Cag leaking gas from overflow tube HELP - Page 2 - Pocket Bike Forum - Mini Bikes
Re: Cag leaking gas from overflow tube HELP
aright i did everything cleaned the float but now this thing wont start... i here it wanting to i can here a push but then it dosnt stay on... im messing with the idol and some times its good and you here it kick for like a second then it cuts off... think i need a new spark plug? and also the little nob that bleeds the tank is it sopost to bleed flat side up or what?
jazer wun is offline
gp mx3blacklight's Avatar
Images: 2
i got a question..i already asked spyguy be4...but is the tube it was leaking out of a tube that leads out of the carb and is just cut?, and the question that lead me to this is, could i just attach a boost bottle there?
gp mx3blacklight is offline
Hooligan
SpyGuy's Avatar
Images: 23
It's not too drastic of a change, but I basicallly did it for fun. I'm going to be working on it again in a while, see if I can get the noise down even firther. Just takes some working on and experimenting.
attaching a bottle on that line would be bad - then all you have is a bottle underneath your bike, slowly filling up with gas. I believe for the boost bottle trick, you actually need to drill a hole in your carburetor for a threaded fitting to attach the hose. As I've never done one, I don't know exactly how it's done,
SpyGuy is offline
gee thx guys this help a LOT. i almost gave up on my bike.by the way spyguy that is a getto tail pipe!the othe threds dont help at all so thanks a lot.
Hugo42 is offline
well moving the froks dond help but i did clean out my carb and now it domnt leek at all thx
Hugo42 is offline
Images: 1
hey my pocket dirt bike is leaking gas from the rubber tube in the carby everytime i put gas in it can anyone help plzzz.
morgan23 is offline
Hooligan
SpyGuy's Avatar
Images: 23
Clean your carburetor, readjust the float forks in the bowl by bending them slightly downward like 1/8". These carbs are finicky, gotta set 'em up just right or they leak .....
SpyGuy is offline
Images: 1
ya but on my pocket dirt bike as soon as i put in the gas it just goes out the overflow tube.
morgan23 is offline
u just open up the bowl and remove the donut or float and bend the fork down
GCD333 is offline
what up giy
TeamSPG is offline
i need some nos for my pocketbike
TeamSPG is offline
you don't have wiyers
TeamSPG is offline
My cag leaks from the overflow unless the bikes running, I've bent the forks checked for debris and all that jazz. I want to run a line from the overflow back into my fuel tank, through the tank cap. What would be the Best method of doing so? I'm determined and handy, pls guide me!
York Ricer is offline
The gas is to high in the float bowl, sometimes the shut off needle inside the float bowl leaks and does not shut off and gas keeps running faster than you use it so it goes up and out the overflow tube, running a return line won't help. Stop the leak.
sometimes the float forks get way too bent out of shape to properly shutoff too....I ve seen some really bent forks that made me wonder what that person was thinking how they thought it was gonna work like that.....LOL
The 2-Cycle DocToR
Pocket-Mechanic's Avatar
Images: 2
Where exactly is it leaking at? From the line? Where the line meets the carb? Or where it goes INTO the gas tank?
** You need to know how it WORKS before you can figure out why it WON'T !!! **
Pocket-Mechanic is offline
Лучшие идивид
I can not take part now in discussion - it is very occupied. Very soon I will necessarily express the opinion.
а чтоб уталить "голод" общения
Проститутки Москвы метро Беговая
Lucasnemi is offline
My carb is pouring out gas around the bottom of it, it looks like it coming out of the seal around the bowl and carb
here a pic of where it pouring out am I going to need a new car or can I tare this one down clean should it work or what thanks and any advice is greatly appreciated
Sent from my RM-917_nam_usa_100 using Tapatalk
jrock x-22 is offline
Alright would someone be able to help I had a leak out the bottom of my carb so I took it off and bent the float arms and it stopped the leak for a few weeks and now I took it out yesterday for about 2 hours and then cut it out and it started leaking fuel really bad so I took the bowl back off and switched the fuel off and it was coming from the float arms can eney body help
Jord123 is offline
