wires to the coil - Pocket Bike Forum - Mini Bikes
post #1 of 12 (permalink) Old 11-06-2009 Thread Starter
wires to the coil
Cateye, 49cc.
It seems the spark is very weak. At times, non-existant. With the spark plug in its boot and removed from the head, I am touching the plug to the head. When there is a spark it is blue. (plug is new) I am using the electric starter to crank the engine. While the battery is weak, the spark would not be affected.
There are three wires to the coil. One is the ground wire. One is the high voltage wire to the spark plug. The third wire goes to the coil winding.
Am I correct in assuming that the third wire is normally open when the engine is running. But is grounded through the key switch when the engine is off? Perhaps that wire would also go to a kill switch if one was available.
The coil is very close to the flywheel... like you guys say, perhaps a business card away. I doubt it has ever been adjusted since the cateye hasn't had anyone mess with it but me.
Perhaps I need a new coil.
Thanks
Frank
Frankc is offline
post #2 of 12 (permalink) Old 11-06-2009
Re: wires to the coil
They stopped making 2 stroke versions of the cateye you have in 04/05 so its very likely you will need a new coil as they have a shelf life in years after initial useage aswell as a service life in run time hours...Whichever comes first becomes its demise.I beleive the service lifespan is 3-4 years or 300 running hours;-if you use it any longer than its operating on borrowed time and not too efficiently either
When no killswitch wires are touching a ground source the engine will run...If the wire going into the winding becomes grounded the coil wont spark..The reason why theres two wires is because one is the coil body ground and the other is the kill wire...You can use the 2 wire starter pushbutton on the throttle as a killswitch when pressed.........Peace
post #3 of 12 (permalink) Old 11-06-2009 Thread Starter
Thanks CAM2.
I ordered a new coil. Hopefully it hasn't been sitting around for 5 years already.
The off position of my key switch shorts out the kill wire to ground. So that makes sense.
I just need to get a reason to use the kill switch.
Thanks,
Frank
Frankc is offline
post #4 of 12 (permalink) Old 12-05-2017
i have 4 wires to the coil no cdi and reflector was not wired up can anybody help me i cant fing diag that works for my setup
BiGmIkE911 is offline
post #5 of 12 (permalink) Old 12-05-2017
Is this a 2 stroke or a 4 stroke?
You only need two wires for a kill switch....Its usually black w/white stripe and solid green.......
If its a 4 stroke and you dont know where the wires hook up lmk....
post #6 of 12 (permalink) Old 12-06-2017
to be honest im not even sure i just got it and just now getting into this hobby i can tell you ive been racking my brain to figure out what size motor also its electric start only 5 speed manuel transmission and has oil cooler its alot bigger then the reg pocket bikes any clues on where i can find out Im gonna try and up load cpl pics oh yea it has ducati coil and reflector would appreciate any help
ps sorry about grammarr and typing never been my friend lol
Big Mike
ok took me a while to figure out i needed to resize my pics lol
post #7 of 12 (permalink) Old 12-06-2017
The frame you have can be either X15 or X19 but the engine isn't a 4 stroke air-cooled engine...somebody put a 2 stroke engine in it...
Now you need to identify the year make and size to get a wiring harness with CDI box..
Can you get a shot of the left side of the engine now?
post #8 of 12 (permalink) Old 12-06-2017
Hope this helps you help me lol
post #9 of 12 (permalink) Old 12-06-2017
I t has a clutch so it has gears no kickstarter but has an electric starter....,,,,What does it say on the head?
it looks like it says SX109...........
I took engine out. Cleaned up a little and hear is a few picks on the other side of the head u asked about says gilardoni2
could it be a Minarelli AM6 possibly??
Minarelli is most likely a huge possibility....
I'm pretty sure Gilarardoni is Canadian...
https://www.tradebit.com/filedetail....-2s-am6-engine
http://beedspeed.com/html-pages/
