whip cream chargers - Pocket Bike Forum - Mini Bikes
post #1 of 19 (permalink) Old 07-16-2006 Thread Starter
whip cream chargers
hey i need some help on where to get those little n2o bottles because i want to make my own n2o kit, so can you get them at like walmart or like a grocery store and help would be appreciated.
derek920 is offline
post #2 of 19 (permalink) Old 07-16-2006
iridenaked14's Avatar
Send a message via AIM to iridenaked14 Send a message via Yahoo to iridenaked14
Re: whip cream chargers
no u cant get em at wally world or any place of that sort the only place i could think of 2 get them is on the internet, specifically ebay
iridenaked14 is offline
post #3 of 19 (permalink) Old 07-16-2006
Try some paintball/airsoft sites, they might carry them in little 3 oz bottles. I was thinking about this earlier myself, but I never followed through with it. You could take one of those bicycle pumps( the handheld ones) that use the little 3oz co2 canisteres, and instead use a N20 bottle. Then you could rig a hose from the air intake, to the handlebars where you could mount the bicycle pump.
Lastshot is offline
post #4 of 19 (permalink) Old 07-16-2006
StealthRTSC's Avatar
Send a message via AIM to StealthRTSC Send a message via MSN to StealthRTSC
worthless been there done all this Its very hard to tune to the different Pressures from the Whip its. I haev burned up a piston testing and tring to figure out a safe way to use them. its just not worth a motor over lean mixture when u haev a Higher pressure whip it then u are tuned for. also u can get then from a cake supply shop.
StealthRTSC is offline
post #5 of 19 (permalink) Old 07-16-2006
Mblough's Avatar
Images: 4
havent done it on my bike but seen it enough and read about it here even more. not something you want like stealth said it raises the odds of you blowing your engine.
give the search a try and youll see what we're saying lots of success initially that ends in ruined pistons/engines.
Mblough is offline
post #6 of 19 (permalink) Old 07-22-2006
125ccCRazy's Avatar
Images: 10
Send a message via Yahoo to 125ccCRazy
we ran the whippet C02 nitrous set up on my son's cat last summer with the 49cc 2 stroke, my son must have went through 50 cartrages with not a lick of trouble, the motor ran just as strong at the end of the season as it did right after the NOS was installed in the spring....I injected the nos in the end of the cone airfilter....We ran it right out of the 1/4" hose that was hooked to the handle....I just richened the top end a little more but not too much where the engine ran crappy without the nos at top end....
If you burned a piston I'm guessing you had a stock carb with i=only one ajustment or you just leaned the engine too much....
125ccCRazy is offline
post #7 of 19 (permalink) Old 07-24-2006
walbro carb (WT603) tuned fat up top.
post #8 of 19 (permalink) Old 07-30-2006
Tommy Pantsdown's Avatar
You can buy 25 packs at adult video stores all over Ohio. That's the only retail place I've seen them.
Tommy Pantsdown is offline
post #9 of 19 (permalink) Old 02-27-2019
Yes you can use n20 nangs but you have to buy the bigger dispenser that the nangs release into so its not so potent because if you do it straight from the little bottle in the boost bottle thing you only get 8 to 12 shots n ya blow ya motor but if ya use the cream dispenser it doubles in amount so you can sting for longer while using n2o and it isn't as potent but you have to put lil bit of fuel 10ml in the bottom of dispenser so when u release nitrous into it when u are finally riding and go to use that shot of No's it works like a wet shot of nitrous which is what u want because if its dry (n20 in dispenser without the 10ml fuel) ya crankshaft piston and that combustion chamber is all gonna dry out instantly while still igniting and your engine is going to cease up but just heads up when ya do this be careful and no matter what if you hit that shot and have to turn ya bike of it ain't gonna happen becoz that engine is gonna keep cranking becoz its will b still oxidizing burns real well I did it on a cag with dry shot bent the back sprocket n I smashed knees n arms n slide up the road but it shoved out good idea to use it once your in ya topend speed not good for take offs becoz it can crank ya piston n that backwards which can b dangerous if **** hits the fan when ya stingin along hope this help
Chris Jones is offline
****...You seem to like to bump some old threads.....LOL
I love when these discussions come up and people swear whippetts cause time warp syndrome....LOL
As far as all of what you said....I just have some other things to say but Ill start off by saying ;-"huh...?"
Seeings food grade nitrous is 100% pure tell me how anything can huff 100% pure nitrous which is conceived as an oxidizer and not suffer the effects of oxygen deprivation like what happens when its huffed?..
That makes food grade nitrous more nitrogen based than oxygen based wouldn't it?...
Another question is how can 8 grams of nitrous kill an engine or reverse its rotation???
There's differences between medical grade,,food grade and industrial grade nitrous...
Medical grade is the purest and must have oxygen added to prevent hypoxia,,
Food grade contains an oilly residue and will cause hypoxia aswell..
Industrial grade nitrous is synthesised by heating ammonium nitrate which is a poison..
You want more bang for your buck...17:1 compression & Methanol / alchohol mix...Plain n simple..LOL
whip its all so has confectioner sugar added this makes whip cream yummy but engines dont like it and it gums everything up and those carts dont hold enuff to make any real power...
I love double headers....LOL....wow...IDK where you got that info from..
Food grade nitrous is tasteless and odorless...That's why its used as a food grade propellant...
The air we breathe is 70% nitrogen ;- is it not??
The sweetness of the cream and ingredients added to Redi-Whip is what tastes all yummy...…….LOL
Reddi Whip’s main ingredients are cream, water, and sugar
Ok the way I had it setup right is through the intake manifold that was on a lucky 7 cag they way it worked when you put the cream charger in the dispenser its pretty much traps oxygen in there when ya put the lid on so when the nitrous is screwd in and released in dispenser turns into a less potent gas but your still getting as much oxygen as u were but when ya squeeze dispenser with ya leg it sprays and the engine wouldn't cut out becoz of lack of oxygen still getting oxygen but nitrous is highly flammable when I used it n the sprocket bent n I slid up the rd I hit the kill switch engine was still cranking over it was still igniting n burning the rest of the gas in the chamber and bro I can tell ya now doesn't matter what grade nitrous oxide u were to use it'd do the same just some would b better than others so until u know what ya talking bout and experiment with it ya self to actually have a point of view anyone can copy n paste facts of google mate go n actually try it ya self then myt listen to ya all that **** u copied to try n put me on show makes u look like the bigger ****head lol go get ya hands dirty working on ya bike champ!!!!!!!!/
lol lol ok ill try it
allso be nice to other members and dont cuss at people or i will have to ban you...
Nice comebacks...Those who cant build a real 2 stroke engine believes in cheap novelties I guess...…..
Your silly explanation doesn't explain how nitrogen based material becomes an oxidizer adding oxygen to it but I guess your a better scientist than me...Real nitrous oxide is synthesized through heating ammonium nitrate which produces nitrous oxide which is a cryogenic oxidizer....Whipped cream chargers are 100% nitrogen based ;-no oxidizer.
Also how do you compensate for the loss of the whipped cream ingredients inside the whipped cream chamber...?Let me guess you add a couple golf balls or double up...Its pretty impossible to double up ..Theres no 1 way check valve by the time you unscrew reload then rescrew down to release more gas the stuff inside will be nothing....
The loss of the liquids lessens the pressure effect even more than it already does as if it didn't the cream would spray out like a rush and be uncontrollable....
I guess they also design those things for being connected to minibike carbs and deliver enough pressure to be effective to make a 2 stroke minibike a supermachine..
8 ounces doesn't go far in a totally empty container but I guess youll have some snippy comeback instead of accepting failure from my first reply....Now youre in even deeper now..LOL
Only way to shut me up is to prove it by posting a video but let me guess the engines now spent....LOL
As far as your comment about "getting my hands dirty".....dude;- you better look up the person you call out because youre the kind that likes to leap before he looks and that can be dangerous besides you cant swim in my pond Champ jr.....
Ive built more nitrous engines in the car and motorcycle world than you will ever dream of building and I use the real stuff.........LOL
You're a 100% joker....
My naturally aspirated junk will eat your nitrous junk alive every way all day long....hands down...…….LOL
Do you think I got my hands dirty enough???
File Type: jpg 025c1d6c-5596-4eef-846c-0211170df136_zpskvz4nkx0.jpg (106.9 KB, 1 views)
File Type: jpg droid%20phone%20pics%20vids%201045_zps9ecwk1su.jpg (225.7 KB, 1 views)
File Type: jpg 91a963bd-a2ad-4999-a4ee-7690761dd292_zpsvni6dwxq.jpg (112.6 KB, 1 views)
File Type: jpg 1ad1e46a-33e2-4167-abe4-a1d86dcd5678_zpsa3xqiopq.JPG (503.1 KB, 0 views)
File Type: jpg 11526_10201846645306305_1444995576_n.jpg (29.2 KB, 0 views)
it dosent go far when its connected directly to the intake with air shock line either 8 grams of N2O that was a complete wast of time
He'd get a better effect running the carb fat and using pure medical oxygen............LOL
Mines filled with the real deal automotive grade nitrous oxide though....The real deal zoom-zoom……….
This aint no novelty whipped cream charger setup...............LOL
yea man the stuff engines love
File Type: jpg 15519989584611890196578_1551998984369.jpg (300.0 KB, 4 views)
Yep...That be the stuff dreams of speed and extra power are made with..…"A real oxidizer".
I guess he never heard of "Oxygen Bars" either?..Its energizer for the human body...
This site can definately weed out the ones who actually learned in school and those who faked their way through............LOL
Its only natural to use sufficants in food products as it helps preserve the product...Colas have carbon dioxide gas, meats get treated with carbon monoxide to give it that nice red color and dairy type foods in pressurized cans are propelled by nitrogen based gas.......
I think I learned that lesson in 7th or 8th grade;-maybe 6th..........LOL
Me Flossin my whip X1 some cool pics Kingjsa 2Stroke Midbikes 12 06-06-2005 11:29 PM
Anyone have a link to some good quick chargers streetridaz Electric Pocketbikes 0 05-09-2005 11:30 AM
San Diego Super Chargers timelesswhite Chat 45 01-05-2005 05:18 PM
Battery Chargers iamzero 2Stroke Midbikes 3 09-19-2004 10:03 PM
