Pocketbike Forum
Top 10 Threads
Post up pics of your Cag...
Stock pipe mod
Boost Bottle?
NOS on my bike
Port timing and size (area)
110cc, 4 stroke, 4 speed pocketbike!!!
Old 10-16-2004
42F67N's Avatar
42F67N 42F67N is offline
After riding today i decided that the port job i did last weekend wasent cutting it so off came the cyl again and i added the boost port and below are pics of how i made my boost port map,i used a carbide dremel bit then cleaned it up with a sanding stone,i also didnt use a gasket on the cyl just some yamabond to bump the compression up a lil.
tommrrow im porting the carb the reed cage, tapering my needle and lighting the flywheel.
For anyone that missed my port pics before i added them in,that port job alone with out the boost port provided a killer low mid range.
first pic with the blue tape is how i mapped out my boost port i then traced out the port with a sharpie,2nd pic is after i removed the tape and the sharpie remains where i cut out.
last pic is where i removed the box with the sqiggly lines and put my 42F sig on it .
  #2
Old 10-16-2004
blueR1cag blueR1cag is offline
you just make the boost port go as far up into the head as the stock transfer ports?
  #3
Old 10-16-2004
Ride Like You Stole It's Avatar
Ride Like You Stole It Ride Like You Stole It is offline
AWESOME work 42F!!!
Did you do all of this with a dremel? I've got a dremel and love metal working just always get scared of sparks for some lame reason haha. Hopefully I can overcome that real real soon.
  #4
Old 10-17-2004
zero4's Avatar
zero4 zero4 is offline
PBP COUNCIL MEMBER
What sparks? The barrel is aluminum.....
  #5
Old 10-17-2004
insyder's Avatar
insyder insyder is offline
Ha! Ha! Ha!
  #6
Old 10-17-2004
42F67N's Avatar
yes the boost port goes up as high as the transfer ports,i used a dremel on the boost port and a die grinder on the rest.
  #7
Old 10-17-2004
Im gonna play with porting my stock head and adding the boost port and see how good I can do and if I mes anything up before I go to work on my B head. I think I am going to wait on the BB kit until I buy a FCS ctrank and get that sucker in to play with porting more, then work up to the BB kit. whats a die grinder, I thouhgt it was what you hold in your hand and it has like a 5 insh grinding wheel but I dont see what kind of headowrk you could do with that so I assume I am dead wrong.
  #8
Old 10-17-2004
bartw bartw is offline
www.extreme4strokes.com
Here is a stupid question, why would the boost port go up exactly as high as the transfer ports? Of course I am asking this because I think something different but tell me your guys theory.
  #9
Old 10-17-2004
Ok cool. I think I am going to port my exhaust port and carb. Should I use a die grinder for the carb too? Also how do I know how much to take off on the exhaust and carb?
  #10
Old 10-17-2004
vehement's Avatar
vehement vehement is offline
Hugs not Drugs!
how wide and how deep did you make your boost port?
  #11
Old 10-17-2004
...B3... ...B3... is offline
It should'nt...
  #12
Old 10-17-2004
vtecds1's Avatar
vtecds1 vtecds1 is offline
I guess everyone is doing the boostport differently.I think rexracer,PBU and a couple of other people go the same lenght as the transfer ports.But some people dont.Which one is more benificiall?back your opinion up?
  #13
Old 10-17-2004
dr.fer's Avatar
dr.fer dr.fer is offline
Senior Member
so what was the result? have you run it yet?
  #14
Old 10-17-2004
42F67N's Avatar
wow so many questions let see if i can cover them all lol ,when i said die grinder i shoulda said mini die grinder lol its alot smaller but a die grinder is bascially like a dremel but runs off my air compressor.
I have started work on my carb and im using the dremel on it..
how wide i made it is approx a 1/4 inch wide maybe a lil more more i didnt measure it and the depth is as far down as u can go without going threw the cyl
...B3... u said the boost port shouldnt go as high as the transfer ports care to go a little further and explain?
I havent rode it yet because im still working on the carb today im going to check the compression and see what i got compared to what i had before
Im by no means a porting guru i mess around with everything i own im 31 and have had alot of 2 strokes and i do performance work to them all and have allways made gains from the things i do.
  #15
Old 10-17-2004
snowboardgeek1's Avatar
snowboardgeek1 snowboardgeek1 is offline
PBP COUNCIL MEMBER
A boost port alone adds 1K to the top end RPMs. That was tach'd with my GPT tach on a completely stock bike. Before the boost port, 96-9700. After boost port, I consistently hit 10600-10700 RPMs. A simple rejet was needed as well.
Doing a 4 port (porting the 2 intakes, exhaust, and boost port), should net you close to 11K. But if you're using the stock pipe, you're limited to its potential. Get an IP2 or polini 6.2 pipe, add some CF reeds, port the carb, and you should be getting around 12,700 RPMs. Not bad for a cag eh? Your low end wont be as good as a stock cag (maybe add a reed spacer to help out this area. I haven't tried it), but your top end will be screaming. Also, try to get some clutch springs to take advantage of the mods. I've seen other boost ports that are larger in width. They all basically work the same. It fakes the engine to think there are 2 exhaust ports instead of one. Fuel and air enter the head more than stock. You'll get an increased combustion...that equals more power.
  #16
Old 10-17-2004
Ritchey79's Avatar
Ritchey79 Ritchey79 is offline
Originally Posted by ...B3...
It should'nt...
It should... and here's why. The boost port is allowing the engine to force more fuel and air into the combustion chamber upon it's downstroke utillizing all three ports; the two transffers and the boost ports. This requires the top of the port to extend past the piston rings at BDC(bottom dead center). It also helps to bevel the top of the port in order to aim the air/fuel mixture up towards the spark plug. The boost port also increases the volume of the crankcase for the duration of the upstroke.
If, however the boost port does not extend past the rings, you will simply be increasing the volume of the crankcase which will allow for the air/fuel mixture to be forced through the transffer ports at a greater velocity.
So which one is the correct way to make a boost port? Well why go through the trouble of simply increasing crankcase volume with a boost port when that can be achieved much easier by simply adding reed block spacers. Reed block spacers increase the amount of volume in the crank case achieving the same effect as a boost port that does not extend past the rings. So if thats what you're after, save your rings and just add a reed block spacer.
So does making the boost port extend past the rings add any performance over just increasing crankcase volume? Well it's debatable. It allows for better mixture of the air/fuel mixture by swirling the mixture around the combustion chamber through 3 ports. It removes some drag from the piston ring/cylinder friction, thus possibly the increase in rpms. It too is increasing crankcase volume, allowing for a slight bump in compression, also resulting in more rpms.
Basiclly the whole thing depends on what you wish to achieve in the end. The great thing about tuning an engine is you can talk to the top 50 engine tuners in the world and they will all have different tip and tricks. Everyone has their own methods for achieving the same end result... more power, more speed!
Just to note: I ran reed block spacers before I ported my head, it helped alot! I ported my head(boost past the rings) and it helped more! Together they make for an awsome combination!
  #17
Old 10-17-2004
42F67N's Avatar
I should have everything done and ready for testing sometime this week :0
  #18
Old 10-17-2004
No, it should not be the same height.
Most of the time it will be open for about 1 degree longer than the side transfers. For a boost port to work properly, as its main intention is to pack the mixture at the plug area, its journal roof must be at a pretty steep angle, usually in the neighborhood of 30-40 degrees.
  #19
Old 10-17-2004
Ritchey79's Avatar
Yes you are correct. I thought you said not to go past the piston rings at BDC. If you make it too long it will force some of the mixture out of the combustion chamber before it's ignited, thus robbing power from the engine. You are exactly right about the angle of the journal roof. As for the length of the boost port I do not recomend any amateurs attempting to make the journal extend past the transfer ports. You could easily ruin the head of your engine if you go too far. B3... this is why I did not specify a length on the boost journal, I simply stated that it must be past the rings at BDC. Their are alot of amateurs on this board that don't understand how to make a journal 1 degree longer than the transfers. Maybe we should start a thread about timing?
  #20
Old 10-17-2004
He said "exactly", and thats why I said "it should'nt".
No big deal, just a bad choice of wording on my part I guess.
*edit*
on your question about making a thread about port timing. There are so many sites now that have almost every senerio out there, if someone is of the right mind to even do motor work correctly, they would also be of the right mind to find the info and decide what they believe through their own trial and error. Its not that I do not want to help others, its the fact that I do not want to waste my breath as I have done so many times in the past, then when someones engine does not work they blame the person who told them how to do it, and do not take into consideration that they are the ones in fact who did it wrong or did not understand when they said they did.
You may not post replies
Forum Jump
Similar Threads
Advance porting basics sesshoumaru562 2-Stroke Midbike How 2's 4 12-14-2008 09:21 AM
my boost port numbers Nashport_Native Air Cooled Pocketbikes 5 12-25-2005 10:02 AM
Four boost port BB head review LONG Dallas L7 Air Cooled Pocketbikes 25 05-24-2005 08:31 PM
My 2 Boost Ports ,Exhaust Port, and Piston Window Port!!! Day-Tone-A MX Air Cooled Pocketbikes 74 12-21-2004 11:21 PM
boost port & purge tube??? 2oh6civic 2Stroke Midbikes 4 11-20-2004 04:58 PM
Powered by vBulletin
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright © 2006 - 2008 Pocket Bike Forums | About Pocket Bike Forums | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
Style design by Leo
