CVT transmission on X1? - Pocket Bike Forum - Mini Bikes
post #1 of 4 (permalink) Old 10-11-2004 Thread Starter
Images: 10
Can you put the CVT trans on an X1 bike. What exactly does the cvt do and does it give you more speed?
ryan2282 is offline
post #2 of 4 (permalink) Old 10-11-2004
Images: 6
Hey Ryan,
U can put a CVT on the X1 but don't think its going to be a piece of cake when it comes to installing it. My buddy had to do some triming on the bike frame so that the CVT casing would sit properly. My obersavation was that the x1/cvt did not show a big advantage over the non CVT x1 on the straight aways.
Over the weekend a group of us did test our bikes in what seemed like a quarter mile drag race and the best it could do was a consistent 32mph on a radar gun. The non CVt was hitting 31mph. The non CVT only had an airfilter and jetpro pipe. However, we speculate that it must have came with a true 49cc motor. There was just no way it could have been that ballistic on take off and top end. BTW; the x1/cvt was outfitted with a HP carb/filter/pacsale pipe and boost bottle. The riders were both of same height and weight 5"8- 160#
zumzum5150 is offline
post #3 of 4 (permalink) Old 10-11-2004
Images: 97
I did it to my x1 had to move motor plate forward cut off tranny mount ear attach 4th ear to motor plate notch rear frame for cvt cvt is longer motor has to go forward,chain has to be longer, output shaft in differerent place it can be done, if you have welder,grinder etc
trick jet is offline
post #4 of 4 (permalink) Old 11-15-2004
Yep , a Cvt When tuned right keeps your motor running in the powerband almost all the time, from the starting line to the finish. Its kind of like a 10 speed automatic tranny. I dont know how hard it will be to put one on, but it will help. There are lots of mods you can do to a CVT-Kelvar belt-less slip much longer life,overdrive variator-higher top end,stiffer clutch arm springs-delays the clutch letting you get a higher rpm take off, stiffer variator spring-holds the CVT in a lower gear ratio a little longer.You can do lots of to a CVT to make it quicker and faster
scottsboy is offline
CVT on an X1? PocketJoe 2Stroke Midbikes 5 04-23-2005 08:45 AM
X1 with X2 CVT, Now SLOWER!? Kingjsa 2Stroke Midbikes 25 02-22-2005 11:24 AM
Question about X1 with CVT tranny Setisg 2Stroke Midbikes 11 02-07-2005 07:33 AM
Can you put cvt on x1 from x2 tnk7313 2Stroke Midbikes 8 12-03-2004 01:11 AM
Transmission 2 or 3 speed or CVT wiwoodsman2003 2Stroke Midbikes 5 11-07-2004 04:02 PM
