Where do i put the oil in the X-12? - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Misc > HELP! Ask our shadetree mechanics
Looking for wire diagram for 49cc cat eye pocket bike
Four wire key switch bypass
49CC Quad starting & idling problems
How to start Pocketbike without Pull start!?!?!?!?!?!?!
Pocket Bike, Wont Accelerate Bogs Down,Stops?dies
49cc cat eye problem:)
X19 wont start! Helpp!!
x7 Help needed
my bike wont accelerate
trying to repurpose a exhaust manifold
Old 04-23-2010
mok420 mok420 is offline
Question Where do i put the oil in the X-12?
just bought a second hand X-12 Super pocket rocket, idk where to put the oil, there is a oil hole next to the kick starter but my dad thinks that is for the crank case oil, any ideas?
  #2
Old 04-23-2010
Kieran's Avatar
Kieran Kieran is offline
Re: Where do i put the oil in the X-12?
the crank case is where you put the oil.
  #3
Old 04-23-2010
guruhelp's Avatar
guruhelp guruhelp is offline
114cc MC w/ Joanna
Yes, unscrew that thing that's in the hole and you will see it's a "dip-stick"...{WHACK} JIMMY!
  #4
Old 04-24-2010
guess i should start thinking with my dipstick, ok, another question, what kind of oil goes into it? and also, could old/bad oil cause for rough shifting?
  #5
Old 04-24-2010
guruhelp's Avatar
114cc MC w/ Joanna
Thumbs up Re: Where do i put the oil in the X-12?
although 5w-30 is recommended, I use Mobile 1 for motorcycles, 10w-40 and haven't had any shifting problems at all.
Useing automotive oil is not as good because motorcycle oil has more polymers, fillaments like spaghetti strings that get chopped up by the gears in the transmission of a motorcycle, since the same oil is used for both engine and transmissions, except on Harley's v-twins. That kid of oil lasts longer and works better. Your bike will thank you!
  #6
Old 04-24-2010
BlitzMInc's Avatar
BlitzMInc BlitzMInc is offline
what i use
You may not post replies
Forum Jump
Powered by vBulletin
