EPRs GRC GP BZM Power - Pocket Bike Forum - Mini Bikes
post #1 of 10 (permalink) Old 06-09-2018 Thread Starter
The BZM rebuild is in and almost ready. Had a lot of small problems cause that engine has never been in this frame before. Had to find a throttle cable with enough free cable to hook to the Dell 'Orto 15mm PHBG carb, fuel lines and filter, and getting the exhaust hooked up.and working. Need to bolt down the seat and a few more small things and it should be ready.
Photos to come shortly.
post #2 of 10 (permalink) Old 06-09-2018
Re: EPRs GRC GP BZM Power
Looking pretty sweet EPR.............
Thats one of the crazy differences between the chinese stuff and the Euro stuff...Alot of the euro stuff is super custom tailored to its specific model....
Its like when I put the 2005 5.3 LS engine with Turbo in the 72 Nova that had a 307.....
The crossmember had to be cut and boxed-in lower and the trans tunnel had to be totally cut out and the firewall clearanced enough for it all to fit.....
It wasnt easy but well worth it in the end result.........
You've got the brunt of it whipped....Now its all downhill....
Good to see you making progress EPR....Keep up the Good job..
post #3 of 10 (permalink) Old 06-11-2018 Thread Starter
Bummer, the top of the old gas tank broke into pieces as I was installing the tank/seat cover, see photos. I have 3 new A2 tanks here, but as you can see the old one is not as tall, because it came with a Fatty Pipe and had a tunnel under the tank to clear belly. Can't find a new one anywhere.
Going to have to see if I can fit the new taller one, that old one is really brittle, it just falls apart now. Some of the great plastic compounds they make in China, lol, I was shocked at first, lol.
PS: Those socket head bolts to the right of the broken tank are Titanium.
post #4 of 10 (permalink) Old 06-13-2018 Thread Starter
Ok, to get the taller tank mounted, had to rap the exhaust belly with pipe heat wrap & SS ties cause the tank sits on it. Had to raise the seat level also to get the tank/seat cover to fit right.
Also posting a photo of the right side of the bike.
post #5 of 10 (permalink) Old 06-14-2018
That sucks once they start turning yellow they are getting ready to expire I had one fail well I was ridding befor
Nice job on the bike that engine is way over powered ( I see this as a good thing )
post #6 of 10 (permalink) Old 06-14-2018 Thread Starter
Rebuilding the engine was easy, putting it all together has been trying at times, lol. This engine has the 15:1 compression cap. I have another cyld / head unit with Gold racing cap w/ 17:1 which would need 105 octane gas, so i chose the 15:1 for now.
post #7 of 10 (permalink) Old 07-01-2018 Thread Starter
Finally got the billet throttle the right cable working and the tank changed and gas lines and shut off valve. I missed getting gas w/o alcohol in California now, might have to buy 94 octane chainsaw gas, at least in my Polini and BZM engines. Also have to cut a hole in the bottom of the fairing to clear the water pump. Radiator fluid and gas is all I need now. Going to add photos now.
post #8 of 10 (permalink) Old 07-03-2018
Rcfish90's Avatar
Nice bike! I love the way how they hook up the waterpump. Looks awesome!
Verstuurd vanaf mijn SM-A510F met Tapatalk
Rcfish90 is offline
post #9 of 10 (permalink) Old 07-03-2018 Thread Starter
I am the one that mounted the water pump there, cause the frame is so narrow and the exhaust was in the way up front too like shown in the 910 Polini shown. The GRCs I got are rollers, so I had to make everything fit and work. Kind of like your transmission project, never know if it will work until you try it.
Rcfish90's Avatar
Yeah, and it sometimes takes allot of effort unfortunatly.. the difficult stuff takes long and the imposible takes even longer as you say hehe
Rcfish90 is offline
