Project-Cag Engine on X-games Dirt Bike Bicycle
Old 09-07-2008
kurdishmonsta kurdishmonsta is offline
k i used it in the rain and i got it 2 days ago, what do i do. is there a guide to clean the air filter?
  #2
Old 09-07-2008
thestone11's Avatar
thestone11 thestone11 is offline
Re: pocket bike wont start
I don't think is the problem of the air filter~! you used it in the rain....maybe water went into your engine when you was riding it~!
  #3
Old 09-07-2008
how do u fix it?
  #4
Old 09-07-2008
wpeters wpeters is offline
Mine won't start either. Can't figure out. How can I test battery? Does x8 take oil?
  #5
Old 09-07-2008
Juanitoboy93's Avatar
Juanitoboy93 Juanitoboy93 is offline
Council Member
Originally Posted by kurdishmonsta View Post
how do u fix it?
just rinse out the filter with your gas mixture, and let it air dry, and if the bike still starts then your lucky and got no water in it
  #6
Old 09-07-2008
i hardly went on water, it was almost dry anyways, i didnt touch 1 puddle, the bike was dry kind of, anyways what happens if there is a little water or some in the engine?
is the bike trash now? I emptied the fuel tank, now i am letting everything dry in the sun.,
  #7
Old 09-07-2008
Council Member
probably wont start and you will have to take the engine apart and clean it, but i doubt you got any water in it you, should be fine
  #8
Old 09-07-2008
I am going crazy, it worked fine and now it deosnt, there is no water and I am sure of it.
after the engine break yesertday, i squeezeds the acceleration grip and we went about 60 - 65 km per hour, and now it wont even start. it did this morning, but then it slowly started to turn off..
please i need some help. is there a fluid u can use to clean the engine? now there is like oil mix on my engine and eveyrthing is a mess. the pocket bike is in the sun as we speak...
  #9
Old 09-07-2008
x18#1's Avatar
x18#1 x18#1 is offline
maybe you got water on the spark plug take off the wire and spray wd40 on the tip of the plug and into the wire then blow it off and put it back that might help
  #10
Old 09-07-2008
kk i took off the starting wire thing, the thing you pull to start the bike. There is some sort of wire, like a electric one, it felt kind of wet. I am guessing that is the problem...
  #11
Old 09-07-2008
x18#1's Avatar
if i understand you right thats the electric start and wouldnt cause the problem it could cause the electric start not to work but did you do what i told you
  #12
Old 09-07-2008
Yoyo, It worked guys thank you all. The spark plug just needed to be dried like you mentioned. thanks.
wow it wasnt even wet, yet i dried it and it worked like magic! thanks
  #13
Old 09-07-2008
x18#1's Avatar
well the same thing happened to me when i was driving my x18 through puddles it was fun but the same thing happened to me and the spark plug didnt even seem wet but it was
  #14
Old 11-26-2008
snoopX8 snoopX8 is offline
my X8 pocket bike was stolen when i got it back the fuse box wires were cut, it still turns on by the pull start but it does'nt move...im thinking it may be flooded can anyone help me?
  #15
Old 11-29-2008
Rambo's Avatar
Rambo Rambo is offline
you rode it in the rain??? why i dont understand why you would do something like that is there not a stiker that say dont ride wen its wet out?? my bike has that. one time i was rideing my bike and it started to rain and all that happend was my handle bars got a lil rusty but that was an easy fix. all i needed for that was some steel wool
  #16
Old 11-29-2008
Hugo42's Avatar
Hugo42 Hugo42 is offline
dude ,who reads warning stickerz?
  #17
Old 11-29-2008
SpyGuy's Avatar
SpyGuy SpyGuy is offline
Hooligan
^^^-- True. None of the new kids ever seem to read the "For off-road use only" sticker ... sometimes even the bigger kids manage to miss that one, too.
  #18
Old 11-29-2008
Rambo's Avatar
i read warning stikers.cause i dont wanna mess my bike up.its called being responsible!
  #19
Old 11-29-2008
nonoftheabove2008's Avatar
nonoftheabove2008 nonoftheabove2008 is offline
are you pulling it or pushing the button?
does motor turn but wont fire?
are you working the choke while rying to start it?
  #20
Old 11-30-2008
El-Joppo's Avatar
El-Joppo El-Joppo is offline
C'mon now, I've ridden my cag and x-15 in rain, sleek and snow, since in my part of the world the weather doesnt give us any choice. But anyway I NEVER had any problems because of riding when its abit wet out, the bikes start to rust faster, and require abit more maintenance but thats it.. Unless you try to ride these things UNDER water they should be fine.
If you are worried about water getting into your engine, then you get a fully shielded air-filter and relocate it to mount higher of the ground, or come up with something clever to shield the air-filter from all the water thats on the ground and spraying of yer tires!
You may not post replies
Forum Jump
Powered by vBulletin
