How To : Make your pocket bike quiet - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Air Cooled Pocketbikes > Air Cooled Pocketbike How-To's
Cheap Reed Mod for Cag!
How-To's - Cag performance tips and tricks
Petcock Mod
How to identify your engine size
How To: Make A Boost Bottle For You 2 Stroke Pocket Bike
How-To Carb Intake Porting
How to: mod your stock exhaust
How to Make High Octane Gas
How-To's: When you first get your Cag
Old 12-24-2010
cagllari187 cagllari187 is offline
Lightbulb How To : Make your pocket bike quiet
1. go to your harware store and get some steel wool
2.take off your muffler tip and take the stock stuffing out
3. fill the new space with the steel wool (pack it in there)
4.put everything back together and enjoy your new quiet exhaust
  #2
Old 01-09-2011
someonec someonec is offline
Re: How To : Make your pocket bike quiet
What kind of performance have you seen with this kind of exhaust packing? Any decrease?
  #3
Old 01-09-2011
SpyGuy's Avatar
SpyGuy SpyGuy is online now
Hooligan
No noticeable decrease in performance. I've done the same mod on my own bikes, and it seems to work just as well as the standard fiberglass muffler packing (and is cheaper to get your hands on).
  #4
Old 01-09-2011
CAM2 CAM2 is offline
Call Evil and it Appears
It reminds me of the steel wool flash bombs we used to make in shop class...a lil oil,,a bit of gas and a spark from the grinder is all it took to set it off with a nice flash and a mushroom cloud backup.....lol
  #5
Old 01-09-2011
SpyGuy's Avatar
Hooligan
*laffs* Figures you would post something like that!
Then again, I'm no better - not only did I grow up being a gearhead, I used to run with some of the renegade chemists back in college, and picked up a whole score of neat and/or nasty tricks ....
  #6
Old 03-19-2011
14U2NV 14U2NV is offline
How tight do you pack it in there?
I did the spray can mod and used #3 steel wool, but only noticed a very slight 1dB decrease in SPL and yes, I did actually use a dB meter (actually a RTA)...LOL
I packed it in pretty good, but figured that, if packed too tight, it would negate the effect of the larger can. I could pack it in tighter if necessary.
How much quieter were you able to get it using steel wool on the stock pipe and how tight did you stuff it in there? How many pads of steel wool did you use?
  #7
Old 03-19-2011
SpyGuy's Avatar
Hooligan
You don't need to pack it in too tight. I only used something like 3 sheets of #3 coarse steel wool. It lowered the annoying high-pitched whine down to a lower-pitched rumble, which was perfect for that bike. People really look at it when I start it up. (Then again, maybe it's not just because of the spraycan exhaust .... the whole bike is really something to look at.)
  #8
Old 03-21-2011
EPR's Avatar
EPR EPR is online now
Outlaw
What packing, most of my pipes had Nothing. I am going to start a You Tube account my son has one. You should hear my A2 Avatar bike, w/ my $535 B/B FC crank racing engine, and the straight pipe with no exspansion chamber and a big baffle muffler that I modded, its Loud & Nasty. The best part is there is nothing to take apart and it is chrome plated so no Paint.
  #9
Old 03-22-2011
DJ_Critterus's Avatar
DJ_Critterus DJ_Critterus is offline
EPR, what else comes with that fatty pipe you have to mount it? Does it only mount on a heavily modded engine or can if be placed on a semi-stock/stock motor with what looks to be a header that's not pictured?
  #10
Old 03-23-2011
EPR's Avatar
Outlaw
Thats, the Pro Jet SS Rep pipe I took off the A2 and put the HP Big Muffler Pipe on, and The U pipe is not in the photo. I was using it to compare the pipes. The pipe was on ebay, for $8.99 and $14.95 S/H, or $23.95 to your Door, and its chrome, how can you go wrong?? I got a twin muffler pipe for the same price.
The Jet or the Big M mount to any Cag engine. On the Jet it has a head pipe then everything else is held by springs.
On the Big M, it is supposed to mount under the seat on the cross brace of a F1 or F2, so I had to bend the rear mount piece into a U shape, and mount it where the stock on goes. On the dual M it nounts the same way on the bar running acrossed the back, so I will have to make a bracket to mount the rear.
  #11
Old 03-23-2011
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Seņor Member!
i attempted to pack a home made muffler, but while i was riding, i noticed something dragging.
a ton of pink muffler packing!!! streamers!!
  #12
Old 03-26-2011
jaloos's Avatar
jaloos jaloos is offline
GHETTO FABRICATOR
On my bike I used a piece of threaded rod. Use some double nutting and it worked out great.
  #13
Old 03-27-2011
EPR's Avatar
Outlaw
I have a big vise and hammer, for exhaust work, every different exhaust I have bought, had to Mod it somehow to make it work.
  #14
Old 03-27-2011
SpyGuy's Avatar
Hooligan
Originally Posted by Bluethunder3320 View Post
i attempted to pack a home made muffler, but while i was going down the street, i noticed something dragging.
*nudges BlueThunder* Psst ...... Hey, ya gotta put the endcap back on the muffler before ya runs it. Just sayin' .....
  #15
Old 04-04-2011
Seņor Member!
yeah right. well it was a ryobi weedwacker box muffler. i guess its not meant for that!
  #16
Old 04-06-2011
SpyGuy's Avatar
Hooligan
Well, duh ...
Not to worry ... my Re-Cycle bike is running a Tecumsah mufler on a 2" header pipe .... and man, it sounds vicious when I fire it up. I was originally running a goped muffler on it, but apparently when I welded it up the first time, the muffler was hanging just a little too low .... About a week or so later, a solid hit on a big rock took care of that problem - oops! After that, I went to the Tecumsah.
  #17
Old 04-06-2011
saddleup7's Avatar
saddleup7 saddleup7 is offline
Would there be a difference in results between a 2 stroke and 4 stroke if the above silencing trick was applied?
  #18
Old 04-07-2011
EPR's Avatar
Outlaw
You need good back pressure on a 2 stroke, on a 4 stroke like my Kawasaki 1000 drag bike we had 3ft of pipe off the engine, slashed on the ends, no muffler at all.
  #19
Old 04-08-2011
saddleup7's Avatar
Got any pictures?
  #20
Old 04-09-2011
SpyGuy's Avatar
Hooligan
Ah, zoomie drag pipes ...... so much fun. Were you shooting flames out of the ends?
You may not post replies
Forum Jump
Powered by vBulletin
