X19 wont start! Helpp!! - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Misc > HELP! Ask our shadetree mechanics
Looking for wire diagram for 49cc cat eye pocket bike
49CC Quad starting & idling problems
Four wire key switch bypass
How to start Pocketbike without Pull start!?!?!?!?!?!?!
Pocket Bike, Wont Accelerate Bogs Down,Stops?dies
49cc cat eye problem:)
x7 Help needed
my bike wont accelerate
trying to repurpose a exhaust manifold
Old 09-08-2011
spbriderx19's Avatar
spbriderx19 spbriderx19 is offline
Okay so im new to this pocket bike stuff i just got an x19 not new its an 06 automatic i bought it used off off some guy and it worked great the first day no problems then took it for a ride yesterday morning it ran great for a lap around the block as soon as i slowed down it turned off and wouldnt start back up??? what can be wrong? I bought a new spark plug changed the oil and nothing.. i tried to check for a spark but idk if i did it right because i got no spark but when i go to start it with the electric start it sounds like its about to start and when i give it gas it sounds like its reving a little bit but wont start... PLEASE HELP I HAVE NO IDEA WHAT COULD BE WRONG
  #2
Old 09-09-2011
patthehat033's Avatar
patthehat033 patthehat033 is offline
Re: X19 wont start! Helpp!!
Go to where your coil is mounted on the bike and make sure both wires are connected to where they are supposed to be on the coil.
It could also be a carburetor problem, but it sounds electrical try it tomorrow and see if it fires up.
To test spark, take out the spark plug, clean it off as best as possible, and then take your spark plug wire and put the spark plug in it. Then ground the plug and wire to a part of the head of the engine that is not painted (a bolt will work if its not rusted). Then crank the engine and see if a blue spark passes the gap of the spark plug.
Also another easy way to figure out is to pour just a tad of gas into the spark plug hole and then reconnect the spark plug and wire and crank it and see if it fires a few times. If not you have an electrical problem you need to troubleshoot.
See if all your connectors and wires are all connected and nothing is just hanging out.
  #3
Old 09-09-2011
Okay i looked at the magnetor or whatever it looks fine i looked at everything and dont really know if its wrong but i took a video to show what its doing maybe this will help.. also im not getting a spark i dont think.
HERES THE LINK:
http://www.youtube.com/watch?v=-qGR70x8wG4
  #4
Old 09-09-2011
Alright, it could be an electrical problem. But first before we go any further in diagnosing this, put just a slight bit of gasoline into the spark plug hole and put the plug back in and the wire back on and fire it up. If it still does not start you have an electrical problem.
Is there another connector that is also just laying out? I am guessing that goes to the rear or front lights but since you do not have those anymore it is not necessary to plug that into anything.
  #5
Old 09-09-2011
Also the little black oval thing with the green wire mounted to it, is the coil. Is the green wire actually attached? In the video it looks like it is ripped or something? If you don't know take a pic of the wire and I'll tell you if its fine or not.
  #6
Old 09-09-2011
Ok I did another video I figured that's easier to see it but I didn't try putting gas in the spark hole yet because I'm not getting a spark at all so I feel it wouldn't do me any good but the video shows the green wire and everything clear so let me know what you think after looking at the video.. I really wanna get this thing started it worked fine the other day and I didn't touch any of the wiring or anything I changed oil and got a new spark plug that's it.
VIDEO:
http://www.youtube.com/watch?v=gR_gd...e_gdata_player
  #7
Old 09-10-2011
I am not a hundred percent sure what that plug is for, but it is possible your CDI is unhooked. Do you see a little black box that looks like this? http://www.scooterpart.net/products.php?id=529 and is it plugged in?
Your coil wires look good, your starter solenoid is fine (which is the other black object you were looking at in the picture that had 4 wires connected to it.)
Otherwise I would really recommend putting in a little bit of gas in the spark plug hole and see what happens, sometimes it's just a surprise.
Also is your spark plug clean and gapped at 0.025" +- some?
  #8
Old 09-10-2011
EPR's Avatar
EPR EPR is offline
Outlaw
Make sure everything has a good ground to the frame, even the battery, No ground, No work. You could have a bad coil or CDI also.
  #9
Old 09-10-2011
ASTALKER123's Avatar
ASTALKER123 ASTALKER123 is offline
VIDEO:
Pull the coil wire off the plug hang on to it touch the head with your finger hit the starter and let us know what happens.
  #10
Old 09-10-2011
Most likely its a carb problem. spray starter fluid in the carb and hit the key see if it turns over.
  #11
Old 09-10-2011
Don't do this or your in for a wild ride. If your going to test the coil use some really insulated plyers!
  #12
Old 09-10-2011
CAM2 CAM2 is offline
Call Evil and it Appears
Do an ohms test on the stator to make sure its generating proper power........
In your vid the plug with 5 wires is for your gear shift selector....If you have a full auto bike it wont be hooked up as the full auto bikes are 1 speed..........
The turn light buzzer was most likely removed to kill the annoying beep which results in inoperable blinkers.......buy a 2 prong 12volt regular duty 80's Gm car flasher and hook the two wires to the two prongs..that will get the blinkers working.............
the round thing is the starter solenoid...its a high current relay to bump the starter.................
  #13
Old 09-10-2011
Thank goodness Cam comes to save the day! Haha he'll lead you in the right direction.. by the way I got my valves adjusted correctly, bike runs great.
  #14
Old 09-11-2011
Come on man. He would have know forsure if he was gitting fire. LOL
  #15
Old 09-11-2011
^ You have a point
  #16
Old 09-11-2011
Nice job man.............
  #17
Old 09-11-2011
Ok I tried putting gas in the spark plug hole and starting it up and nothing still just sounds like it's gonna start but not starting... what parts could be bad that I'm not getting a spark? I don't wanna buy all new stuff just to find out it's not the reason the bike won't start..
Also how do I do an ohms test?? (stupid question I know)
  #18
Old 09-11-2011
Please specify what you mean by "It sounds like it is going to start." Do you mean it fires once or twice? If it is firing once or twice your spark is fine, you need to do some carburetor work which we can lead you through.
To do an OHMs testing you will do exactly as Cam's picture says to do. Basically go to the side of your bike and you will see a half inch black wire coming out of your drivetrain. Follow that up to the little plastic connector, where it connects with the next set of wires. Then you will do exactly as the picture says and connect the red terminal (positive) of your voltimeter to the red and black wire of the plastic connector. Then you will put the black terminal (negative) of your voltimeter on the green wire or black wire that is not part of the plastic connector but is still coming out of the 1/2" wire.
If you look at the picture the arm of the voltimeter is set diagonal, set it exactly like that and it will read ohms, (unless your voltimeter does not look like that, but most basic ones do.)
Parts that effect spark: Stator (Alternator), CDI (Black box, holds a charge of a couple hundred volts), Coil (Oval looking thing with green wire attached, and heavy duty wire coming out of it that leads to the spark plug, and then the spark plug itself which needs to be gapped properly and very clean.
  #19
Old 09-12-2011
Look at the first video I posted and I try starting it that's what it does
  #20
Old 09-12-2011
Then you are not getting spark. Did you try the ohms test yet?
You may not post replies
Forum Jump
Powered by vBulletin
