x1 transmission help - Pocket Bike Forum - Mini Bikes
post #1 of 27 (permalink) Old 10-23-2011 Thread Starter
x1too's Avatar
Question x1 transmission help
So I got my x1 pocket bike two months ago and it seemed to really have slow acceleration. I figured it was the transmission so I took of the plate and inside were the two sprockets with the double chain and also there was no oil just thick grease. I cleaned that out and poured in 30 wt motor oil until it was full and rode my bike like that. Oil would always leak out on top but soon stopped, I guess because it ran out. Recently I met this guy that has an x1 all stock but his bike is way faster and it burned out easily. Mine never burnsout and the acceleration is still very slow. Any ideas?
I appreciate the help.
x1too is offline
post #2 of 27 (permalink) Old 10-23-2011
Re: x1 transmission help
you need to do some weight reduction and perf mods then tune it in...........
post #3 of 27 (permalink) Old 10-23-2011 Thread Starter
x1too's Avatar
ok but what about my transmission? What oil should i use and how much do I pour in?
x1too is offline
post #4 of 27 (permalink) Old 10-23-2011
Some of them have a #25 chain and grease inside.
post #5 of 27 (permalink) Old 10-23-2011 Thread Starter
x1too's Avatar
not mine and it says "oil 100cc" on the cover. What is that supposed to mean?
x1too is offline
post #6 of 27 (permalink) Old 10-24-2011
StrayDawg63's Avatar
That's how much oil you put in it. You can use whatever oil you have from motor oil to gear oil
StrayDawg63 is offline
post #7 of 27 (permalink) Old 10-24-2011 Thread Starter
x1too's Avatar
how much is 100cc? Which is better 80w or 75w gear oil?
x1too is offline
post #8 of 27 (permalink) Old 10-24-2011
Either gear oil will be fine.
post #9 of 27 (permalink) Old 10-24-2011 Thread Starter
x1too's Avatar
and should I fill up fully or halfway?
x1too is offline
I use lighweight synthetic oil like 5w/20 Amsoil mixed with a lil white graphite chain lube......Heavier weight oils add too much drag..........Alot of others use just plain 30wt oil......
100cc's is as much as a shotglass full of oil............It isnt very much.....
post #11 of 27 (permalink) Old 10-25-2011 Thread Starter
x1too's Avatar
Thanks cam2 I will just use 30w i guess. And 1 more question should I clean my transmission with some degreaser and what is some good material to make gaskets out of?
x1too is offline
If you put too much oil the moving parts have swim thru the oil or power loss.
I seal my trans cover with plain old RTV...........To clean out the case You can use carb cleaner,,brake parts cleaner too............
I have a question. What is
rtv
joseph2116 is offline
Its an automotive type of silicone sealant.....For the transcover grey will work fine,,,black will too.....red is overkill
Its Permatex silicon, all different kinds, the black will work great for that, any auto store or hardware store will have it.
post #17 of 27 (permalink) Old 10-29-2011 Thread Starter
x1too's Avatar
thanks everyone for the info. I didn't get to the transmission when another problem occurred. My pocket bike was running fine until I changed the bolts that hold the muffler to the engine. i swapped the bolts and rode my pocket bike for like 10 minutes and it ran fine. I came back like a hour later and I couldn't start it. It usually starts in 2 pulls. I pulled the string at least 30 times when I noticed there was a puddle of oil in the black cover underneath the exhaust. I took out the spark plug and it was moist so I put it back in and thought that I had to much 2 cycle oil in my gas. I added some more pure gas into the gas tank and shook it up. Then I tried to start it and at first it was barely starting but eventually I got it going. I rode it down my street full throttle and noticed a serious decrease in speed and power. I dont know what to do.
x1too is offline
Make sure your lowspeed needle isnt loose and your highspeed needle didnt fall out................
post #19 of 27 (permalink) Old 10-29-2011 Thread Starter
x1too's Avatar
I have a stock carb with only one mixing screw.
x1too is offline
post #20 of 27 (permalink) Old 10-29-2011 Thread Starter
x1too's Avatar
ok never mind I fixed it and it runs great but won't idle when the choke off.
x1too is offline
