Go Back   Pocket Bike Forum - Mini Bikes > Misc > HELP! Ask our shadetree mechanics
Pocketbike Forum
Top 10 Threads
Looking for wire diagram for 49cc cat eye pocket bike
x7 Help needed
49CC Quad starting & idling problems
49cc cat eye problem:)
my bike wont accelerate
Cant get my bike to idle
X19 wont start! Helpp!!
no fuel to carb, help!
How to start Pocketbike without Pull start!?!?!?!?!?!?!
Pull start cord not winding back up.
Old 02-28-2011
johnbs8 johnbs8 is offline
3hp snowblower motor for pocket bike
i have this 2 cycle tecumseh 3hp motor from my old snowblower. it works great. just curious about if it will work for a pocket bike. my concern is that there is no needles or a adjustable throttle on it. on the snowblower it just runs fixed speed. is there a way to make this work or is there a carb upgrade available for engines like this?
  #2
Old 02-28-2011
CAM2 CAM2 is online now
Time for WHAT?
Re: 3hp snowblower motor for pocket bike
Techumseh makes a pumper carb on the Techumseh TC210 I beleive...That engine is 3 hp aswell and will work with the engine angled into a few different positions to fit....
The carb on your engine probably has a spring that holds the throttle flapper wide open but to hook up a throttle to it would be crazy as you would have to full throttle it to get it to idle and basically work the throttle backwards which is mega dangerous if you lose hand control or fall off......
  #3
Old 02-28-2011
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Seņor Member!
yes, it will work. im not too sure of the performance, though.
someone from another forum has mounted several industrial 2-stroke on go karts, here is a picture of one of his karts.
DIY Go Kart Forum
post some pics of the engine you have. has to have a keyed shaft.
You may not post replies
Forum Jump
Powered by vBulletin
Style design by Leo
