Mx650 forks - Pocket Bike Forum - Mini Bikes
post #1 of 14 (permalink) Old 04-28-2019 Thread Starter
Mx650 forks
Has anyone fit another set of forks on? The stock ones really suck..
FORCE is offline
post #2 of 14 (permalink) Old 04-29-2019
you can adapt some down hill mt bike forks you need the mt bike disk and brake claper to make it work prepare to open your wallet
MrKitty is online now
post #3 of 14 (permalink) Old 04-29-2019
Re: Mx650 forks
Seeings they are similar to a gas powered pocket dirtbike the forks could be a better upgrade seeings both have a 10mm steering stem bolt.......
The MX500/650 front forks closely emulate the Oldschool Rupp minibikes and the Kawasaki M75 minibike with subtle differences too...Finding a really good set isn't cheap though...
PW50 front forks are a good consideration too..
post #4 of 14 (permalink) Old 04-30-2019 Thread Starter
Any clue where to shop for them?...ones I'm finding on Amazon are all the bigger hollow stem bolt like a traditional motorcycle
FORCE is offline
post #5 of 14 (permalink) Old 05-01-2019
Re: Mx650 forks
Vintage minibike classifieds and ebay..
On the ones with the hollow stem bolt you can unscrew the stem bolt and make an adapter to adapt basically any set of forks to fit any type frame...
Theres guys on the oldschool minibike forums cross breeding them with USD forks from pitbikes..........
https://www.popscreen.com/prod/MTgxM...-Old-Mini-Bike
These are from a Rupp
Kawasaki front forks....
If you go with the pocketdirtbike front forks I suggest buying an extra set of upper and lower fork clamps and doubling up the upper and lower fork clamps for extra strength for that heavier e-bike...
post #6 of 14 (permalink) Old 08-22-2019
Re: Mx650 forks
Just modded my sons suspension...........heres what I did:
An XR50 stock rear shock lines up and bolts right on with the stock hardware after pushing out the bushings in each "eye" (end) of the shock and replacing with new 1/4 x 5/8 x 3/4 bushings from ACE hardware ($2.99 ea). This raises the rear about 2" and gives a much softer/smoother ride with more travel. I had one laying around from other builds Ive done but the stockers are cheap on ebay (or any other pitbike shock).
For the forks.......
Theres a hole in the bottom of the forks where you can put a VERY LONG allen head tool (I had to make one using a hex apex and welding to a long metal rod with a nut welded on the other end) Remove these 2 bolts and the 2 bolts on top of the forks to disassemble. The white nylon bushing that keeps the inner fork tube stable can be compressed using small screwdrivers to pry it out after you pull the fork tubes out. Replace the bolt you just removed with a longer bolt (length depends on how much longer you want it to be/how long your new springs are) I had to make my own bolt as my local stores didnt have anything long enough in the correct thread. (I simply cut a bolt in half and welded in a metal rod to make it longer) You will find a rubber tube inside the spring in the forks when you disassemble. You dont need it. I cut this (1/4" length) and put it under the head of the new bolt to keep the bolt from slamming on the rebound of the fork. (thats the banging noise you hear on your stock forks. Older dirtbikes with spring forks used a rebound spring in this place....you could do that too. Make sure to account for this added length when choosing/building a new bolt) I cleaned/greased up everything and then reassembled using a longer spring I got from ACE. I dont know what the stock spring rate is but I bought the closest thing I could find in the same diameter/spring rate & length I wanted. ($2.99 ea) Put it all back together and you end up with the forks balancing out the rear end for ride height. The new seat height is 27". (Not sure what stock was) This made the bike waaaaay more fun. Even just riding around in the grass, you dont feel any of the little bumps etc..... With the added leverage, stoppies become easy. Super cheap mod!!
I also had a KX60 rear brake lever laying around so I fabbed up a bracket and cable to add a rear foot brake for it. Welded on some metal to widen the footpegs and sharpened them up. Hit me up if you have questions.
hubbyracing is offline
post #7 of 14 (permalink) Old 08-23-2019
Re: Mx650 forks
Good job! There's a whole lotta stuff you can do with a welder.
pntrbl is offline
post #8 of 14 (permalink) Old 3 Weeks Ago
Re: Mx650 forks
Where could one find a new white nylon bushing for the forks? Ours broke on one fork and is now jammed. Canít find specs for a replacement.
Directorjohn is offline
post #9 of 14 (permalink) Old 3 Weeks Ago
they dont sell individual fork parts for the 650 unless someone is parting them out you should try and sorce some used forks for parts or contact razor for a new pair.
post #10 of 14 (permalink) Old 3 Weeks Ago
https://youtu.be/rylbFnTgFI8
Re: Mx650 forks
Could anyone please supply a link to any better spring just like how HUBBYRACING was able to obtain? Or any other better recommendations to make the MX650 perform better? Or any other better fork that directly bolts in???
rockstar195 is offline
this very exspeisve mod where they use down hill mountain bike throw axial air forks with a mountain bike throw axial hub laced into a BMX double wall rim then you can use the mountain bike disk brakes a BMX goos neck and low profile BMX bars
you have to buy the forks new once the head tube has been cut to fit a mountain bike the head tube will be to short for a MX 650
dont even try to use a cross country fork it will snap you have to use ones rated for down hill mt bikeing
bearings cup sizes shims spacers and all of that fun stuff depends on the forks be prepared for lots of trial and error sence all mountain bike frames are difrent its trial and error on bikes as well
its not worth it IMO ($$$ to $$$$) unless you have down hill MT bike parts laying around...
post #13 of 14 (permalink) Old 10 Hours Ago
Re: Mx650 forks
Thanks, but not an option for me.
post #14 of 14 (permalink) Old 6 Hours Ago
i will stop by the ace hardware today and see if i can find the springs they used
MX650 mods? filitup Electric Pocketbikes 1888 1 Hour Ago 04:08 PM
Razor MX650 Won't Run John_crawford39 Electric Pocketbikes 6 08-29-2013 10:56 PM
New guy with mx650 chili3 Electric Pocketbikes 8 10-23-2008 10:31 PM
modding mx650 grim3vil Electric Pocketbikes 2 10-02-2008 09:10 PM
MX650 (again ... sorry !) Orphee Electric Pocketbikes 3 04-09-2008 08:40 AM
