MX650 mods? - Page 11 - Pocket Bike Forum - Mini Bikes
 4Likes
Re: MX650 mods?
i got ever thing coneted and i don't no how to do the throtel wire
mud fest boy is offline
Re: MX650 mods?
which throttel do you have? Which controller did you upgrade to?
Red usually goes to red
BLack usually goes to Black
Blue usually goes to Blue or Green.
THe other two wires in the existing MX 36 Volt throttel
I dont think are used. I also dont know if the throttel
will still light up and show power status.
But the throttel (if wired properly) will make your motor spin.
Did you get the YK42-4 or the lb37 or something different.
cruh
cruh is offline
Re: MX650 mods?
Okay I'm brand new to this forum but excited to join. There is a lot of discussion about different mods which has been fun to read
Like most newbies, I ask what is the best mod to start with?
1) A simple 13 tooth motor sprocket change?
2) extra battery with 48V controller?
3) go for it all at once, battery, controller and larger motor?
I read about problems wiring up the new controller to the stock twist throttle, etc.
I want to have my 12 year old son do the work so he can learn. Any advice on the best place to start would be great.
Thanks
millhaus is offline
Re: MX650 mods?
Hi, to tell you the truth i dont remember most of this stuff because it was just a little play bike but now im getting really into motocross so i really dont remeber everything i did but here is it, 48 volts, new controller, bigger motor and i left the sprokets alone.
amhman22 is offline
Re: MX650 mods?
Originally Posted by andyS View Post
that motor is a good one. I believe it is actually the same as the 800 watt motor that was used in the Rad2go White shark scooter-one of the most powerful stock motors ever put on a cheap scooter. What controller did you end up running-the 60 volt Xtreme??
My son loves his bike with the same motor and 48 volt set up and stock gearing. he can take off very quickly, goes 25 on the straight, 20 up fairly steep hills, and tears it up in the dirt. What amazes me is he can also go way over 10 miles on a charge at full power. The motor doesn't even get warm with him riding it. I have had to hop up my ride a bit more so I can still hang with him!! I just put a 48V 12AH LiFePO4 battery in my ride. Man, those things pack a wallop for their size and weight. 25 pounds lighter than 4 12V 12AH Lead acid batteries.
**can I just install a motorcycle battery to it? is that what you did? :-/
blakravhen is offline
Re: MX650 mods?
did you have to buy a new charger? miker71
mx650guy125 is offline
Re: MX650 mods?
INTERESTING THREAD
smokinxtreme is offline
Re: MX650 mods?
im having a hard time finding a 1200watt motor......please help
Re: MX650 mods?
probley wont find one but u
can get a 1000 watt 48 volt or 60volt from monsterscooterparts.com
or tncscooters.com
Chip
Chip Douglass is offline
Re: MX650 mods?
or tncscooters.com
Chip
and would those work as a direct swap or does it have to be modded to fit like the 1200.........thanks
Re: MX650 mods?
its about 1/2" wider so you have to mod?
Re: MX650 mods?
Where can you buy sprockets for the stock motors/replacement motors from tnc scooters? I need some front sprockets that would be good for riding around in grass (i.e. smaller than stock).
What are the stock sizes of chain and sprockets?
Will there be a jump in performance if I switch from the stock 500w to the tnc 750w and that is all?
prologue is offline
Re: MX650 mods?
This is what I did:
Razor Minichopper, 250W motor, overvolted to 36V on the stock controller.
She had NO TORQUE ats all. Literally. I couldn't make it up my driveway going full speed (and then pretty much ramping up my driveway).
People burnt these motors out (from what I read on PBP), and many agree that those motors have awful power.
I switched to a 750W motor, and 48v controller + 8 batteries. Stock gearing (just like before), I could now ride on grass easily. However, speed was still so-so ish, torque was phenomeonal considering what I had lived with before (250W)...
And then I put 60V on it. Now I can ride through virtually anything! No matter how thick the grass, it doesn't stop pulling
oscaryu1 is offline
Re: MX650 mods?
Thanks for the reply but where do you get sprockets? And what sizes do they come in? I have heard of down to 8 teeth on the front but can't find anything that small at TNC. What is the stock size (front) on an mx500?
Also, is it a #25 chain, or the 8mm type?
prologue is offline
Re: Travis is back soon!
Originally Posted by 48voltmx650 View Post
Hi Everyone I'm Back,
I know it's been a while but yes, I have continued to modify my 2-MX 60 Volt 1,000 Watt Razr Dirt Bikes!
I am still waiting for my motors to arrive but I still have been working on them once in a while.
I welded 6" front fork extensions on the front ends of my Dirt Bikes down where the brake calipers are located. I did that because I added even longer and larger 12" rear shocks that raised the back end up to high. My bikes stand up as high as full size motocross bikes now! Now I will be able to jump a lot bigger jumps without bottoming out!
I also added an additional 5 more amp hours to my previous 12 amp hours bringing me to 17 amp hours of ridding time!
I have also murdered out my dirt bike rims to Gloss Black for a more aggressive look with Dupont Paint!
I will post my updated photo's when I get my motors in, hopefully within the next month!!!
how did u get your parts and where did u get them??
cause i want 2 make my mx 650 higher! pleas reply!
kevinsmith mx 650 is offline
Re: MX650 mods?
i would like to make my mx500 into the mx1200 would u know any stores that would do the welding and stuff
alrules is offline
Re: MX650 mods?
Hi!
I bought the upgrade to take my Son's MX 500 to a MX 750. I don't understand how to connect the new controller... I think it's the throttle (deraileur) that has 3 wires on the new controller but 5 on the old one. I'm not sure what to do with that. Any ideas? I would REALLY appreciate help
h.r.venus is offline
Re: MX650 mods?
red > red. black > black. blue/green > blue.
NecessaryEvil is offline
Re: MX650 mods?
wiring - the biggest problem is there was a 5 wire derailleur in the old controller - this one has a 3 wire one. I'm thinking I need to combine 2 of the other wires to it
old: yellow, red, black, black, green
new: red, blue, black
arggghh!
Re: MX650 mods?
You dont need the yellow and one of the blacks. Attach red to red, black to black, and blue to green. If it doesnt work then switch the black wires and it will for sure.
