x1 transmission lube - Pocket Bike Forum - Mini Bikes
post #1 of 6 (permalink) Old 01-04-2005 Thread Starter
Angry x1 transmission lube
please can any help i would like to know what oil to put in the transmission of my x1 .the oil that came out was like strawberry jam .any idea ?
bazza is offline
post #2 of 6 (permalink) Old 01-04-2005
smn1's Avatar
Images: 81
my bike manual tells me
"maintain proper transmission fluid levels use 30wt NON-detergent oil"
also
"fill the clutch reservoir located above the chain sprocket. Remove filler bolt. Loosen bleeder screw located toward bottom of engin. fill top oil hole with valvoile 30w NON detergent motor oil part # 265 until oil seeps from bottom hole"
so I filled up both reservoirs with 30w Non detergent oil, I could only find Costal 30w non detergent at the auto zone.
Good luck
smn1 is offline
post #3 of 6 (permalink) Old 01-05-2005 Thread Starter
Lightbulb x1 transmission lube
also
Good luck
do you think automatic transmission oil would be ok ?
bazza is offline
post #4 of 6 (permalink) Old 01-05-2005
smn1's Avatar
Images: 81
dont think so.
smn1 is offline
post #5 of 6 (permalink) Old 01-05-2005
i use 80wt. gear oil in my son's X1 and seems to be ok.
db54 is offline
post #6 of 6 (permalink) Old 01-07-2005
ryan2282's Avatar
Images: 10
Just get some Royal Purple or other name brand 80wt gear oil. that is the best to use and all i have seen anyone use in them.
ryan2282 is offline
X1, X2..that much difference?? littlebikeboy 2Stroke Midbikes 11 05-16-2005 10:56 PM
X1 turns naked, project foxthor 2Stroke Midbikes 4 02-07-2005 12:22 PM
Buying a new bike... X1? Everlast 2Stroke Midbikes 35 11-28-2004 05:32 PM
CVT transmission on X1? ryan2282 2Stroke Midbikes 3 11-15-2004 09:35 PM
