clutch problems...???!!!! - Pocket Bike Forum - Mini Bikes
Go Back   Pocket Bike Forum - Mini Bikes > Pocketbike Tech Talk > Water Cooled Pocketbikes
Tuning a B1 China replica
Nick's Water cooled bikes.... MT-A4 ( C1 )
Just got my Banshee SHO starts Smooth but..
Best Chinese Water Cooled Bike?
Teaser - DM replicas from China
dellorto 19mm vs dell rep 19mm comparison
Best Pocket Bike to Buy
ZPF Replica on the way...
Banshee SHO Updates and Test Thread
ZPF Replica here now
Old 01-02-2005
pocketbikeboy's Avatar
pocketbikeboy pocketbikeboy is offline
i just got a zocchi clutch the whole upgrade...i was told to set the springs at 24.90mm well it did really good at 1st but i saw after awhile it was engangen earlier then when i 1st set it..i have the c1 with squinch down to .5 reed spacer,2 stage reeds, 17mm carb,and a 6/72 gear and it seems like it doesnt want to grab like it 1st did... so im not very impressed with this clutch it take me a good 45 yards to hit the pipe if not farther....if any of u guys out there can help me i would be thankfull......and oh yea the bike moves out when it hits the pipe i just wish it would do it from the get go...im 6'0 210 lbs
  #2
Old 01-02-2005
Method Man Method Man is offline
Junior Member
Check the overall diameter of the clutch, it should be around 78mm. What you are experiencing is a clutch that is engaging too early. It has nothing to do with the clutch. Recheck the springs tighten them down to 24.6mm, but check the diameter. Tom at DCminimoto said that the pads from Zocchi have been a little thick. I had to recheck also after he told me the diameter is at 77.8mm to 78mm. I removed a little bit of the pads, very small amount, and got the diameter to 77.9mm and the clutch engages perfectly around 9k. It works great.
MM
  #3
Old 01-02-2005
my springs where set at that i went to 23.8 today it rev alot higer but was doing the same thing....overall with the springs set at 23.8 is 78.31 at the part of the pad that first touches the drum..seems like they are wearing down more than the rest of the pad on the oppsite side from the 1st part that touches it is 77.31...so i have on part of total a 78.32 to a 77.31... how long does it usally take when u hit wot to get up to full speed
  #4
Old 01-02-2005
Junior Member
Do you ahve a 2 or 3 shoe clutch? I have a 2 shoe...
My C1 is similar to yours, it feels sluggish then comes on like a freight train. The powerband kicks in around 9,5k. Its the nature of the beast. I think that you have gone too much the other way now. It is difficult to tune the clutch without a tach, you really need one, otherwise its like finding a needle in a haystack. If you compress the spring beyond its tension limit, it is like loading up the suspension in your car, there is no more rebound. It is the same with these springs. I was told that beyond 24mm loads up the spring tension, and beyond 25mm is like jacking your car up on stands, 24mm to 25mm is the range. Its not much it seems. I have a tach and it helps eliminate the guess work. Just start all over and reset in the middle at 24.5mm, and measure the total diameter, the distance between the pad and the drum should be 1 to 1.2mm.
  #5
Old 01-02-2005
at my thinest over all i have 2.35 distance at my thickest i have 1.32 distancethats with my springs set at 24.58 so what do u have done to yours and how much do u weigh...from the vid that jimmer got i want mine to run like his
  #6
Old 01-02-2005
Junior Member
It sounds like that one of your pads has worn more than the other, your springs are equal?. I think Jimmer pulls up on the bars and leans back a little, take another look... I weigh 185.
  #7
Old 01-02-2005
yep all is equal imma sand the pads and equal them out!!!
  #8
Old 01-03-2005
triks's Avatar
triks triks is offline
Thumbs up
ok set spring tension too 23.45.. ok another factor with upgrade is have you replaced clutch drum?
From jimmers C1 vid it was going but my bike sounds/moves better an pulls some serious wheelies with ease i'm 14 stone...running polini clutch
  #9
Old 01-03-2005
jsigone's Avatar
jsigone jsigone is offline
did you replace the clutch drum yet? if not, maybe ur drum sucks and it's not 80mm all the way around. If you already have the new drum, you should set the clutch to engage around 8400-9600 RPM. I have mines set at 8900. I'm 6'2 and bout 205lbs. My clutch measurment is about 23.5mm
  #10
Old 01-03-2005
chaos321's Avatar
chaos321 chaos321 is offline
Man, your bike must haul a$$ with you on it. I picked up 14 stones from the drive way and they were only 5 lbs. Exactly how heavy are rocks in the UK?
  #11
Old 01-03-2005
it was a whole kit like the one dc mini moto sells.. and i tried loweren the springs to 23.80 it didnt help any at all
  #12
Old 01-03-2005
jsigone's Avatar
get a tach to set the clutch. If u keep trying this trial and error stuff ur bound to heat up the pads and wear then out fast from premature engagments. The clutch needs to engage at about 9k, where as the stocker engaged at 8000-8200rpm.
  #13
Old 01-03-2005
where can i fine a tach that wont break me!!! i used to have a digatron when i raced go karts but i sold my whole operation
  #14
Old 01-03-2005
Obpr's Avatar
Obpr Obpr is offline
Retired Mod and Racer
ask around at the kart shops, i found a used mychron lite mcr for $20
You may not post replies
Forum Jump
Similar Threads
clutch problems!!!! dmicgrif Air Cooled Pocketbikes 23 08-26-2005 10:48 AM
Clutch Problems RossiniF1 Air Cooled Pocketbikes 8 02-03-2005 08:12 AM
B1 Clutch problems!!! MB_Melvin Water Cooled Pocketbikes 28 10-24-2004 03:46 PM
clutch problems #mikey# Chat 0 10-19-2004 03:33 PM
clutch problems geebzter808 European Pocketbikes 1 09-06-2004 06:34 PM
Powered by vBulletin
