Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Water Cooled Pocketbikes
Pocketbike Forum
Top 10 Threads
Tuning a B1 China replica
Just got my Banshee SHO starts Smooth but..
Best Chinese Water Cooled Bike?
Nick's Water cooled bikes.... MT-A4 ( C1 )
Teaser - DM replicas from China
ZPF Replica on the way...
ZPF Replica here now
Banshee SHO Updates and Test Thread
B1 replica review (unicorn) with pics *pic request*
Have you guys seen the D1? Pic inside.. :)
Old 10-24-2004
Arjan's Avatar
Arjan Arjan is offline
Talking Tuning a B1 China replica
Hey bikerz,
I got an B1 replica,
It's completely stock, no cooling problems, no clutch problems,
I've just installed a Del'lorto phva 17,5 mm carb on it, this are the result's:
I've tested this on a dyno(so many dyno's so many result's), it went from stock 6,5 hp at 9700 rpm to 8,7 at 8100 rpm, this result was with an 100 main jet,i found out that it runs better on a 88 jet,not tested this jet though.
More tip's WANTED
greets
Arjan
  #2
Old 10-24-2004
banzai660r banzai660r is offline
Where can I get this carb in the states? I'll need the manifold too? any Ideas Is this the carb the Blata B1 uses.
Banzai !!!!!!!
  #3
Old 10-24-2004
Banzai !!!!!!!
Disregard, I read it in the other post.........of course you could put the info here too.
Banzai !!!!!!!!!!
  #4
Old 10-24-2004
Arjan's Avatar
All Blata ortigami B1 parts do fit!!
Hey bikerz,
Yes the carb is the one Blata uses, you can find this at youre local blata dealership www.blatausa.com <--- this site contains a nice blueprint and parts list too.
you can try a bike store where they sell moped's they often sell del'lorto ore bing carb's too or a motorbike tuner they usually use Del'lorto's too i got mine from a Ducati Tuner wich happend to be a Blata dealet too he got me the part's within a week.
I also found that with this bigger carb the clutch problems are gone, it's like it was ment to be like this(check the blueprint see for you're self)
  #5
Old 10-24-2004
Arjan's Avatar
hey bikerz,
And indeed the manifold is a blata 17,5mm the airfilter too, all stock blata part's.
I've read in some threats that blata won't sell spare part's to cag owners....
Well they be foolish then in my district there are already 400 china cag's operating, Blata sell's only 40pcs a year, i think they could sell 100 orignal ones all in parts next 6 month's... all those **** thing's breaking .....
The blata dealership i found was happy to sell me sum stuf...
just find a small dealership they be very intrested to sell you sum hehehe.
Arjan
  #6
Old 10-24-2004
jsigone's Avatar
jsigone jsigone is offline
u can prolly use hte intak emani that came on teh C1 but remove the 14mm adaptor.
I just picked up a Delorto 14/14 carb, came w/ a 68 jet stock. The bike is now more consistant through the power band. I did a squish test w/ a piece of 2mm solder.....it didn't even squish the solder one bit. The squish should be .50mm, So I have to make a new HG to lower the squish and this will also raise teh compression which makes more power.
  #7
Old 10-24-2004
Arjan's Avatar
??Squish??
Xplain plz i'm a overseas noobie...
where did you put that solder tin and what is a HG??!!??
  #8
Old 10-24-2004
jsigone's Avatar
squish is the gap between the edge of the piston and the top cap. This gap should be .5mm or **** close to it. Any more and u loss alot of power making compression and also messes w/ the power band.
Take out the spark plug, make a "L" shape, stick it in the hole, make sure the solder is touched the cylinder wall and pull the pull starter. The piston is suppose to hit the solder, "squish" it, take out the solder and measer it w/ a caliper. .50mm is the target.
Mines is over 2mm. the HG alone is bout 1.5mm to 2mm.
  #9
Old 10-24-2004
omnivore's Avatar
omnivore omnivore is offline
So there's alot of untapped power that can be found pretty cheap, left in the C1 then eh? COOL!
What is that Blata style 17.5mm carb priced?
  #10
Old 10-24-2004
Arjan's Avatar
Wink
thx
Mine cost 80,- euro and the manifold was 60 euro and the filter 10,
  #11
Old 10-24-2004
cmb cmb is offline
i checked mine and it was the same. i think i will try some yamabond stuff to see what i could have for squish. when i was checking mine i got the solder stuff suck in there so i just decided to pull out my whole motor and see what everyone is talking about. how do i find out if the ports are not lining up. since i have mine apart i would like to check that stuff. i also noticed the white crap in the water passage. **** china people must have used some sewer water in my bike to test it.
  #12
Old 10-24-2004
cmb cmb is offline
jsigone
thank you for all the info you gather. i have been doing some of the same stuff as what you have done to your bike. i think i will end up getting the dellorto 17 carb to unleash the beast. i have since ordered sprockets, clutch bell, clutch, and some other misc. stuff. now i want to do the internal stuff on it. again thank you for the wealth of knowledge
  #13
Old 10-24-2004
jsigone's Avatar
i didn't want the 17.5mm carb cuz that would bump me into open class where I think the bike won't be competitive. After looking at a REAL B1 head and compaired to the C1 head, the ports are off on both. Not sure if it was suppose to be this way or not. I suppose u can port it to match the case. The white crap u see in there is the Water wetter when dried. Messy huh. My buddys was the same, when I drained the bike, I also poured in straight distilled water to clean teh passages for water wetter. That way it wouldn't dry where I don't want it too.
I'm glad my info and trials to debug this bike has helped others with the same situation. I have confidense that this bike will rock once debugged, but all my debuggin has lead me to installeding better quailty and performing parts. The carb helped alot though the C1 carb is a knock off of the deloroto but I don't trust the guts and not being able to find the right jet was frustrating. $60 for the delorto 14/14 is a **** good deal. Easy to change the jets too.....now i just have to find the right one
  #14
Old 10-24-2004
scooter4n's Avatar
scooter4n scooter4n is offline
where is the pictures?
  #15
Old 10-24-2004
jsigone's Avatar
look here www.angelfire.com/sd2/sdmm/ I couldn't get the flywheel off so I only too the head off till I get the proper tools. I'll have some more pics later and show some of the HG as well.
  #16
Old 10-24-2004
cmb cmb is offline
you know on the rear engine mount which has the long bolt. how do you get your engine back on the frame with that spacer thing. it is so tight in there i cant get the spacer in. i dont know what to do. i took out the motor to see some things on it now i want to put it back in and i cant get the spacer to fit. it was super tight to get the motor out. i am thinking of making the spacer smaller with some sanding but not sure if i need to do that.
  #17
Old 10-25-2004
profyl619's Avatar
profyl619 profyl619 is offline
Junior Member
is there a distributor in cali....san diego/ los angeles area...?
  #18
Old 10-25-2004
viper01 viper01 is offline
Junior Member
I changed the carb on mine also, I used a 17,5 mm carb from del'lorto. But I used the original manifold, I took out the aluminium ring en increased the diameter using a Dremel. And also installed the Polini Power Filter and a 88 jet.
It's going like hell!!
In the next coming days I'll make some pictures to show you all..
Greetzz
  #19
Old 10-25-2004
scooter4n's Avatar
so what you going to do about your 2MM?
  #20
Old 10-25-2004
Demtoofast's Avatar
Demtoofast Demtoofast is offline
Cool pictures. Great to see. Thanks
You may not post replies
Forum Jump
Similar Threads
blata 2.5 to origami b1 replica - yes / no ?? jono400 Water Cooled Pocketbikes 10 08-11-2005 02:42 PM
What Is The HorsePower Of A C1 (B1 Replica), Do some C1's have more HorsePower? pbmod Water Cooled Pocketbikes 16 06-20-2005 11:38 PM
B1 Replica Vs Polini 6.2 Hp 817 ryders Chat 31 05-26-2005 08:59 PM
the best b1 replica? crashburn314 Air Cooled Pocketbikes 10 05-03-2005 06:59 PM
B1 China Replica vs. the Italian B1 Video! PocketPride Water Cooled Pocketbikes 11 12-30-2004 11:09 PM
Powered by vBulletin
Style design by Leo
