Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Mini Choppers
Pocketbike Forum
Top 10 Threads
Pics of your choppers!
apc mini chopper -pepboys-A&A
Tuning a 49cc 2 stroke
250cc V-Twin Scorpion Chopper
4 stroke chopper with 4 speed manual tranny
Homemade chopper
Mini Chopper 49cc Won't Idle, and Seems to be leaking gas. PLEASE HELP.
APC Mini Chopper Questions
lost my key
my chopper pic
Old 11-26-2011
Rat5000's Avatar
Rat5000 Rat5000 is offline
Exclamation 125cc Lifan chopper project.
Well I just got myself a new project/headache. So its a 2-stroke chopper with lots of plastic crap on it. But all that stuff will be coming off the bike, and I'm dropping in a Lifan 125cc engine. I already bought the engine just waiting for it to arrive, it come in a kit with:
26mm MIKUNI carburetor
40 mm Air filter
Kick start
Shift lever
Throttle cable
Clutch cable
Clutch lever perch
Engine Cover
Engine wiring harness
24mm Intake Manifold
Seal gasket and necessary nuts and bolts.
Brake lever
Ignition coil
CDI Box
Basic wiring diagram
But I'm stuck looking for the correct main wiring harness. Now the seller did say and so the others that the harness from CT70, CL70 mini trail bikes will fit the engine (Basic plug and Go thing). But the thing is that the engine is a kick start and not a electric start. Does it really matter?? And another issue is that which wire to which do I connect. So all I'm asking for a bit of help with electrical wiring (if possible pictures would be awesome). Now I'm not a electrician so wiring diagrams is like a new language to me. So pictures would be a great way to show me and help others to understand the basic wiring form the engine to the harness. But other than that I thank you all for the great help, and hoping for the best to finish this project with success.
  #2
Old 01-24-2012
duncanreed duncanreed is offline
Re: 125cc Lifan chopper project.
i just dropped a lifan 125 into my mini chopper but it has a few kinks to work out. do you know to increase the ride height of a chopper
  #3
Old 01-29-2012
Rat5000's Avatar
I really dont think you can make it higher, but I will be installing 2 small shocks to the seat making it sit bit more higher same time having a really smooth ride. Also did you finish the wiring part if you did can you please take some pics of all connections and such. I dont want to mess us the wiring part and burn everything to hell ))))
You may not post replies
Forum Jump
Powered by vBulletin
Style design by Leo
